You don't need to remove the starter. The bolt is right behind the inboard starter bolt. Like Chris says, pivot the engine/trans down as far as you can, supported with a jack or something.
Then put together about 3 ft of extensions and a swivel and a couple of bungy cords around the trans to hold it. Push it up to the bolt area on top of the trans, then climb on top, reach down with your finger tips and jam the socket on the bolt head. Get back under, firm up the socket connection and remove the bolt.
Be ready for the heaviest damn trans you've tried to dead lift, when you put it back in. I don't think I would do it again on jackstands without a helper.
Finally got around to tidying up a final few things on my "to do" list.
Borrowed a lift and went to work.
Swapped diffs and, surprise, diff covers too. Removed the 3.73LSD for a 3.46LSD.
Added a RD strut brace
Also managed to install new front sway links, some more shadowline trim, oil/filter change and an overdue follow up inspection of all suspension bits and pieces installed over the past several months. That was a lot of nuts & bolts!
A good day away from the store!
Thanks to the info on this site, other sites, and in the Bentley manual, replacing all of this on my 1986 535i (11/85 prod. date) used up my past couple weekends:
Clutch disk
Pressure plate
Throw-out bearing
Rear engine seal
Pilot bearing
Transmission input shaft, output shaft, selector shaft seals
Transmission mounts
Clutch pivot pin
Driveshaft guibo
Driveshaft center support bearing
All shifter parts except the carrier and selector
Front suspension control arms
Thrust arms
Tie-rod end links
Front and rear anti sway bar end links
Front and rear anti swaybar mount bushings
Rear subframe bushings (Ireland green poly)
Rear trailing arm "dog bones"
Rear shocks (bilstein sport)
Differential mount
I ran out of money and will have to do the front struts in a month or two. The difference that all of this made is wonderful. The car is so much more enjoyable to drive. Thank you.
Clutch disk
Pressure plate
Throw-out bearing
Rear engine seal
Pilot bearing
Transmission mounts
Clutch pivot pin
Driveshaft guibo
Thrust arms
Tie-rod end links
Differential mount
Last week I got the cluster connectors straightened out for the cruise control and it worked fine for a couple days then stopped working yesterday so did a search and figured maybe the control module So today I said "what the Hay" , with all those wires in the column all scrunched up I'll just telescope it out all the way and see what happens,,,,,,,took it for a spin for petrol and sure enough CC works again.But the best part was when I extnded the column I got a plume of 74" CARRERA out of the dash Still smells the same.
A combination Barbecue Pit / Smoker on wheels. Officially it'll be the BBQar*.
*B(ar)-B-Q(c)ar aka Black on Black Qar.
There's a rebirth studio in action.1st 5er wrote:A combination Barbecue Pit / Smoker on wheels. Officially it'll be the BBQar*.
wkohler wrote:There's a rebirth studio in action.1st 5er wrote:A combination Barbecue Pit / Smoker on wheels. Officially it'll be the BBQar*.
That's funny right there.
I picked up a rear windscreen, from an is, with this car that had his decal on it.
I'll have to post a pic. Gonna be keeping it for its factor.
So i didnt do it all today but its been recently done;
New DME temp sensor
New charcoal canister
New canister hoses
New purge valve
Used thermovalve
New thermovalve vacuum hoses
New ICV hose
New Intake boot
New crankcase breather hose
New tires
New fuel filter
New fuel pump
Used right side headlight bucket
New belts
Replaced trans fluid
Replaced diff fluid
New DME temp sensor
New canister hoses
New purge valve
Used thermovalve
New ICV hose
New Intake boot
New tires
New fuel filter
New fuel pump
New belts
Replaced diff fluid
I got an April Wine cassette tape stuck in my radio.
It was stuck in rewind mode somehow. Turning the radio off did nothing, turning the car off did nothing. I finally had to pull the wires out of the back. It wasn't happy about that either. The anti theft beeper was going off
I just got that freaking thing working last Saturday after not having a radio for 4 months! Ugh.
