Posted: May 14, 2014 10:36 PM
i had to change a lot of angles to make everything fit more easily. so, not much forward progress... but, i'm happier with it now. i also added the wastegate.
This 24v head wouldn't happen to be the S38 head, would it? You know that doesn't bolt onto the M30 block, right?Jelmer538i wrote:It would be plain stuppid to put loads of money and time into a M30 head when there is a 24v head available of the shelf which flows 3000 times better.
Yes it does fit. My brother has it in his 537i turbo: M30 block, S38 head. But we only used this combo because the M30 block was already prepped.Owndapwn wrote: This 24v head wouldn't happen to be the S38 head, would it? You know that doesn't bolt onto the M30 block, right?
I'd be very interested in how it was prepped then.Jelmer538i wrote:Yes it does fit. My brother has it in his 537i turbo: M30 block, S38 head. But we only used this combo because the M30 block was already prepped.Owndapwn wrote: This 24v head wouldn't happen to be the S38 head, would it? You know that doesn't bolt onto the M30 block, right?
Well, you heard wrong because a S38 block is basicly a M30 block. Only issue's where the oil return from the head which we made our selfs and the timing chain where we used the S38 timing components, this was basicly plug and play.Owndapwn wrote:I'd be very interested in how it was prepped then.Jelmer538i wrote:Yes it does fit. My brother has it in his 537i turbo: M30 block, S38 head. But we only used this combo because the M30 block was already prepped.Owndapwn wrote: This 24v head wouldn't happen to be the S38 head, would it? You know that doesn't bolt onto the M30 block, right?
I've heard multiple accounts that the oil and coolant reservoirs don't line up from head to block, in addition to the obvious timing problems.
Which begs the question why there isn't a single documented build to be found. Just a few hypotheticals and second hand claims, and people looking to do this and being told it would require VERY invasive machine work on the block and head, the oil return, timing, compression ratio, and the bore doesn't match to name a few of the issues that I've seen.Jelmer538i wrote:Well, you heard wrong because a S38 block is basicly a M30 block. Only issue's where the oil return from the head which we made our selfs and the timing chain where we used the S38 timing components, this was basicly plug and play.Owndapwn wrote:I'd be very interested in how it was prepped then.Jelmer538i wrote:Yes it does fit. My brother has it in his 537i turbo: M30 block, S38 head. But we only used this combo because the M30 block was already prepped.Owndapwn wrote: This 24v head wouldn't happen to be the S38 head, would it? You know that doesn't bolt onto the M30 block, right?
