New to me 524TD
Galahad
Re: New to me 524TD
Post by Galahad »
It sounds like this'll be an adventure at least, good luck.
Also, your photos are effective at showing what you want which will certainly be helpful.
SherlockCholms10 wrote: Mar 28, 2022 11:29 AM Pictures posted, but both of these developments are very strange indeed. I've got a bead lined up on the special injector, and I've heard these are near unobtainable, but I'm not at all sure how to proceed with the injection pump. It seems that one of the previous owners may have made a "field expedient modification" to the wiring harness, and I'm not sure what was trying to be accomplished by this.
This is definitely not stock - very odd. I would have expected the original connector to still be there.
gadget73
Re: New to me 524TD
Post by gadget73 »
The unplugged switch on the throttle linkage is the throttle closed switch for the EGR system.
No lift sensor on #4 and no electronic stuff on the pump makes me think someone converted it. The advance thing on the mechanical pumps is just for cold starts. It will work without it, but cold starts might be rough. I notice your cold start high idle thing is missing some parts from earlier pics. Should be a thumb wheel on the cable that contacts the throttle lever to pull it open a bit when cold.
honestly if you don't have the computer controlled pump, the special injector isn't needed. That pump looks mighty shiny, like its been worked on in the not distant past.
also the oil sep has no drain tube on it, but thats easy.
Not sure whats going on with the vampire splice things but that looks like the over-boost pressure switch connector. Should plug into the bottom of the blow off valve on the bottom of the intake plenum. BMW did something kind of dumb with this one IMO. If it over-boosts, your oil pressure light comes on. I suppose the idea is to inspire panic and a throttle lift? Maybe someone was trying to have it operate a dedicated over-boost lamp instead. I'd ditch the splices and paint over the damaged insulation with some liquid electrical tape. I absolutely hate those things.
SherlockCholms10
Re: New to me 524TD
Post by SherlockCholms10 »
Blowoff valve connector, that’s very interesting. I wouldn’t even have thought there would be a connector for that. 2
The compression on these engines is relatively high, so I guess I can understand why it’s factory limit is 13psi, but that is a ridiculously low number for a diesel. I will take a look at that tomorrow. I will also look for some more pieces of the injector pump - you are correct that it looks relatively clean. It was spray painted silver, and the engine is a full bronze. The injectors are like full on gold. Very strange and already beginning to flake off. The used vacuum pump arrived today, when the valve cover comes off for installation I will likely take a wire brush to it.
I spend a decent amount of time working on the car today and make some progress. The turn signal connector was located underneath the clutch/brake pedal bracket. The prior owner (PO) must’ve just slapped it in there without paying much attention. There are still several connectors without a home, I’ll post a picture of that tomorrow. My suspicion is that they belong to the now removed automatic, and it’s control box. Are there any connections or junctions that need to be modified now that it’s becoming a manual car? If not, then I think it’s time to begin working on the transmission installation, but still waiting on many parts for that.
Galahad
Re: New to me 524TD
Post by Galahad »
The boost limit may have more to do with the efficiency curve of the turbo and the lack of an intercooler. I haven't looked into it at all; I'm sure there's other people that would have more informed thoughts.
There's no electronic control on the td transmissions. There is an auto-only connector (9 pins, 3x3, potentially with a 1 pin pigtail next to it) that's used for the gear selector, it'll be near the window switches. You need to short two pins together to convince the starter relay you're in park or neutral - I stuffed a washer in the plug in my swap car at least for right now. Use the ETM to figure out wire colors; I think you need to short either of two brown wires to the black one, but I did all that almost a year ago. You'll also need to hack the reverse light switch into the reverse line of the same connector, the car won't care that you're telling it you're in park and reverse at the same time. The only other wiring difference between auto and manual that I can think of is the clutch switch which is used to turn off cruise control when you shift - don't be an idiot and you're fine leaving it alone.
gadget73
Re: New to me 524TD
Post by gadget73 »
The connector is just for an over-pressure switch. Whenever boost exceeds some value, I think right about 1 bar / 15 psi it closes and the lamp comes on when the valve opens. Its not electronically controlled or anything like that.
And yeah the low pressure is partly the lack of intercooler, and probably partly durability. At relatively low boost the engine isn't under a lot of stress. Its also not that fantastically low considering the era either. I think the Mercedes diesels of the time were around 8 psi.
SherlockCholms10
Re: New to me 524TD
More forward progress made today. The clutch reinforcement plate was received and installed. Another issue from the PO found and corrected, the clutch master cylinder was installed on the wrong side of the pedal bracket. I discovered this after installing the plate, and pressing the pedal to the floor. There was a crunch sound and it appeared the rod had bent. After I took the linkage apart and moved it to the other side of the pedal bracket, it cycles smoothly now. Hopefully nothing internally broke, guess I'll find out once I finally get the transmission installed and start bleeding the system.
I spent some time looking at the injection pump and comparing it to the breakdown on realoem. You are correct, I am missing some pieces, the thumbwheel being among them. Interestingly enough some of that assembly is present. I will start looking for parts and try to get that resolved. In staring at the pump with a flashlight, I noticed two brown wires hanging down towards the engine oil pan. When I first saw these wires, I had assumed they were for the oil level indicator sensor in the oil pan, but I am now fairly certain they are the two missing wires that link the R118 injection pump to the ECU. Perhaps I need to follow up on the special #4 injector. I'll get a picture of the connector this afternoon, but in the meantime I found a picture I took a few days ago that shows these two wires on the left side of the picture next to where the oil dipstick mounts to the block:
Vacuum pump came in, I've just got to find or purchase the mounting hardware to get that wrapped up, then I can continue addressing the wiring nightmare in the engine bay. Some other things that need to be addressed are to find the bracket that mounts on the end of the starter, get the starter tested, and continue trying to figure out what else is missing. Accelerator pedal bushings are beyond gone, I'll get some delrin ones placed on order. . . its all the small stuff, but there is one huge glaring issue that I need to address: The flywheel and clutch.
Yesterday, I took the only flywheel that came with the car (that looked like it would fit correctly) to the machine shop. I was asking for 3 things: (1) clean the metal up using soda blasting or some other type of non-abrasive media. (2) use the factory flexplate as a template to drill holes and transfer the 6 tachometer pins into the new flex plate (3) skim the clutch contact surface to clean it up as best they are able.
I was very surprised that they refused all 3 requests. I was told this is a dual mass flywheel (which I knew it was prior to my visit), but consequently it is a scrap item and cannot be surfaced or blasted. There is a fabrication machine shop at the other end of town that I will be visiting today, to see if they will entertain my request. My thoughts are drilling and reaming some blind holes using a template are among the most basic of machinist tasks, and one I would most certainly do myself if I had access to a large enough drill press or vertical mill.
If I am unable to have this flywheel modified, I am back to this journeys origin regarding the clutch/transmission installation. I've inquired at the usual sources regarding the factory 524td flywheel, but it seems to be out of stock everywhere. The other option is to order the Valeo single mass flywheel kit from ECStuning, but I would need to find someone to drill and ream the blind holes for the 6 pins. Does anyone have any recommendations?
Galahad
Re: New to me 524TD
Post by Galahad »
I have a RHD engineering flywheel on my swap car - it's pretty light but costs significantly less than the Valeo kit. I'd contact them and see if the m20 flywheel would work on the diesel, it mentions DMF conversions on the page. They were pretty quick about replying to my questions.
SherlockCholms10
Re: New to me 524TD
I took a look at their website, looks interesting, but I'm not sure if there would be enough room to mount those 6 pins. That is the long pole in the tent as of now, and while it might be minor to some people, having a dead tachometer constantly staring me in the face is not an option for me.
Good news is that even though most companies here in the U.S. say they are "out of stock" I found 40 sitting in a warehouse in Germany. So I may just go that route, and add a Sachs 618 sport pressure plate for the E30. This would probably be the best "fix it once and be done with it" solution, but I'm not sure I want to lay out $700 to get it done.
Fabrication shop was closed today, so I'll have to give that another try tomorrow. If that's not an option, then I'll likely be going the OEM route instead of the Valair one.
Spent some time looking at the injection pump parts breakdown. Unfortunately many of the parts I need simply aren't available from BMW anymore. Anyone have a good vender for parts on the VP-20?
gadget73
Re: New to me 524TD
Post by gadget73 »
don't specifically but if you know people into 12v Cummins engines, the early ones ran the VE pump. Same thing, just no electronic controls. I think they call the advance part the "ksb solenoid".
SherlockCholms10
Re: New to me 524TD
Finished sorting through the boxes of parts that came with the car today. Found the clutch hard line! Also found what l believe is the rest of the cold start assembly. I just need to figure out how to install it. There doesn't appear to be a readily available spot for it to bolt on.
I also found the support bracket for the back of the starter. So I need to get the starter thats not frozen with corrosion over to the Napa to get it tested. If someone knows of a good electric shop that will rebuild the starter and alternator I will just send them out, please send me your recommendations.
Regarding the flywheel issue, I think I am leaning towards ordering the Factory Euro one. I think this is the only way I would have the timing pin hole in the correct location, thoughts?
Galahad
Re: New to me 524TD
Post by Galahad »
I'm a bit confused about the flywheel: why do you think it has 6 pins? On the gas cars it only has 3 (like in the photo of the DMF you posted). It's possible the diesels are different - I don't know either way.
SherlockCholms10
Re: New to me 524TD
Yes from what I understand in the gas cars there are 2 sensors in the bell housing that derive that information. On the diesel, there are 3 pins on one side that mate to the pressure plate, but on the other side - the one that faces the engine - there are 6 small pins that protrude about .250”. If you scroll up you will see a picture of my dual mass flywheel with the flex plate in the background. While the side that is up is the rear side you can see the base of 3 of the pins. I’ll get you a photo of the other side so you can see what I’m talking about.
https://www.r3vlimited.com/board/forum/ ... p-underway
Galahad
Re: New to me 524TD
Post by Galahad »
Oh ok it's a diesel specific thing. That'll make my swap plans harder, thanks for the heads up!
gadget73
Re: New to me 524TD
Post by gadget73 »
yep, thats the high idle stuff. Those were removed on mine too, but I found it in the trunk. The fuel had been cranked up enough on the pump that the high idle wouldn't let the throttle close enough to get a reasonable idle rpm. One of the multiple things I fixed.
I'll see if I can get some pics of where mine is mounted.
SherlockCholms10
Re: New to me 524TD
Any luck on those pictures?
gadget73
Re: New to me 524TD
Post by gadget73 »
Forgot I can't actually post pictures on here. I don't have an image hosting account anywhere and this software doesn't allow for uploads.
Galahad
Re: New to me 524TD
Post by Galahad »
gadget73 wrote: Apr 04, 2022 3:00 PM Forgot I can't actually post pictures on here. I don't have an image hosting account anywhere and this software doesn't allow for uploads.
If you email me the photos I can post them to this thread
gadget73
Re: New to me 524TD
Post by gadget73 »
see if this will show you what you need
http://gadget73.com/images/84_Continent ... on%20pump/
those are from when I had the pump out on the bench just before it went out for rebuild
didn't have my login info handy earlier to dump it in the folder. Nothing actually on that domain besides random pictures that I needed to put somewhere.
SherlockCholms10
Re: New to me 524TD
Thank you very kindly for the pictures! That does help me, and I continue to sort out issues. Unfortunately this project has just become substantially more complicated as it seems that I am in need of a camshaft. I'll be uploading pictures shortly. From what I've seen doing a review of old posts on this forum, it seems that the camshaft on this engine is a common wear item. From what little I know about metallurgy, I would imagine that these cams are ground at the factory and then surface hardened - as soon as that surface hardening wears through metal comes off at a rapid pace. I guess I can say for certain that this engine was not "freshly rebuilt" as the seller had originally stated. Oh well. Good news is that I was able to turn the engine over using a ratchet and there is no binding. I can feel and hear the engine building compression. So off to the usual parts vendors, looks like I'm going to need a camshaft and a set of rocker arms, I didn't measure but the tolerance is .005, and it is well beyond that on several lobes. $OUCHH$
gadget73
Re: New to me 524TD
Post by gadget73 »
Pull that oil sprayer pipe off and have a look at it. Just a theory but I suspect you'll find the holes are at least partly blocked above the worn lobes. Not that it will do anything to reverse the wear, but it may prevent the next one from failing.
SherlockCholms10
Re: New to me 524TD
That's a good point. Likely the engine will still run even in this state, but the question really is how will it run like this? I'm actively looking for a serviceable replacement cam and rocker set . . . but if I end up ordering a brand new cam and rocker set then I'm sure I'll be replacing the spray bar. Since nearly every lobe displays significant wear, I think the issue wasn't with the spray bar assembly but rather neglectful maintenance and valve clearance adjustment. A historical search here on the forum shows many owners have had similar issues with cam wear. It makes me strongly considering running a ZDDP additive. . . I'm currently running AR9100 in my pickup truck, I'm waiting for another 2 oil change intervals to decide for myself if it is actually helping to reduce wear metals (which I determine through oil analysis).
gadget73
Re: New to me 524TD
Post by gadget73 »
Not sure you need to replace the spray bar, just clean it. Its a steel tube with some pinholes in it. Nothing some solvent and a torch tip cleaner can't put to rights. I wouldn't trust a used one to not need the same treatment. In the meantime, may as well do what you can to try to prolong the worn out cam a bit.
Problem with it being just a tube with pinholes it wouldn't take much sludge to plug them if the oil changes aren't kept up on. The turbo bearings would also not be happy about sludgey oil. Might want to check that for excess slop. These are just sleeve bearings.
SherlockCholms10
Re: New to me 524TD
Yes, the turbo journals are also in need of replacement. There is significant side to side play. I suppose since this engine is going to be down for awhile, I'll go ahead and get that pulled off and take a look at the internals. Spinning the turbo over by hand it doesn't feel like there is any contact between the wheels and one of the housings, but that doesn't mean that it hasn't happened in the past.
I agree completely with what you are saying, all of these are symptomatic of running oil longer than it should have been. Could have been substandard oil, or even a quality oil that was ran too long (short tripping). Good news is that it still spins over easily by hand, and both the turbo and the cam are the two areas that would show lubrication related failure the soonest. Its raining here over the next few days, but I should be able to pull the turbo off on Friday. I'll let you know what I find.
I've got a bead on a running engine a decent haul from here. That is looking like a better option all the time.
SherlockCholms10
Re: New to me 524TD
Pulled the rocker arms off, 6 of them show what I would call normal wear, the other 6 show what I would call abnormal wear. I'll get pictures posted this evening. The cam & rocker arms are going to be making the trip to Delta Cam in Tacoma, WA for a stock regrind. Quote was $80 to regrind cam, $4 per rocker arm. I suspect that some of the rockers aren't going to be salvageable, but the worst one had a divot worn about .020 deep. While reducing the base circle isn't ideal I'm not going to lose anymore than a few thousandths. I don't expect to exceed the capabilities of the stock cam with this engine, and ~150 is much better than the $1K plus that it would run for new parts from BMW. Anyone know if the rocker arms are made from chilled iron?
It would seem that this was caused by lack of valve lash adjustment, combined with running oil longer than it should have been. Once this all goes back together I'll be sure to use oil analysis and monitor the wear here. I'm still waiting on parts from Europe, as well as tracking down the front 1/2 of a driveshaft. Interior is already ripped apart, I'm contemplating taking apart the blower motors and heater core/evaporator coil assemblies and resealing everything with new foam. Looks pretty intense.
I've found this forum to be very useful with posts running back over 15 years. I'll pay it forward a little for the next guy; Ford used the same engine and parts are available using their part numbering system. Rocker arms are E45Y-6564-A. Camshaft is E45Y-6250-A. I was able to pickup a complete set of 12 NOS rocker arms for $150. This was nearly $500 cheaper than the discounted BMW dealerships. Unfortunately no camshafts are available via this route.
gadget73
Re: New to me 524TD
Post by gadget73 »
I tend to shop the Ford parts, partly because its what I have, but mostly because of pricing. There weren't all that many diesel Lincolns made in the first place, and the survival rate has to be quite low. The most common response I get with mine is "I didn't even know they made that".
80 bucks to fix the cam is a whole lot cheaper than I'd have expected it to be. I just wonder if its going to end up changing the clearances enough to exceed the ability of the rockers to be adjusted. Not sure if they exist for this, but ages ago I had an air cooled VW with that problem, and the solution was a thing called a lash cap. Basically it looked like a small metal cup that sat on the valve stem to make it a bit longer so it would work.
Re: New to me 524TD
gadget73 wrote: Apr 19, 2022 8:28 AM ... Not sure if they exist for this, but ages ago I had an air cooled VW with that problem, and the solution was a thing called a lash cap. Basically it looked like a small metal cup that sat on the valve stem to make it a bit longer so it would work.
Reminds me of the 302'd '91 Bronco we had many years ago that collapsed a lifter. I pulled the valve cover, rocker, and the affected push rod. Inserted a GM 350 push rod, reassembled everything and proceeded on down the road for several more years.
gadget73
Re: New to me 524TD
Post by gadget73 »
There is a right fix, and a right now fix. Sometimes things are only worth so much effort. If it worked for years like that, I can't exactly say it wasn't right enough.
SherlockCholms10
Re: New to me 524TD
SherlockCholms10 wrote: Apr 06, 2022 8:30 AM I've got a bead on a running engine a decent haul from here. That is looking like a better option all the time.
I've decided that due to the extended unknowns with the engine installed, I've taken a 90* turn and we are now headed on an entirely different route.
SherlockCholms10
Re: New to me 524TD
"Euro spec" M21 flywheel arrived today!! I'll get some pictures up this afternoon. It's all starting to come together now.
Re: New to me 524TD
SherlockCholms10 wrote: May 09, 2022 11:26 AM ... It's all starting to come together now.
:clap:
