Page 116 of 178
Posted: Feb 17, 2014 3:29 PM
by EvanJacob
Lubed squeaks in the steering wheel, gas pedal and brake pedal. Loosened up the door lock. Fixed the cruise control.
Posted: Feb 17, 2014 3:52 PM
by Das_Prachtstrasse
Oil change. Went with liquimoly 20W50 mineral race oil mos2, will be interesting to see how it holds up. It's already quietened it down a noticeable amount, but I'm yet to have driven it as I need another litre to top it since draining the oil cooler. With consumption of zero in 10,000 ks with the previous oil, it'll be interesting to see how the moly performs.
Posted: Feb 17, 2014 4:10 PM
by carnutdallas
Sooooo close to painting. Hopefully I will add some spray pictures Tuesday hopefully...
Posted: Feb 17, 2014 8:58 PM
by djazz
Das_Prachtstraße wrote:Oil change. Went with liquimoly 20W50 mineral race oil mos2, will be interesting to see how it holds up. It's already quietened it down a noticeable amount, but I'm yet to have driven it as I need another litre to top it since draining the oil cooler. With consumption of zero in 10,000 ks with the previous oil, it'll be interesting to see how the moly performs.
I use the GT1 10w60 in the M5 and had a noticable reduction in oil consumption in the S62. Good stuff.
Reference Sensors
Posted: Feb 28, 2014 9:10 PM
by revse28
I changed the reference and speed sensors so she would start! 1986 535i auto
Posted: Feb 28, 2014 10:52 PM
by LarryM
I pulled the alternator to replace the rubber bushings with some poly ones, like I did on my 6er some years ago...and then discovered the E28's alternator doesn't HAVE any bushings.
The mounting bolts pass directly through the alternator body. Evidently this was an engineering change made sometime between the 1985 and 1987 model years.
Oh well; I changed the voltage regulator (which I knew it needed anyway) and put it back together.
Posted: Mar 01, 2014 1:06 AM
You must have an '87 build '87. They went to the solid mount alternators which work pretty well.
Posted: Mar 01, 2014 3:48 PM
by LarryM
wkohler wrote:You must have an '87 build '87. They went to the solid mount alternators which work pretty well.
Build date was 9/86. I think they were making a lot of changes about that time.
Posted: Mar 10, 2014 7:40 PM
by DanOKC
I drove it to work, but yesterday I changed it's oil & filter with
Valvoline Racing 20/50 & Filter from the Stealer.
Posted: Mar 10, 2014 11:16 PM
by Karl Grau
I got enough done at the new place Sunday to move it from the side yard to the garage.
It's so filthy that I feel guilty moving it without a bath though.
Posted: Mar 11, 2014 11:40 AM
I miss Snob.
Posted: Mar 11, 2014 3:05 PM
by dsmith
1st 5er wrote:I miss Snob.
I missed you missing Snob?
It was finally above freezing yesterday, so I cracked open the garage door to see what mine still looked like.
Posted: Mar 15, 2014 11:06 PM
by lilpoindexter
Posted: Mar 16, 2014 2:03 AM
by djazz
lol S-I-L still have it?
Posted: Mar 16, 2014 3:50 PM
by louielouie
Amsoil 15w-40 diesel formula w/lots of zinc & back to the E34 525/530/535 brakes w/ Mintex pads for the street.
Posted: Mar 16, 2014 6:39 PM
by rollcentre
Yesterday was new plugs and fresh injectors. Today was oil change.
What an incredible difference! Why did I wait so long to do my injectors?
Posted: Mar 17, 2014 10:39 PM
djazz wrote:1st 5er wrote:I miss Snob.
Yeah but I saw her Saturday when we stabbed the 350 back into his Tahoe.
Now for him to get the rest of that thing back together.
engine swap
Posted: Mar 20, 2014 12:11 PM
by revse28
I am prepping for putting 100k engine in place of 300k engine that had timing chain failure. Getting list of parts together. 1987 535is Hope to have ready for Vintage at Old Salem NC end of May.
Posted: Mar 22, 2014 11:47 PM
by EvanJacob
Found an operable dash vent at the yard today (I don't know why, but that was really exciting), replaced the front passenger door seal, replaced b pillar trim on the driver's side and put in a lit sunroof switch.
Posted: Mar 23, 2014 6:09 AM
by dsmith
I brought the M5 back to life after a hard winter slumber. It was dry out, so I moved it to the storage unit in prep for a new upcoming e28 project at the house. When I got back home there was a rather large spot of coolant on the driveway.
I can't wait to see what popped over the winter...
Posted: Mar 23, 2014 5:08 PM
Bought a set of tires.
Posted: Mar 23, 2014 10:23 PM
by geordi
skinned my pumpkin...
Posted: Mar 24, 2014 12:02 AM
by BENAllison
New Shoes for the 533i
Posted: Mar 28, 2014 10:23 PM
by DanOKC
Replaced the yellowed expansion tank, so when I do get around to showing pics of this 88 is, my dirty engine bay won't look so dirty with a new expansion tank.
next up: buy a freon leak detector & find the missing R12 I put in from last year
I bet it's up around the ozone layer.
Then I'll find the leak & fix that too.
Posted: Mar 29, 2014 1:34 AM
by rollcentre
Getting closer! Still need a few pieces.
Ivo stopped by Wednesday, met up with geordi (George) and huffvpdl (Gary)
Had a good time with those guys and took delivery of my euro front bumper. It is shadowlined, but diamontschwarz I believe.
Posted: Mar 29, 2014 9:51 AM
by geordi
rollcentre wrote:Getting closer! Still need a few pieces.
Great meeting Gary & you too! Your M5 is looking great!
Posted: Mar 29, 2014 4:56 PM
by Chimi-Changa
ZHP nob, painted the collar ring black:
Also, checking out using an analog clock instead of the OBC- what do you guys think?
Posted: Mar 29, 2014 5:26 PM
by Karl Grau
The day after St. Paddy's, we noticed a gas smell from the M5. It turned out to be fuel supply hose at the hose clamp on the injector rail. Today I removed it, trimmed off the damaged part of the hose and reattached everything. About 5 minutes later I remembered that I actually have the correct replacement hose (13 31 1 722 565) with the Hofmeister kink in it so I'll be doing it
again tomorrow.
m5
Posted: Mar 29, 2014 11:29 PM
by socalM5
i replaced the rear sub frame bushings. fixed a rattle coming from the exhaust heat shield and replaced a broken b pillar
Posted: Mar 31, 2014 12:33 AM
by mcskibadee1
I like that knob painted. I just got one for my e30 and that brushed aluminium just looks out of place.
