Page 2 of 4
Re: A turbo is born in Nebraska! e23 content
Posted: Sep 22, 2014 9:27 AM
by Nebraska_e28
Hit Man X wrote:Glad I can be of assistance on resurrecting another 745i :lol:
Much appreciated!
1st 5er wrote:2 weeks.
Can't wait to see this beast in action.
This should prove interesting. I'll try now to blow it up on the first time out.
SteveCO wrote:Sweet car man
Thanks Sir! Hope to see you at 4corners sometime!
Hffvdbl wrote:Nice work!
Thank you! Can't wait to see your work of art at TexFest!
Posted: Sep 23, 2014 9:36 PM
I hear I-10 west of Kerrville is an interesting stretch of road.
Posted: Sep 24, 2014 9:15 AM
by Nebraska_e28
Last night I accomplished absolutely nothing! :evil: Texas or bust right? :roll: :(
I'm dealing with an idler arm debacle. See my thread in GC.
Posted: Sep 29, 2014 10:52 AM
by Nebraska_e28
Small update.
Got R&D green springs from Todd installed along with Bilsteins. Alignment was knocked out Saturday night, thanks Mike!. Last night Troy assisted in diagnosing a bad master cylinder & bleeding of the brakes, thanks to him too!
Things are rolling along nicely, but still a ways to go. :shock:
Posted: Sep 29, 2014 9:48 PM
by Nebraska_e28
Shit just got real! :shock:
Posted: Sep 30, 2014 12:51 AM
Somebody ain't playin'. :laugh:
Posted: Sep 30, 2014 12:55 AM
by Nebraska_e28
1st 5er wrote:Somebody ain't playin'. :laugh:
It's gonna be a long friggin night my friend.... Just started welding and have a long ways to go.
Posted: Sep 30, 2014 12:57 AM
:beer:
Posted: Sep 30, 2014 10:51 PM
by Pavel
Is that your ride, LJ? I have 100% confidence I will see it Friday night!
Posted: Oct 01, 2014 1:21 AM
by Nebraska_e28
Pavel wrote:Is that your ride, LJ? I have 100% confidence I will see it Friday night!
Yessir that'd be my hunk-o-junk. Friday can't come soon enough. My appearance will be proof I made it. Even if arriving on flatbed, skateboard, or other means.
\Small update.
So last night sucked ballz! I completed building my very own CUSTOM adjustable subframe. My hope is to dial out almost all negative camber in the rear end for extended tire life. While it was out I also poly filled the subframe bushings. They were already in tact but I figured a little insurance couldnt hurt in case this ride ever has a new purpose. Attached to the SF is a little something that should pep things up a bit. Blanton 4.10 rear diff courtesy of Todd. Highway gas mileage should be interesting but fun!
My trailing arms are at the machine shop getting new bushings pressed in. They were unable to press the old ones out & will have to be cut out. :x This set me back a bit today as I was hoping to have them installed & the car aligned. I'll revisit that tomorrow. Also, it's been raining ALL DAMNED DAY here! Not very conducive for driveway mechanics. :evil: :evil: :evil:
Tomorrow is a new day & I have a ton to accomplish before hitting the road Thursday morning at 0500. :shock:
Posted: Oct 01, 2014 8:41 AM
We are a people of great faith. :up: :up:
Posted: Oct 01, 2014 2:59 PM
by Greg E34
WOW!
Can't wait to see this bad boy Friday!
Safe travels LJ!
Posted: Oct 01, 2014 9:12 PM
by T_C_D
Good luck LJ!
Posted: Oct 02, 2014 4:12 AM
by Nebraska_e28
Thanks guys!
Adjustable subframe install successful! The 4.10 rear end really wakes things up too!
Posted: Oct 02, 2014 8:38 PM
Welcome back. ;)
Posted: Oct 07, 2014 2:38 AM
by Nebraska_e28
After the trek to TexFest, I ran the math to see how many miles this beast covered. During the course of Thursday - Monday I covered no less than 2000 miles at varying speeds and conditions. :shock: :cool:
Posted: Nov 13, 2014 9:13 PM
by SicStang03
Awesome Progress! I'm interested in what exactly you did to the rear end. I tried to get the KMAC rear caster/camber kit to fit on my car but it only works with early e23 rear subframe :(
Posted: Nov 30, 2014 3:07 PM
by Nebraska_e28
SicStang03 wrote:Awesome Progress! I'm interested in what exactly you did to the rear end. I tried to get the KMAC rear caster/camber kit to fit on my car but it only works with early e23 rear subframe :(
I removed the entire subframe & polyfilled the existing subframe mounts in addition to welding on adjustable camber/caster tabs below. When mocking them up prior to welding, I set them to dial out as much camber as possible & the ability to put in just a tad bit if needed.
Posted: Nov 30, 2014 3:22 PM
by Nebraska_e28
Posted: Jan 01, 2015 5:17 PM
by Nebraska_e28
TexFest was a blast! My cobbled together e23 made it down there & took the abuse I dished out with no issues. About a month after I returned home, the tranny started slipping. :oops: I suspect there was some fluid passing the input shaft seals & my abuse expedited things. Soooo... Time for a 5speed swap! NOT! The stall tq converter & 4.10 gearing was a perfect combo for shenanigans. I plan on keeping this setup but changing to different gearing more suited to x-country driving when needed. As for the tranny? Well time to test my skills again more or less... Now I could've/shouldve went the easy route & just replaced the A clutches but I figured I'd go all out. I also disassembled the valvebody for cleaning & updating to correct a bit of erratic downshifting out of OD.
This was all performed using the links below as a guide & heavy advise from Hit Man X. Note, all pictures are not in order. I'm still waiting on a few items before I can install & test out my handy work. :roll:
http://twrite.org/shogunnew/fixes/clutc ... x_Overhaul_
http://twrite.org/shogunnew/files/jason ... ebody.html
http://twrite.org/shogunnew/fixes/clutc ... ch_rebuild
The last 2 pics in this series are of a s2.79 pulled from an e30 that I'm going to test out on the next long haul road trip. :rofl:
Back in the air again!
The golden egg! 3k TCD tq converter
Toasted A clutches!
Shoebox to keep track of where all the damned screws go. :evil:
Updated style pump plate vs early unit. Note updated model has a check valve.
Clutch piston for the A pack drum. This is where they recommend drilling the relief hole
New stator shaft (which I ended up not using) & Moosehead knife.
New kevlar clutches installed!
Posted: Jan 01, 2015 5:35 PM
by M. Holtmeier
Outstanding! You got me with the 5 speed swap!
Posted: Jan 01, 2015 6:24 PM
by tig
Jeebus!
Posted: Jan 01, 2015 10:32 PM
by nerd of nerds
Damn! I like what I see every time I visit this thread.
Those Alfa seats are mega-rad.
Posted: Jan 27, 2015 8:50 AM
by Nebraska_e28
Daddy's got a new groove! :pimp:
I wanted the rear of the car just a tad higher due to the 255/40 r17 tires & for aesthetics.
Posted: Jan 28, 2015 12:14 PM
by Coldswede
I suspect it might have been cheaper to just buy new Sports. No?
Hope it works for you.
Posted: Jan 28, 2015 1:36 PM
by Nebraska_e28
Coldswede wrote:I suspect it might have been cheaper to just buy new Sports. No?
Good question. It seems sports are NLA. I already had HD that came with the car. $60 for 6 grooves cut. Added 2 more for another 20 just in case.
Car is sitting about perfect for my taste now.
Posted: Feb 28, 2015 11:06 AM
by Nebraska_e28
Installed a s2.79 diff last weekend. Might be safe to safe this 7 now has some of the longest legs of any m30 around. :rofl:
A few rough #'s
1750rpm = 60mph
2600rpm = 100mph
Posted: Mar 12, 2015 9:41 PM
by Shadow
waaaaait... bmw auto and it didn't explode?
Posted: Mar 13, 2015 4:44 PM
by Nebraska_e28
Shadow wrote:waaaaait... bmw auto and it didn't explode?
I liked the other thought better about breaking em loose 100mph in 3rd :rofl:
Tranny no go pop pop yet. I have yet to really pound on it. Thus far everything has been less than top speed runs on extended stretches.
Posted: Mar 13, 2015 7:07 PM
by Shadow
Ya I thought you had a 5spd then I looked back on the thread. :shock:
The long gears are worth it. 2nd gear goes over 70.
I notice some jap cars are going through the gears quick and I'm just sipping coffee and shit.
