Noob M30B35 Build
Re: Noob M30B35 Build. 2014-05-24: Engine is out!!!
I knew what you meant but figured I'd add clarification for cek and future reference.
cek wrote: Question: there's a little nipple. show this nipple.
Kyle in NO wrote:The nipple
cek wrote:Thanks Kyle. two small nipples. goes to the nipple. a nipple on each side. the large nipple. 2nd small nipple
Guys. Come on. Family-friendly site here. c;DJM1986-5 wrote:one small nipple. other small nipple. vacuum. beating the clock. I plugged the nipple
I think my flywheel is still at my machinist, who was to check its balance. At least that's what occurred to me at about 3am this morning.
Happy Father's day to all you dads.
I have figured out what each coolant hose is for. I think. I'm not as confident on which end goes where though, particularly for the smaller lines that go to the heater and heater control valve. I'm missing the tee (and I don't want to pull it off of Vlad's B34 because those hoses are relatively new and I'd like to leave them intact), so I can't hook everything up today as I had hoped.
Question: The B35 fuel rail has the fuel inlet facing the front of the engine. How is the fuel line supposed to be routed? Down through the middle space on the intake manifold and then back to the supply? Anyone have a pic of a B35 with this detail showing?
While you all work on answering my previous question, I'm sorting out how to mount my IE AFR.
The B34 intake manifold has some mount points that were sorta convenient. The B35 doesn't.
I'm considering getting rid of the hose between the AFR and the fuel-rail mounty thing and finding some brass fittings that would allow me to just mount it directly. One less hose with clamps to deal with and should be low enough to clear the hood. Good idea? Bad idea?
Why do you need an adjustable FPR? You're going to run a WAR chip, right?
Maybe. But initially I'm running the stock 179 ECU and AFM. Since this is a high-comp engine with 24lb injectors, Paul Burke recommended that I have an AFPR, at least initially. I also have a wide band gauge (actually two).wkohler wrote:Why do you need an adjustable FPR? You're going to run a WAR chip, right?
Okay. I've got a friend that had three of those fail before he ditched them and got the war chip, 24# injectors, a stock regulator and a dyno tune. He said the tuning was best money he had spent on the car.
Motor looks great, btw.
As soon as I have it broken in, I'm taking it in for a dyno tune and will likely got with a War chip at that point.wkohler wrote:Okay. I've got a friend that had three of those fail before he ditched them and got the war chip, 24# injectors, a stock regulator and a dyno tune. He said the tuning was best money he had spent on the car.
I started with the 1/4" neoprene for sound deadening. It doesn't matter that it's not cut perfectly because the Thermo-tec will go over it
Turned out great!
I ended up doing more of the driver's side because....well why not?
The insulation on this fuel cooler thingy was shot. Since I have headers and they get super hot I felt it was worth while replacing the insulation. I started with some pipe insulation...
Then wrapped it in Thermo-tec; you can see it blurry on the left of this pic.
Now the subframe goes back on...
Turned out great!
Is there anything special or different that needs to be done when adjusting the valves on a brand new head? Just standard cold procedure?
I'm not certain that torquing the head down doesn't change things a bit, so I'd suggest the final adjustment after the head is bolted down tight. Other than that it's the same.cek wrote:Is there anything special or different that needs to be done when adjusting the valves on a brand new head? Just standard cold procedure?
I am pretty sure the head gasket comes with instructions on the torque procedures. It will usually includes a final torque after initial start-up and a heat cycle. Adjust the valves before the first start-up and then again after it cools down completely (overnight).
The second adjustment is not necessary IMO, and I've done a bunch.pldlnr wrote:I am pretty sure the head gasket comes with instructions on the torque procedures. It will usually includes a final torque after initial start-up and a heat cycle. Adjust the valves before the first start-up and then again after it cools down completely (overnight).
You are probably right, Mike. I tend to be a little extra cautious with things like this.Mike W. wrote:The second adjustment is not necessary IMO, and I've done a bunch.pldlnr wrote:I am pretty sure the head gasket comes with instructions on the torque procedures. It will usually includes a final torque after initial start-up and a heat cycle. Adjust the valves before the first start-up and then again after it cools down completely (overnight).
Thanks guys.
With the exception of a new CTS and block-off plugs for the t-stat housing, the valve adjustment completes the motor itself. Those parts should be here tomorrow.
My next wrench session will be to re-assemble the steering components. When that's done we'll roll the car into the driveway and drop the engine in and then roll it back onto the lift. I think I need to find a transmission jack for the next step...
I can smell the finish line!
Oh, just as I say that, I remember I haven't sorted the C101 connector for the wiring harness yet. I originally was going to do it with the harness separate from the engine, then I realized that I'd likely get the length of something wrong and have to re-do something after it was in the car.
So my plan is to sort out the harness after the engine is set in the car. This will really just be a matter of routing the relay wires from where they currently are near the ECU to where they should be at the fusebox. I am going wire the C101 pig-tail I have from my donor M30B34 directly to the new harness and not use an intermediate 20X connector. I'll wrap it all nice and purdy using F4 tape. It'll be a little tedious doing this while the engine's in the car, but I really want to make sure everything fits since I've never done this before. Maybe I'm just being paranoid and I should just do it while it's out of the car.
Other things I know I have to do:
- Connect cooling hoses and put radiator back in.
- Figure out how I'm going to mount the B35 coil.
- Attach headers. May do this before I drop engine in. I bought 35mm studs so it will be slightly easier to do than before either way.
- Figure out how to secure the B35 air filter housing. I may wait to do this and just use my newly powder coated B34 housing initially. I really do want the cleaner looking B35 housing in there in the end though.
- Drop in the new in-tank fuel pump.
- Install short-shift kit.
- Install lightened & balanced flywheel and new clutch.
- Install rebuilt driveshaft.
- Reinstall exhaust. (once the car is drivable I'm taking it into a shop and having the exhaust rebuilt)
- Fill fluids. Bleed brakes, PS, clutch.
- Remember to tighten steering column nut (I have a piece of tape on the dashboard where I wrote "don't forget steering nut!").
- Cross fingers and start it up. 20 minutes, then re-torque head bolts.
Correct.cek wrote:This is for a B35 O2 sensor, right?
Re: Noob M30B35 Build. 2014-06-21: Wiring harness fight!!!
The flywheel is 17lbs.
I spent almost all day fighting with the wiring harness. I realized that there were two ways I could do it: 1) Just blindly follow the FAQ and cut & splice quickly or 2) Make sure every wire was done correctly and that I understood what went where.
I'm glad I took my time because I've learned a ton. I still have some questions, but it's slowly going together.
Here's where I started. On the bottom right is the C101 pig-tail from the donor B34.
This is C103 by the glove box. The engine speed sensor (small black wire) in harness needs to go to pin 1. The White/Black wire from the harness goes to Pin 3. Pin 4 is from the AC switch and goes to pins 40/41 on the ECU (although I'm still verifying this is absolutely correct). To make this all work, I pulled a male C103 connector from my donor B34 harness and 'upgraded' it with a pin in slot 4.
I need to get a B35 O2 sensor plug. I won't need this while I'm running the wideband gauge, but after the rig is tuned, I'll want to go back to stock sensor.
On E32/E34 harnesses the relays are by the ECU, and there's nowhere to mount them securely in the glove box. So I need to re-route those connections to the other end of the harness by the C101. It turns out that the green/violet lines that go to 87 on the fuel pump relay can all be removed from the B35 harness, except the small one that goes through the part above the fuel rail and down to the O2 sensor connector. I re-routed it and spliced it in.
Things should go more quickly now that I've got everything decoded and my confidence in what goes where is up....
Fun stuff. Just a few wires left that I'm not quite sure about.
Butt connectors. Rule.
I don't have the nice hard plastic covers BMW used to cover their butt connectors, but seems like F4 tape does a nice job.
On the bottom right you can see the wires that I'm not sure what to do with. Some are fine, but...
- Green. Comes from 86 on main relay. OBC Relay Box. Seems important. ?!?!?
- Green/Blue. From O2 sensor heater relay. ?!?!?!
On the harness side, I have the black/white that comes from the ECU as "Speed Signal Input". Supposed to go to instrument cluster. But I don't think the E28 speedo has an output. So I think this remains unconnected!?!?
Fixedcek wrote: On e32/e34 harnesses the relays are by the ECU, and there's nowhere to mount them securely in the glove box.
