4 holes to give reason to changing your timing belt
south26
Post by south26 »
ya, well u no i had to tpye real fast wit gading papers
tn535i
Post by tn535i »
Is it possible the belt stripped some teeth and then the 'mechanic' (may not apply in this case) rotated the cam while changing the cap and rotor which re-engaged some good teeth on the belt and then tried to start it a few more times with more dmage occuring?
I think only two valves are ever open at the same time and when a belt brakes you break those valves but it would have to slip and sorta stop and start again horribly out of time to do that.
south26 wrote:ya, well u no i had to tpye real fast wit gading papers
-nice save, irregardless.
tn535i wrote:Is it possible the belt stripped some teeth and then the 'mechanic' (may not apply in this case) rotated the cam while changing the cap and rotor which re-engaged some good teeth on the belt and then tried to start it a few more times with more dmage occuring?
Had a customer with one that broke at interstate speed. Head looked just like this. Probably skipped time or stripped a couple of teeth and kept going.
tn535i
Post by tn535i »
When one of our M20's had a rocker break at 70 ish and the cam stopped dead in it's tracks it only bent one valve. The one where the rocker broke should have been open and was undamaged since it was closed while one other valve was open and it bent. SO I am pretty sure that a clean break couldn't do this. It would have to skip time and more or less keep going for a bit.
And why does it always seem like the exhaust side gets so much damage compared to intake. At least thats what I've noticed in many pictures? Extra heat or difference in valves themselves?
south26
Post by south26 »
When I took the belt off it was missing a number of teeth like it had skipped and then broke.
south26
Post by south26 »
to show to new people with a 528e
cvillebimmer
Post by cvillebimmer »
Best change da timin belt mang!
Andy, if you come across black leather in 9/10 condition for an e32, let me know. e34 would work for the front but I'd rather not bother with dying the back seat.
Best be changin' that t-belt y0!
pleasefixitup
Post by pleasefixitup »
who's finley? ;)
When looking at a m20 in a e34 all I can think is, look at all this room!!!!
SoopaGhetto
Post by SoopaGhetto »
I think I experienced some valve float...
I thought my head gasket blew. I was able to cradle it home. got all the parts for an e2i swap and had a big surprise :rofl: :banana:
the rocker arm, spring, and keeper were all intact baffling
south26
Post by south26 »
It has been a 8 months, so hear is a reason for new people to change their timing belt.
Andy
south26
Re: 4 holes to give reason to changing your timing belt
Post by south26 »
I thought this might be good for new members.
Andy
Jelmer538i
Post by Jelmer538i »
Here some carnage from an S38B36.
tn535i
Post by tn535i »
What caused this ^^^ ?
If my S38 ever suffers that I'll cry...
trevmmeister
Post by trevmmeister »
tn535i wrote:What caused this ^^^ ?
Exactly what I said. What could have possibly gone so catastrophically wrong?!
south26
Post by south26 »
Had that happen to a m30b35 I was parting, except it had a whole in both sides. The rod let go and all kinds of crap hit the fan.
Andy
Owndapwn
Post by Owndapwn »
Man, I bet valve reliefed pistons never looked so good, huh?
Jelmer538i
This went boom at 160mph. I think it was the combination of lack of maintenance, chipped ECU (speed limiter removed, rev limiter raised) and the fact that the guy never let it warm up properly. The car sat for 4 months in the winter and he started it and went directly to the freeway to test the top speed.
I've seen a trown rod before but I really wonder how the pistonrings end up between the valves!! :shock: There is no room between the piston and the cilinder wall, how the heel get they past that?
Jelmer538i
Owh, and the rod was gone, like we never found it!! Mostly there is still a piece connectec to the crank.... :lol:
Jelmer538i wrote:...chipped ECU (speed limiter removed, rev limiter raised) ...
Why do 'tuners' insist on doing this? Unless you are racing, what benefit is a raised/removed rev limiter?
Post by slammin_e28 »
Forum signature lines.
south26
Post by south26 »
Thought that a friendly reminder to the 528e people was a good thing.
Andy
south26 wrote:Thought that a friendly reminder to the 528e people was a good thing.
Andy
You are a good man.
