Page 8 of 13
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 3:27 AM
by tig
FWIW, this link has been super useful to me in ensuring I'm doing things right...
http://www.e30zone.net/e30zonewiki/inde ... tronic_1.3
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 10:41 AM
by demetk
cek wrote:
demetk wrote: What year/model e34 harness do you have?
I'm not sure. Seller told me it was from an E34.
Appreciate you taking a look! I'm sure I could just ignore all that stuff and splice in the C103 wires for 40 & 41, but I HATE not understanding the details.
So I did not use those connectors on the e28. In fact, for my M1.3 install, I completely cut them off and taped the wires into the harness for a cleaner look.
Here's some pics of where they connect to my 89 e34.
On the e28, these are the only two c103 connections I did directly to the ecu harness as described in this faq.
Main relays and fused main power feed wire I mounted here.
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 2:23 PM
by tig
Demetk = hero.
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 8:40 PM
by tig
Buttoning up the harness and a few things have me stumped.
First is the green wire that comes off #86 on the main relay. It's not going anywhere now.
I think it's supposed to go to the C103:
Here's what it looks like inside the car:
The C103 pins
1 - Black - Goes to Tach. Comes from Pin 6 on ECU (B35).
2 - Green - Goes to OBC Relay Box (pin 4). Comes from ???.
3 - White - Goes to economy meter. Comes from pin 32 on ECU (B35).
4 - Green/Yellow - Goes to AC Switch (sort of). Not connected on B34. Comes from Pin 40/41 on ECU on B35.
On my B34 pulled out of Vlad it does.
However, in all the instructions above regarding C103 people say "Just hook up pins 1 & 3".
This doesn't seem right. Can someone confirm that this is supposed to be hooked up for a B35.
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 9:28 PM
by tig
While you guys are helping with the C103 above, let's talk O2 Sensors and O2 Sensor Relays.
The outputs from my O2 Sensor Heater Relay, seen here just off the eraser of the pencil aren't connected anywhere yet.
The Green/Brown wire coming of of #85 of the O2 Sensor Heater Relay is not connected to anything.
According to the E28 ETM, these relay connections are:
30 - Green/Blue - Goes to O2 Sensor Heater (white)
85 - Green/Brown - Goes to ECU Pin 31 (O2 Sensor Heater Control)
On the E34/B35:
ECU Pin 10 is O2 Sensor Ground
ECU Pin 23 is O2 Sensor Heater Control
ECU Pin 28 is O2 Sensor Input
The O2 Sensor Connector (on the engine) has the following leads:
1 - Yellow - Sensor Ground - To ECU Pin 10
2 - White - Sensor Input - To ECU Pin 28
3 - Ground
4 - Green/Violet - Heat - (From 87 on Relay)
This is all fine and dandy, however, my ECU connector has NO CONNECTION at Pin 23. I have two B35 harnesses. There is no connector on Pin 23 of either of them!??
Where do I wire the input (#85) of the O2 Heater Control Relay from?!?
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 11:03 PM
by demetk
Are you sure that is pin 23?
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 11:45 PM
by tig
demetk wrote:Are you sure that is pin 23?
Pretty sure.
Re: M30B35 Swap FAQ
Posted: Jun 22, 2014 11:59 PM
by demetk
Pretty sure.
Is that pin numbering for the wiring face or the mating face?
Re: M30B35 Swap FAQ
Posted: Jun 23, 2014 12:04 AM
by tig
demetk wrote:
Pretty sure.
Mating face. Although it wouldn't make any difference. Pin 1 is farthest away from wire bundle and on the longer row. Can't screw that up.
Re: M30B35 Swap FAQ
Posted: Jun 23, 2014 12:15 AM
by demetk
So that looks be a mistake in the ETM. Mine doesn't have a pin at 23 either but my o2 sensor relay works. How many brown/green wires at the harness ecu connector? I wonder if they spliced 3 & 23 together and didn't update the schematic. I'll bet there's only one trigger for both the o2 relay and the fuel pump relay and it happens at pin 3.
Re: M30B35 Swap FAQ
Posted: Jun 23, 2014 2:25 AM
by tig
demetk wrote:So that looks be a mistake in the ETM. Mine doesn't have a pin at 23 either but my o2 sensor relay works. How many brown/green wires at the harness ecu connector? I wonder if they spliced 3 & 23 together and didn't update the schematic. I'll bet there's only one trigger for both the o2 relay and the fuel pump relay and it happens at pin 3.
I just downloaded the 1991, 1992, and 1993 E34 ETMs just to see if an updated ETM (over 1990) would be different.
All of these ETMs include a nice ECU pin-out that show Pin 23 as "Not Used".
In addition in 1991-93 the O2 Sensor Heater is fed by #87 on the Fuel Pump Relay. Interestingly, the Fuel Pump Relay input is hot always/not fused. This means that on E34s the O2 Sensor Heater is not fused either! Odd, but BMW knows best.
So, there you go. Not only is the 1990 ETM wrong, but the ECU documentation on E30 Zone is wrong. And Demet is right.
It turns out I had mistakenly connected the output (87 Green/Violet) of the fuel pump relay to the line that feeds the o2 sensor heater in the o2 sensor connector. This would have worked fine, and I could have removed the Heater Relay, but not having it fused was bugging me. I also didn't like the fact that I had done this by accident.
Now pin 3 of the ECU now will close both the Fuel Pump and O2 Heater Relay.
The net of this is the E28 O2 Heater Relay is completely superfluous when moving to a B35! Pin 6 of C101 does not actually need to be connected to anything (other than the diagnostics connector, if you really care). Or you can do it the way I did.
Re: M30B35 Swap FAQ
Posted: Jun 24, 2014 6:59 PM
by danc
cek wrote:I'm really struggling to figure out how to wire in my harness. My problem is that I am un-willing to just blindly splice things together when either the colors or pin #s in the previous posts are ambiguous. I need to understand what goes where.
Black 8 pin - Not needed, but has some useful stuff on it
Yellow - to TPS
Red - ECU Pin 36 - 12V Main Relay Output
Red/Blue - Switched 12V from Main Relay 87a
Brown/White - ECU Pin 51 - Auto kickdown switch input
Black - to TPS
Brown - to TPS
Brown/Green - ECU Pin 3 - Fuel Pump Relay Control
Black 2 pin - ??? Probably not needed - I think this connects to the AC switch on an E34/E32???
You may have just answered the question (the one that no one is really asking) regarding how to incorporate an auto trans into the conversion.
I'm going to have to take a look at both ETMs (E28 & E34) and see if I can make sense of those TPS connections.
Re: M30B35 Swap FAQ
Posted: Jul 12, 2014 10:36 PM
by tig
A note on dipsticks:
I was using a red one in my M30B35. The handle broke today which made me check the 2 others I have; that's when I noticed they were different and I dug in to find out what was right. I didn't realize they were different lengths.
According to RealOEM the E28/M30B34 dipstick tube and the 89/E32/M30B35 tube are both 300mm.
The M30B34 dipstick is part #11431266740 and according to RealOEM should be 552mm.
The M30B35 dipstick is is part #11431718861. RealOEM does not specify a length, but does show it with a metal loop handle.
I measured the dipsticks I have and...
The two red dipsticks below have an overall length of 545mm. The metal part is 450mm. (They look different because of the camera angle; they are the same length).
The yellow dispstick has an overall length of 550mm. The metal part is 400mm.
The B35 oil pan is shallower than the B34 pan. Both blocks have the same length tube (300mm). I verified this by measuring the tubes on my B35 block and 2 B34 blocks. They are the same length; about 260mm meaning about 40mm is inserted into the block.
If you use a B35 oil pan you should be using part #11431718861.
Re: M30B35 Swap FAQ
Posted: Jul 21, 2014 8:06 PM
by tig
Brad D. wrote:Why would I want a “B35” in my car?
Additionally, fuel economy should improve as well.
I averaged 36.7 mpg from Portland to Seattle yesterday. According to my OBC. My econometer seemed generous too; always wanting to be further to the left than I would expect.
IOW, something ain't right.
I've searched and found no one else complaining of their econometer/OBC read wrong after a swap. Maybe I just did a REALLY good job on this engine build? Haha.
Could be:
- I missed something in the swap instructions?
- I'm using 24lbs injectors and that's confusing it?
- Something else?
I sure would like my OBC/ecometer to be at least somewhat accurate. Whelp.
Re: M30B35 Swap FAQ
Posted: Jul 21, 2014 11:25 PM
by Kyle in NO
It's the 24lb injectors.
Re: M30B35 Swap FAQ
Posted: Jul 22, 2014 1:24 AM
by tig
Kyle in NO wrote:It's the 24lb injectors.
Ok. Thanks. Now what?
Re: M30B35 Swap FAQ
Posted: Jul 22, 2014 8:02 PM
by Kyle in NO
I dunno. Jump back to 1987 and recalibrate the programming for the OBC I guess.
I just live with mine, as the Econometer and OBC mileage calcs serve no useful purpose for me.
Re: M30B35 Swap FAQ
Posted: Aug 21, 2014 7:58 PM
by Jeremy
24 lb injectors use a shorter pulse width to deliver cruise fueling than stock. The dash econometer and OBC functions are both based off injector pulse width, so they think you're using less fuel. Search the archives, I remember somebody mentioning an adjustable pot on (I think) the OBC that could be used to adjust the calculation for larger injectors. Bit of a guess and check process so it's a PITA, but if it's important to you that it works correctly you could try it. The econometer on the dash is a lost cause though I think.
Re: M30B35 Swap FAQ
Posted: Sep 08, 2014 2:36 AM
by e27moloko
Hey guys Im over in Adelaide SA Australia and was wondering if there is any one on my e28.com that could help me with this conversion?
I recently bought an e28 535is m-tech with what i believe to be the M30B35 engine all ready bolted in my problem is the wiring has been spliced and is looking on the bad side, poorly done.
The person I purchased the car from for very little said that it was running before i bought it but very ruff. The starter motor is not wired in so Im unable to start it.
just wondering if any of the people on this forum would be able to help or know of someone that could in SA..
Thanks in Advance Justin
Re: M30B35 Swap FAQ
Posted: Sep 08, 2014 3:03 AM
by e27moloko
hey guys id also like to know if you can make a 1989 535i e34 automatic harness work with a manual 1986 e28 535i m30b35 engine????
Re: M30B35 Swap FAQ
Posted: Sep 08, 2014 4:21 AM
by mitch5
e27moloko wrote:hey guys id also like to know if you can make a 1989 535i e34 automatic harness work with a manual 1986 e28 535i m30b35 engine????
Yes you although you do have to change a few sensors, first one of the top of my head is the tps sensor. A lot of people prefer the e34 Barnes because its has the plastic cover for the injector wiring
Re: M30B35 Swap FAQ
Posted: Sep 08, 2014 5:06 AM
by e27moloko
mitch5 wrote:Yes you although you do have to change a few sensors, first one of the top of my head is the tps sensor. A lot of people prefer the e34 Barnes because its has the plastic cover for the injector wiring
Thank you mate much appreciated i will now be able to buy the harness from a e34 535 :D
Re: M30B35 Swap FAQ
Posted: Oct 03, 2014 7:49 PM
by John project car
Anyone know if a wiring harness out of a e32 will work ? I happen to have one for parts with a good engine - drives , no interior . Want to do a turbo on mine and I am thinking I might as well swap engines too,
Re: M30B35 Swap FAQ
Posted: Oct 11, 2014 11:45 AM
by kzolee
Yes, the E32 harness works. My car has also an E32 harness.
Re: M30B35 Swap FAQ
Posted: Oct 11, 2014 11:02 PM
by tig
If you are putting an M30B35 in an E28, you might want an intake manifold bracket that will fit. See this thread:
http://www.mye28.com/viewtopic.php?f=4&t=126900
Re: M30B35 Swap FAQ
Posted: Oct 26, 2014 8:55 PM
by rondwyer
Hi,
I am doing the M30B35 swap to an e12, the wiring is nowhere near as easy to follow with these current flow diagrams. Does anyone have a diagram of the engine harness? I am particularly confused by a plug that seems to go to the variable Throttle position sensor instead of to the ECU. Sorting out the harness will help me determine what wires are important and which ones could be removed without any ill effects. Last I did one of these it was an E28 engine to my E3 coupe.
Any assistance that the group could provide would be greatly appreciated.
I don't check messages often, please e-mail me.
Re: M30B35 Swap Wiring Harness Mystery Solved
Posted: Nov 01, 2014 10:27 PM
by rondwyer
Many thanks to Mike for contacting me with the link to the Rosetta stone. My conundrum was a connector that seemed to be attached to some portion of the throttle position sensor which being an engine component, was not readily apparent as to what it connected to. Ends up the automatic transmission was looking for the variable resistance outputs other than the simple TPS outputs and are now redundant. For anyone attempting to map the harness off the BMW current flow diagram, give up. It is a worthless POS. I spent way too many hours attempting to make sense of a publication that only vaguely hinted at portions of the bigger picture. I am not yet certain of the origin of the diagram I now have but it is either a Mitchell, Chilton or Haynes creation. As a first choice, it is invaluable. The BMW current flow diagrams come in to help figure out if you have identified the appropriate connectors, etc. Today I confirmed there is indeed a significant amount of wiring in the 735i harness that can hit the trashcan. The wiring diagram tells exactly what the color codes are that can be deemed redundant.
Good news, if anyone wants one of these harnesses ready to install, it can be had for a reasonable cost. The man I met today has 7 coupes in various stages of upgrade in his shop and since I am a coupe restoration veteran, we had a lot to chat about. Essentially a harness takes him 16 hours to do correctly. They are priced accordingly as he has a business to run...(rent to pay). After I finish this E12 project, I realized I need another E28 and am on the hunt!
Glad I posted, thanks Mike!
Re: M30B35 Swap FAQ
Posted: Nov 12, 2014 2:38 PM
by BuzzBomb
Ron, the level of difficulty and frustration felt was compounded by the fact that not only did you use a harness from a car that is physically laid out differently, you have additional wiring meant for a car with an automatic trans. Regardless, the 1.3 harness is straightforward and not that hard to understand. It just takes once doing it. Now that you know what is involved, you're in a good position to help others that want to do similar builds. Consider posting a diagram for the connection at the fusebox for 1.3 into e12 conversion. I know I'd like it for reference...
M30B35 Swap using Autobox
Posted: Nov 12, 2014 2:55 PM
by BuzzBomb
For reasons unknown, information for a 1.3 install while retaining an automatic transmission hasn't been posted in this FAQ.
Thanks to Mark at Bahn Motorworks for his help over the phone with a few last mystery wires.
If anyone needs assistance with wiring questions, PM me.
Re: M30B35 Swap FAQ
Posted: Dec 16, 2014 2:38 AM
by bkbimmer
I am in the middle of modifying a e34 harness for a 1.3 conversion on a b34 engine....
I am pretty confused at the moment on where the charge light wire comes from with the b35 harness. The b34 had a alternator harness built in, the b35 doesn't seem to? What am I missing?
I feel really stupid right now!
