E28 537i-24v Turbo
Shadow
Post by Shadow »
Oohh. Didn't think about that.
So basically it's a total guess at what it should
supposedly be making if there was xx amount of factual
drive-train losses.. :|
Jelmer538i
Post by Jelmer538i »
The first driving and a driftday is done with the 537iT! The power/torque is unbelievable! It is now running on 14 psi because the boostcontroller is not working, we will get a new one soon.
Drifting went fine too, we can spin the tires in 4th gear all the way to the rev limiter and leave marks as long as 1600 feet! :cool:
Jelmer538i
DMS
Post by DMS »
Hey Jelmer,
What do you use for a low pressure pump? The original in tank pump?
Jelmer538i
Yes, we use a new OEM in tank pump that pumps the E85 to a swirl tank which feeds 2 Bosch 044's.
Jelmer538i wrote:Yes, we use a new OEM in tank pump that pumps the E85 to a swirl tank which feeds 2 Bosch 044's.
Do you think an in tank pump feeding directly into the dual Bosch 044's would work also? Do you have a picture of your swirl tank setup?
Jelmer538i
I don't know if it would work without the swirl tank but getting one of these is always better for a E28 because they run out of fuel when cornering hard and with a half full tank.
Jelmer538i
Today we did some trackdriving with the 537i:
http://www.youtube.com/watch?v=TndXA_2rzpI
ZenitramNaes
Post by ZenitramNaes »
Extremely impressive numbers. When you say TCD 745i turbo is that the k27 with the garrett 60 trim?
Murfinator
Post by Murfinator »
The swirl tank was a good idea to address hard cornering fuel starvation at < half tank. However, you're doing yourself no favors by using the OE in-tank lift pump (externally?) then dividing the line (apparently same ID) to the two 044's. Most likely the lift pump (Walbro?) is only adding restriction since the 044's can only flow what whatever fuel the lift pump provides, like trying to pull fluid through a clogged filter. Better to ditch the lift pump and increase the ID of all your fuel lines. Looks like you're using full-flow fittings, which is definitely helping with flow. With a single 044 rated with sufficient capacity to feed 600-700hp you likely aren't as yet pushing those limits. What filtering are you using?
Jelmer538i
The 537i is going to be tuned for 100% bio-ethanol and finaly gets a working boost controller so we run 1.2 bar turbo pressure.
sideways7
Post by sideways7 »
those 1600cc injectors should be able to flow close to 1000 whp with enough fuel pumps and pressure behind it.
Jelmer538i
Re: E28 537i on the hub-dyno
After a busy time this E28 gets some attention again. The DTA engine managment is going out because it is very complex and very, very hard to get tuned properly. A Microsquirt is going to do the job now, because the tuner has alot of experience with these. He also puts a bio ethanol sensor in it so we can run regular gas and bio Ethanol. The boost controller is already installed. When everythings is ready I'll make some pictures and a vid.
Jelmer538i
Re: E28 537i-24v Turbo
Some vids of the testing on pump gas:
https://www.youtube.com/watch?v=yTVv2fcM6L0
https://www.youtube.com/watch?v=SSpiKAtj7q4
Next week the final tuning on 17 psi.
Jelmer538i
A new headgasket (actualy it's piramid ringed now) and a bio ethanol sensor and now it makes these numbers:
650Hp and 833lb/ft
Dyno print will follow.
Jelmer538i
Haven't updated this for a long time but a lot has happend.
New block (M30B34)
New Wiseco pistons
New turbo: Garret GTX42 dual ceramic ballbearing turbo
Old setup with the KKK K27 TCD turbo:
The engine is currently build but this is the new turbo:
marc79euro645
Post by marc79euro645 »
are you using a twin cam head on an m30b34 block?
George
Post by George »
That is a Big Fucking Turbo. I approve. Looking forward to a dyno to see what the power curve looks like.
What are you seeing for IAT?
offroadkarter
Post by offroadkarter »
marc79euro645 wrote:are you using a twin cam head on an m30b34 block?
A lot of europeans like to do this since it's cheaper than a S38 block.
marc79euro645
I thought there was a difference in the front timing covers that would not allow them swap.
Jelmer538i
@Marc: Yes, no problem bolting it on. Only some minor difference like the oil return from the head and the chain guide pin.
@George: the turbo can support 1000+ horsepower so that is our goal.
@Nebraska: I'm not sure on the old setup.
The current 6 speed Getrag 420 will be swapped for a ZF gs6-53dz gearbox because these are strong, cheap and readly available.
The Getrag will be for sale.
In for more. :Wow:
charofire
Post by charofire »
This is really cool. How will you adapt the ZF gs6-53dz gearbox to mate to the s38?
Jelmer538i
We will weld a new bellhousing on it after both are machined.
Jelmer538i
Coming along nicely:
Nanajoth
Post by Nanajoth »
I was wondering about this, looks good!
russc
Post by russc »
ya, that turbo should work well.... for big power #'s
Jelmer538i
Almost there! Right now we are working on the 4" exhaust and the 3" turbo --> intercooler --> intake tubing.
Offcourse the innerfender will be closed again...
