Your gonna need a lot more meat than that. I have 225 on the back that are DOT-R 100 TW and I can spin them with ease. You should have at least 200 more HP to the wheels than I.
Duke,
I don't intend to drive the car like a teenager on the street I have 245 drag radials with no treadwear rating on style 5s and my set of slicks for the track.
No kidding, you don't either. Not till it is tuned and up to the boost level you want. You really can't ever take any input can ya????
I am always open to intelligent input. Fact is this car car 450rwtq with the m30 and will have no more than 550 with this setup. The power delivery will be much smoother and manageable with the throttle. I suspect my experience with the e28 and power delivery is more relevant than your experience with the Tiger.
Therefore I am not likely to accept your statements as fact.
I put about ten miles on the car today. Still not ready for WOT but got a little more aggressive. I wasn't datalogging at the time but pushed a little bit on the Parkway in 2nd and 3rd gear. Power delivery is very linear. It just feels like a big powerful n/a motor. Drove it at 60+mph in 6th gear. No drivetrain issues. It's nice and smooth.
Bad weather the next two days but it gives me a chance to keep pushing through the small issues. I hope the PWM controller for the fan arrives this week.
Sorted out a few issues this morning and drove it some more. Cooling system seems to be working perfectly. 173F while cruising. Car is actually pretty quiet at the 725rpm idle. Creeped into the throttle heavier today and was spinning 2nd gear at part throttle but it's very cold today. Intake temps rose from 40F to 44F during one pull. Revved as high as 5600rpm and 7psi. I am all smiles. Tried to get a video from in the car but failed. Snow starting in a few hours.
5PM edit: boost leak somewhere - engine has enough heat cycles that it is time to spend an hour tightening everything.
Worked the car today and made more progress. I have an issue with the intake manifold and need to remove it tomorrow. I'll post pictures of the issue and fix tomorrow. Drove the car 15 miles today. Modified the timing and fuel maps and it made the engine very happy! Fan controller arrives tomorrow. Hopefully I get the car sorted tomorrow and get some videos on Sunday.
Removed the intake today to look for a boost leak. The bottom of the intake has a plate that bolts to and seals the plenum. It has a paper gasket. When I removed the intake two of the screws had backed out and the rest were loose. The gasket was fine so I reused it with some super duper sealant on both sides and blue locktite on the screws.
I also rerouted a heater hose and solved the last PS leak. I believe the car to be leak free!
I drove the car again and am getting real comfortable with it's reliability. As soon as the fan controller is installed it's ready to go anywhere.
I was heavier into throttle and got a little spin in 3rd (haha Duke). Videos tomorrow!
