535is Homebrew Turbo (ex 633 Callaway) - 2024 Update
Re: Callaway 633CSi
The car is alive again!
Started it up last night late around 8:30pm after tracking down no start issue. It ended up being a no spark situation. Checked main relay, speed/reference sensors, power at the coil, ECU etc. Eventually we got it going and it didn't want to idle because of a bad connection at the Coolant temp sensor. The connection here had gone bad with a non-BMW connector. Got that sorted out and the hood back on.
Idle was looking smooth at around ~12.5-13:1 as we added coolant to top off the system. Got it closed up and then put the hood on as it was drizzling. Started up again and nice AFR readings from the gauge, so I took it around the block. In slight acceleration, AFR's at 12:0-12.5:1, excellent. Drove a mile around the block but never really got on it. The turbo spool makes a somewhat loud noise, much more than my brothers 745i. It was rainy and went and my tires are old and somewhat questionable in the weather so I just took it easy.
Took my friend Mike around the block and he's excited to see how the car does. Definitely had some torque come on with a light bit of throttle.
I then drove the car home for the night, about 55 miles, but I took it very easy since it was already 10pm by this point and AFR readings suddenly went lean. Around 15.5:1 and sometimes slightly more. It was a cool wet evening so I decided to drive it home. During driving it was bouncing around quite a bit from 14-16.5:1 while staying steady on the throttle. I stayed out of boost religiously.
Thinking that some of the crappy intake boots went bad and burst without a BOV in place. Next step will be to install the BOV/ diverter along with replace all of the connecting piping hoses. Can't really troubleshoot until I know those connections are good.
Also, after warm up the oil pressure light comes on at idle. I thought this was from a weak pump on the B32, but it is doing the same on the B34. I have read up about restrictors in the oil line, do I need this? After 1000rpm, the light turn outs and oil pressure goes up nicely... The oil supply like is -4AN. Oil is 20W50 conventional for the time being.
So I need to diagnose a temp gauge that doesn't move off the right edge of blue (it moves).
Rewire AFR gauge to known good power circuit.
replace hose couplers
add diverter valve
replace brake rotors/pads (likely E34 big brake upgrade).
replace drivers window motor
Once I get it running back to when it was when we started it up, I'll continue with front/rear bumper install and then I'll be able to have the rear section of the exhaust finished up. We just used exhaust clamps for a temporary solution until everything can be finalized.
Maybe a few photos later today, unfortunately I won't be working on it this weekend due to a trip to Pagosa Springs for D4C planning.
B Rod
Re: Callaway 633CSi
Post by B Rod »
Did the wiring to the fuse box end up being plug and play as expected?
Re: Callaway 633CSi
B Rod wrote:Did the wiring to the fuse box end up being plug and play as expected?
It did indeed!
Now to track down lean running condition. Thinking FPR may be faulty, or AFM may need to be adjusted although I probably won't mess with it. Won't be around this weekend, so it may take me some time to track it down. As I mentioned, I'll be taking it apart to get the correct (new) couplers for all the piping.
In other news, i did replace the OBC fuse and it is now working! Sorry no photos today, so you will have to wait until early next week. Not much to look at as I still have ot reroute diverter valve and other stuff.
Re: Callaway 633CSi
I was planning to spend some time yesterday evening swapping parts to understand why the car was running lean, however it has been raining the last two days and unfortunately now the car won't start.
I had power at the coil, swapped the main/fuel pump relay, and swapped AFM's, but that was about as far as I got. I am wondering if some moisture got into the cap/rotor, but I won't know until it dries up (rain forecast for the next full week, which is insane for CO). I may try my other 059 ECU tomorrow as that's a pretty easy test.
In between all of this I did replace the fuse of the OBC I, so I did get excited when the display started working, although the functions aren't as intuitive as the 85+ OBC II. I found some useful info on the forum here about how to use it. although I don't think that's the problem, I may disconnect the battery to rule out any code issues that could be caused by my button fiddling.
I added the E30 idle control valve and added a port on the callaway manifold for diverter valve. I was going to route that in once I get the fuelling issue figured out. Here's a photo of the engine currently.
So to feel like I made some progress, I mounted up the front euro bumper/spoiler. At least it looks like it is closer to getting out on the road!
The plan was to unplug to the 02 sensor when I start it and see how the fuel mixture changes. Swapping the AFM with my spare would then tell me if it is operating the same as my known good one. Based on those tests, I was going to assess the condition of the spark plugs and injectors to get the car running properly.
Also found the Waterpump leaking, so a new one is coming in to be replaced asap, along with the replacement heater core.
Re: Callaway 633CSi
tschultz wrote: The plan was to unplug to the 02 sensor when I start it and see how the fuel mixture changes. Swapping the AFM with my spare would then tell me if it is operating the same as my known good one. Based on those tests, I was going to assess the condition of the spark plugs and injectors to get the car running properly.
This doesn't make any sense to me.
GI jonas
Re: Callaway 633CSi
Post by GI jonas »
You have company.
Re: Callaway 633CSi
When the donor car was parked, my friend Mike said the engine ran strong. This includes the large 42lb injectors still on the engine. To this point I have assumed that they were good as we got the car started right away after we found a wiring issue on the CTS connector. For the first ~5 minutes the Air/fuel mixture was great 12-14. Once driving around, the mixture started going to the lean side. I had it in the back of my head this had to do with the ECU 'learning' from the 02 sensor feedback.
If I understand the Motronic system, the 02 Sensor, CTS, and AFM are the main inputs controlling air/fuel mixture. I want to make sure neither is operating improperly. Unplug the 02 sensor, and the ECU defaults to a slightly more rich map. I want to make sure this happens so I know the wiring is good (it had been tampered with).
Also, if the AFM has been tampered with for the larger injectos, I am thinking it could be causing the lean mixture, so I was going to see if the mixture becomes any more rich when I swap in my known good AFM. Once I know my AFM is good and no air is bypassing it, then it will be time to verify that all of the injectors and spark plugs are operating properly.
Re: Callaway 633CSi
Motronic won't support 42lb injectors. So it's highly unlikely that is what you have. You need to pull one out and identify it.
Todd
Re: Callaway 633CSi
Ford Lime Green injectors. The Ford part number on them is: F83E-A5A as posted earlier.
From some additional research, lime is typically 42lbs, but these should be 19lbs:
Bosch part number is: 0 280 155 909 Measured resistance is 14.4 ohms. Average rated flow - 19lb/hr.
Can be used as replacements for OE part numbers: 0280150943, 0280150939, and 0280150778, FOTE-19lb/hr.
Following are some of the possible vehicle applications:
Ford 92-95 4.6 V-8 Crown Victoria
Ford 96-02 4.6 V-8 Mustang
Ford 95-96 4.6 T'Bird
Ford 96-98 4.6 Crown Victoria
Ford 97-00 5.4 Truck, Expedition
Ford 86-95 5.0/5.8L V-8
Ford Truck 5.0/5.8L EFI-MPI V-8
Thanks for the help--maybe these aren't as common as the typical yellow top bosch injectors?
Re: Callaway 633CSi
tschultz wrote:Ford Lime Green injectors. The Ford part number on them is: F83E-A5A as posted earlier.
Bingo.
Re: Callaway 633CSi
Today hopping in and doing nothing else, the car started. Not sure what the no-start is caused by (except moisture), but I won't be driving the car much until I figure it out.
AFM is actually unopened, but the idle control screw was turned in. I adjusted it back to 3 turns out, however it didn't seem to change much.
I am still a little puzzled why the engine idles at 16-17:1. Drove it around the block and it gets moving pretty well. It doesn't like gently getting onto the accelerator and sticks are 15:1, so I haven't pushed it. But it does like full throttle, where AFR's show 12:1-13:1. It is seriously quick though, third gear pull showed 8psi boost. It seems like the turbo is set pretty well to the mid range. Nothing crazy extra past 4500rpm, but it was pulling slightly harder than the S38.
Getting it running right will make a pretty sweet setup. Just until then :x
I will replace the FPR with a spare as pulling the vacuum line didn't seem to change anything. Also need to test the CTS and TPS with a meter.
Jelmer538i
Re: Callaway 633CSi
Post by Jelmer538i »
I was told that you can't rely on a narrowband lambda, you need to get a a wideband controller and sensor.
Re: Callaway 633CSi
Thanks Jelmer.
I have an AEM UEGO Wideband sensor that's giving me AFR readings, so I'm certainly not guessing.
I am slightly puzzled why the WOT AFR's look great, yet everywhere else, those values are lean. From my research, most people have the opposite problem. :?
downforce22
Re: Callaway 633CSi
Post by downforce22 »
The motronic 1.3 TPS has like 3 settings. Closed, Open, and WOT. It should be fine at full throttle because the motronic switches to the WOT part of the map based on the tps switching at 100% open. It does not use a variable TPS like the M5x cars do. I had to switch my TPS to a vTPS to get a steady signal from 0-100% open on the m20. With the stock m20 tps it would 'float' higher, continually increasing, even if you left your foot at a constant throttle input.
One option is that the fpr may be failing open not allowing enough fuel pressure to build up. WIth the WOT switch the injectors inject everything they have and it is about right at 12-13 AFR.
Another option is the AFM is reading incorrect. Unlikely if the engine was running well on the other car, but still a potential problem.
Another option is the TPS could be bad and sending incorret signals to the ECU.
ECU could be bad, but probably not since it seems to run or drive fine.
Oxygen sensor could be bad and not injecting the right amount of fuel at idle.
Injectors could be old/clogged/ not working right. Not likely but plausible.
Also, it could be any combination of the above causing issues. I can get that spare 3 bar fpr, rrpr, and 24# injectors to help troubleshoot half of the above issues. I would have considered using one oxygen sensor port because that way you can see on the display of the wideband what signal it is sending to the ecu. WIth two it doesn't make sense and your oxygen sensor could be bad.
Jelmer538i
Re: Callaway 633CSi
tschultz wrote:Thanks Jelmer.
But does it has a wide band controller? You need a wideband controller to monitor it.
Re: Callaway 633CSi
Jelmer, it is both combined into one: http://www.aemelectronics.com/?q=produc ... -afr-gauge
Ted, thanks for describing that. I have a small update. Getting home and trying the 059ECU with the turbo chip, the car did not want to start. So I pulled out my spare and the car started right away with that. I think the turbo chip ECU is flaky and needs solder joints repaired. But anyway, upon startup, AFR's looked perfect at 14.7 upon idle. Revving also stayed very close to stoich. I decided to drive around the block and to my amazement, everything was looking good. Idle, partial throttle, it was sticking right on 14.7. Note that I changed NOTHING since shutting off the car yesterday besides the ECU. I want to believe this means my coil, plug wires, injectors, etc are all working properly.
About 2 miles down the road, all of the sudden everything went lean. The same hesitation as before, 16+ AFR's and poor drivability.
So when I got home I did some checking. When I unplug and retry the car, it sits right at 14.7 for ~5 seconds until it all the sudden goes lean and idles poorly. I am thinking the Coolant Temp Sensor is bad, and once the coolant warms up, the sensor throws off the mixture. Then, the ECU saves the revised map and it uses this map when I restart the cold engine.
Additionally my o2 sensor cable does not have any power. I need to check the relay, but with a test light, I am getting nothing from the o2 harness plug. Power between the Green/Blue wire and the Brown wire is supplied to the heater. I mention wire colors because mine had been cut at one point. This leaves the green wire for signal. I was attempting to hook the Wideband simulated 0-1volt output to this green wire so I can see exactly what the computer is seeing. Of course at this point it is seeing nothing. I am a little puzzled why the mixture doesn't default to slightly rich in this condition, but I ill check this out once I can confirm the CTS and o2 are operating properly.
Anyway, I'll be testing these items with a meter tonight to understand which may be bad.
mitch5
Re: Callaway 633CSi
Post by mitch5 »
Just a heads up from my experience with testing the 12v wire for the o2 when I installed my wideband, the car has to be cranking or running for the o2 to get power. I don't know why but when you test for 12v I'm accessory position you get nothing
Re: Callaway 633CSi
mitch5 wrote:Just a heads up from my experience with testing the 12v wire for the o2 when I installed my wideband, the car has to be cranking or running for the o2 to get power. I don't know why but when you test for 12v I'm accessory position you get nothing
Thanks Mitch. After replacing the heater relay, this is the same behavior on my car. I believe the old relay was incorrect, it was some noname brand and there was no power when the engine was running. Getting the o2 sensor plugged in and operating has made a huge difference in the idle and mixture. Now it is returning to 14.5-15 and responding much better to throttle inputs!
Here's a short video. Yes I still need to fix the window, my window motor replacement was a late model and had a different mounting pattern :x
Quality not great, but thought I would share: https://www.youtube.com/watch?v=DXaF_fN ... e=youtu.be
With the wastegate set all the way relaxed, it's currently running at about 8psi. And yes, I'll need to get an alignment once I swap shocks/springs.
Re: Callaway 633CSi
Congrats! You made quick work of the swap and sorting out the issues. Job well done.
Re: Callaway 633CSi
T_C_D wrote:Congrats! You made quick work of the swap and sorting out the issues. Job well done.
Thanks, still lots to do! Just driving the current setup around, I can tell why MS would be the better way to go to make use of fueling and have the control for optimum drivability. I can tell there are some slight RPM where it could be smoother power delivery. For now I am a ways away from that but will be preparing to do the suspension install. I'd like to take the shocks and spring (bilstein/eibach) from my 535i as they worked well on the track but are not the most comfortable on the street. I'd like to put my DD back to stock so this car will become more track oriented.
May try the BEGI 2025 soon, we will see.
What do people use for oil coolers? I read about the B35 oil filter housing and cooler setup from an E32. I'd probably do this before actually bringing the car to an autocross or lapping day...
Re: Callaway 633CSi
tschultz wrote:
I ran my e34 with no oil cooler at Mid Ohio and Road America on coolish days with no issues. Best oil cooler for you would be from an e24 m6.
9mil
Re: Callaway 633CSi
Post by 9mil »
Careful what you wish for :-)
Re: Callaway 633CSi
For the immediate future, MS is off the table until I can get on top of other items like normal drivability-- finishing exhaust, suspension, brakes, alignment, heater core/waterpump. I am not driving this further than a mile from my house since I don't want to get stranded. Part of this was due to the ECU, the other is a weeping water pump.
So I took apart the ECU causing the no-start issue and found the transistor joints had cracked. After soldering, this ecu fired right up 3 times in sequence last night! I am still carrying the spare so I don't get stranded anywhere. But here's a photo I found on the subject, along with the repair procedure:
Great procedure, not always shared here in my search for "ecu solder joints cracking transistor" because it isn't an actual thread on the forum: http://e28-535i.com/technical/e28-ECU_Repair.php
I will be swapping the FPR as I think the one in this engine is bad. No change at idle with/without vacuum line hooked up, and the power delivery is not very smooth after 4500rpm (even though AFR's bounce between 11.5-12.5). After I replace this, I may try the BEGI 2025 for fuel control. To do this, I will need a 255lph pump for the flow capability and larger injectors.
I will also be soon replacing the waterpump, gasket, temp sender, and at some point, replacing the heater core. These parts are coming in today, so hopefully I can start on this soon.
I have a few other items I need to repair on both the M5 (clutch return spring is damaged), 535i (front lower control arm ball joint is bad), and X5 (Air springs on the fiancé's vehicle just failed). So I have plenty of car projects and it may take me a while to get these turbo car items completed.
The next big project will be swapping shocks and springs between cars. In my head all three of my E28 based cars need a set of shocks/springs from another car, or what I have sitting in the garage.
Re: Callaway 633CSi
Here are a few other random photos from the swap last month.
pulling out the donor
The assembled Callaway setup (hillbilly special wood block not shown)
Installing the new engine:
So another update.
I have been in discussions with Ken H. (Lucifer's Hammer) and he was kind enough to spend some time digging for me. Based on the specs/part number on the turbo he was able to determine that the turbo in this car is a T04B S-4. I had assumed based on some posts by a member here, that it was S trim, and that the generic turbo map I found was correct. Well it is not correct. Further research (big kudos Ken) shows that this is the correct compressor map.
Unfortunately with the higher altitude and larger displacement of the B34, this moves the map further into choke. At ~485cfm and 1.8 pressure ratio, it's sitting outside the 60% island :shock: Well, unfortunately I'm gong to have to change turbo's when I want to actually drive this thing. It sucks because the manifold is a PIA, but I will figure it out when I come to that.
But anyway, onward with progress. Late last week, after work I spent the evening replacing the water pump. Since the swap, there had been a leak from around the water pump area--dripping off the oil pan. From all my research this indicated water pump. The shaft didn't have much play but I figured I ought to replace it. So after swapping the front control arm off my 535i (it didn't solve my clunking :x so I'll have to resolve that later), I started on the 633. Good news, it was pretty straight forward and I was able to get the old one out. I think the gasket may have failed, causing a slow leak. Got the mating surface nice and smooth and put the new one in. From my research on here, I went with the Saleri brand. I buttoned it up and was able to get it all back together. Good news, no more leak.
I replaced the coolant temp sender, but still not getting anything. I think it's bad wiring because everything was working before, and ground the sender doesn't move the gauge. I didn't want to have to track this down, but oh well. Will follow the repair procedure: http://www.mye28.com/viewtopic.php?t=34049
I drove it around the block again and still no leaks. However, with the new knowledge about the turbo size, everything made sense. The engine runs out of steam after ~4500rpm, I believe because of compressor choke. Also, the manifold and turbo seem very hot, even for 65 degree weather, which makes sense for the condition. Also, it makes sense because a very similarly sized turbo was put on all of the other Callaway models-- the M10 and other 4 cylinder VW's that Callaway modified in the early 80's. So down the road I am definitely changing the turbo, but I currently don't have the funds for it, and probably won't until next year when I got on top of my other projects.
So over the weekend I was able to do a few more items. I got some rotors in the mail and calipers from my brothers old parts car. So I installed E34 rear rotors and the calipers. Pretty excited about this as I have them on my M5. The fronts, however, will have to be rebuilt, and I will need to get rotors still.
I didn't drive it around yet because I also started on the heater core replacement (remember our mistake when pulling the engine??). Well I tore into it Saturday and spent a couple of hours on it until I stopped at my brothers house. I continued working on it yesterday for 4 hours or so. Lots of removing of parts, but I wasn't taking pictures as I really wanted to get the job done. The toughest part is getting all of the vent out of place, removing all the AC bits, and then pulling out the heater box. It took me a while to understand that there were 4 nuts/bolts holding the heater box in place. Once loose, it took another 15 minutes to get it situated on the passenger floor for core replacement. I'm glad I got it removed because I found a little friend and his home inside the box. No photos, but there were nuts, insulation, leaves and other misc stuff.
I'm pretty glad to have changed it for this reason.
Old and new.
I figured the heater didn't work well because of the heater valve, but I didn't really drive the car enough in the cold to know for sure. The valve looked pretty good (except for the brown crud in the filter), but I replaced it with a new one anyway. Now I know the heater didn't work because the heater box didn't ever get enough airflow to actually transfer heat to the cabin. So for the time being I have to finish putting the center console back in, along with the glove box and driver's kick panel. It has been a good opportunity to clean out the dirt and trash, along with getting the wiring cleaned up underneath the dash. Still have a ways to go, but I'm getting closer.
Re: Callaway 633CSi
In the future all you have to do is measure bother the compressor wheel and turbine wheel to determine capacity. It's super simple and maps are readily available. We went through this discussion in 2003. I suspect you were still in high school. LOL
The compressor wheel isn't a choke point. The turbine could be but isn't. Even with the smallish compressor wheel the turbo will support 7/8psi although not efficiently. The engine. Probably falls on its face because you have not tuned it yet. Don't give up yet.
Re: Callaway 633CSi
T_C_D wrote:In the future all you have to do is measure bother the compressor wheel and turbine wheel to determine capacity. It's super simple and maps are readily available. We went through this discussion in 2003. I suspect you were still in high school. LOL
Thanks Todd! I suppose it may be worth verifying my FPR is working properly and checking fuel pressure.
Next, getting a Warlboro pump installed sooner than later and the RRFPR may be a good idea so I know the fuel supply is not contributing to the problem.
daniels635turbo
Re: Callaway 633CSi
Post by daniels635turbo »
Some good work on this, I like your persistence. Another thing to consider is the maximum cfm the head will flow through the rev range. I did a lot of research on this before I started building my engine. There are tables around with the flow rates of the heads. I was able to compare the stock B34 with the B35, then the twin cam head. Some big differences. Best to see where your head is at with flow and use the torque decrease as the max flow rate on the table for the turbo. All depends if you are looking for high hp top end, or fat torque curve that'll burn out at higher rpm. Each engine has its characteristics, best to build around those. Also you need to get a specific turbo cam, it's all wasted boost with cam timing with overlaps.
My engine will run 400hp at the wheels with 8 pounds boost, no intercooler according to Jim at the Metric Mechanic.
Read this and you will get an idea why you need a turbo cam
http://www.speedtalk.com/forum/viewtopi ... =1&t=14384
Re: Callaway 633CSi
daniels635turbo wrote: Also you need to get a specific turbo cam, it's all wasted boost with cam timing with overlaps.
Some thoughts:
- Both b34 and b35 are great turbo cams. The one turbo cam I tested made more power but at the expense of drivability.
- No m30 with make 400rwhp at 8psi non intercooled.
daniels635turbo
Re: Callaway 633CSi
daniels635turbo
Re: Callaway 633CSi
Some thoughts:
Check with Jim at the Metric Mechanic. He thinks otherwise!
