You are probably right, Mike. I tend to be a little extra cautious with things like this.Mike W. wrote:The second adjustment is not necessary IMO, and I've done a bunch.pldlnr wrote:I am pretty sure the head gasket comes with instructions on the torque procedures. It will usually includes a final torque after initial start-up and a heat cycle. Adjust the valves before the first start-up and then again after it cools down completely (overnight).
Noob M30B35 Build
Re: Noob M30B35 Build. 2014-05-24: Engine is out!!!
Thanks guys.
With the exception of a new CTS and block-off plugs for the t-stat housing, the valve adjustment completes the motor itself. Those parts should be here tomorrow.
My next wrench session will be to re-assemble the steering components. When that's done we'll roll the car into the driveway and drop the engine in and then roll it back onto the lift. I think I need to find a transmission jack for the next step...
I can smell the finish line!
Oh, just as I say that, I remember I haven't sorted the C101 connector for the wiring harness yet. I originally was going to do it with the harness separate from the engine, then I realized that I'd likely get the length of something wrong and have to re-do something after it was in the car.
So my plan is to sort out the harness after the engine is set in the car. This will really just be a matter of routing the relay wires from where they currently are near the ECU to where they should be at the fusebox. I am going wire the C101 pig-tail I have from my donor M30B34 directly to the new harness and not use an intermediate 20X connector. I'll wrap it all nice and purdy using F4 tape. It'll be a little tedious doing this while the engine's in the car, but I really want to make sure everything fits since I've never done this before. Maybe I'm just being paranoid and I should just do it while it's out of the car.
Other things I know I have to do:
- Connect cooling hoses and put radiator back in.
- Figure out how I'm going to mount the B35 coil.
- Attach headers. May do this before I drop engine in. I bought 35mm studs so it will be slightly easier to do than before either way.
- Figure out how to secure the B35 air filter housing. I may wait to do this and just use my newly powder coated B34 housing initially. I really do want the cleaner looking B35 housing in there in the end though.
- Drop in the new in-tank fuel pump.
- Install short-shift kit.
- Install lightened & balanced flywheel and new clutch.
- Install rebuilt driveshaft.
- Reinstall exhaust. (once the car is drivable I'm taking it into a shop and having the exhaust rebuilt)
- Fill fluids. Bleed brakes, PS, clutch.
- Remember to tighten steering column nut (I have a piece of tape on the dashboard where I wrote "don't forget steering nut!").
- Cross fingers and start it up. 20 minutes, then re-torque head bolts.
Correct.cek wrote:This is for a B35 O2 sensor, right?
Re: Noob M30B35 Build. 2014-06-21: Wiring harness fight!!!
The flywheel is 17lbs.
I spent almost all day fighting with the wiring harness. I realized that there were two ways I could do it: 1) Just blindly follow the FAQ and cut & splice quickly or 2) Make sure every wire was done correctly and that I understood what went where.
I'm glad I took my time because I've learned a ton. I still have some questions, but it's slowly going together.
Here's where I started. On the bottom right is the C101 pig-tail from the donor B34.
This is C103 by the glove box. The engine speed sensor (small black wire) in harness needs to go to pin 1. The White/Black wire from the harness goes to Pin 3. Pin 4 is from the AC switch and goes to pins 40/41 on the ECU (although I'm still verifying this is absolutely correct). To make this all work, I pulled a male C103 connector from my donor B34 harness and 'upgraded' it with a pin in slot 4.
I need to get a B35 O2 sensor plug. I won't need this while I'm running the wideband gauge, but after the rig is tuned, I'll want to go back to stock sensor.
On E32/E34 harnesses the relays are by the ECU, and there's nowhere to mount them securely in the glove box. So I need to re-route those connections to the other end of the harness by the C101. It turns out that the green/violet lines that go to 87 on the fuel pump relay can all be removed from the B35 harness, except the small one that goes through the part above the fuel rail and down to the O2 sensor connector. I re-routed it and spliced it in.
Things should go more quickly now that I've got everything decoded and my confidence in what goes where is up....
Fun stuff. Just a few wires left that I'm not quite sure about.
Butt connectors. Rule.
I don't have the nice hard plastic covers BMW used to cover their butt connectors, but seems like F4 tape does a nice job.
On the bottom right you can see the wires that I'm not sure what to do with. Some are fine, but...
- Green. Comes from 86 on main relay. OBC Relay Box. Seems important. ?!?!?
- Green/Blue. From O2 sensor heater relay. ?!?!?!
On the harness side, I have the black/white that comes from the ECU as "Speed Signal Input". Supposed to go to instrument cluster. But I don't think the E28 speedo has an output. So I think this remains unconnected!?!?
Fixedcek wrote: On e32/e34 harnesses the relays are by the ECU, and there's nowhere to mount them securely in the glove box.
Seems like it would be better to leave the relays so they can be in the glove box, only since there is less tampering on the harness and it is a nicer environment for electrical components. The M5 has two in the glove box near the ECU. I don't particularly remember how they mount and the M5 is surrounded by other cars so I can't open the doors.
Way too late for that.Justin_FL wrote:Seems like it would be better to leave the relays so they can be in the glove box, only since there is less tampering on the harness and it is a nicer environment for electrical components. The M5 has two in the glove box near the ECU. I don't particularly remember how they mount and the M5 is surrounded by other cars so I can't open the doors.
Fixed. Fixed.BuzzBomb wrote:Fixedcek wrote: On e32/e34 harnesses the relays are by the ECU, and there's nowhere to mount them securely in the glove box.
Re: Noob M30B35 Build. 2014-06-23: I beat the wiring harness
Well done. I think this is why most people drop the idea of having a clean install and stuff relays under carpet, etc. The Depot carries the cloth tape to wrap the harness with, which would give it a more factory look, but there are a lot of car restorers and shops that swoop in and buy it all since it's hard to find elsewhere.
I'm going to be using F4 tape to wrap it. I have a nice supply of cloth tape, but think the F4 tape will hold up better.BuzzBomb wrote:Well done. I think this is why most people drop the idea of having a clean install and stuff relays under carpet, etc. The Depot carries the cloth tape to wrap the harness with, which would give it a more factory look, but there are a lot of car restorers and shops that swoop in and buy it all since it's hard to find elsewhere.
It looks nice and shiny but... It looks like it was fly cut on a rotary table ? I didn't think that's how you should do a flywheel and the step for the PP is now gone. Won't that affect the pressure on the friction surface or are you using something different than stock PP and friction disc. Just curious.
It looks like the work you are doing is basically outstanding. We have tried to put that attention to detail in the e30 project my son and I have worked on but we skipped the engine for now and rarely find the time to work on it.
cek,
This thread is awesome. We never got a chance to get together last time when I needed to do my control arms, but I'm still just right up the road in Kirkland. If you ever need a second person or odd ball tool let me know. Feel free to pm and we can exchange phone #s. I may still have your email too if you prefer that way. God knows theres always work to be done on my car too lol.
Keep up the awesome posting!
-John
-John
Kirkland... Hmmm. My 105 yr old grandmother lives in Totem Lake and my aunt in Woodenville. Next time I'm out that way, probably September... and if you don't think it would be too strange of me to ask... IM me a phone number and I'll give you a call. Maybe I could stop by to have a look at the progress and talk BMW's. Always great to meet fellow board members and enthusiasts.
I too love this thread and have the same car teed up and ready. Will start next winter. This motivated me to go all the way with my new 535is
I have no freaking idea. This is the first flywheel I've actually ever touched or looked at up close. I bought it off a guy on the forum. From a previous post in this thread:tn535i wrote: It looks nice and shiny but... It looks like it was fly cut on a rotary table ? I didn't think that's how you should do a flywheel and the step for the PP is now gone. Won't that affect the pressure on the friction surface or are you using something different than stock PP and friction disc. Just curious.
A shameless asshole named Kyle said:cek wrote:Bought a flywheel from a guy on the forum here. It came while I was fishing last week.
It was billed as a "early 533/M5 variety". I'm not sure that's what it is, because although it weighs about 17lbs it has tabs on it, where all others I've seen are smooth all the way around.
Did I get mis-led?
For example, here's pictures from other theads showing a 533 flywheel. Looks totally different:
I've since had it balanced. I'm not sure what "step for PP" means.Kyle in NO wrote:I wouldn't touch that flywheel with a 10' pole. It's so incredibly butchered. How do you even know its still balanced properly? I would demand a refund if that junk showed up at my door.
Maybe I should source another one (or shave the one from Vlad's B34 down?)?
I actually am in Bellevue. Please do come visit when you are out here. Email me via the forum and we can exchange contact info.tn535i wrote:Kirkland... Hmmm. My 105 yr old grandmother lives in Totem Lake and my aunt in Woodenville. Next time I'm out that way, probably September... and if you don't think it would be too strange of me to ask... IM me a phone number and I'll give you a call. Maybe I could stop by to have a look at the progress and talk BMW's. Always great to meet fellow board members and enthusiasts.
For my untrained eye, that flywheel looks properly machined.
If you look at this picture above you'll see the friction surface is proud of the outer ring where the PP is bolted down. There is supposed to be a step there (1/2mm or so, maybe 1mm ?) I'm not sure of the spec but it does decrease the gap between the PP and the flywheel a little and part of the stack up.
I think your flywheel was put on a rotary table under a milling machine to make the cut outs in the OD between bolt locations to lighten it. This has removed a lot of the surface the PP would normally rest on. Is that a problem? IDK but I've seen PP that are not completely flat at the bolt locations but since the whole thing rests on a flat surface if it draws up a little around the bolt who cares. In this case maybe it results in some distortion of the PP so it's not nice and parrallel. But I really don't know if that could be a problem here or not.
In the process of doing what I think was done it may also mean the surface is no longer true to the backside where it mounts to the crank. Again I think because either before or after the cut outs it looks like they used a big fly cutter (think like a lawn mower) to just shave the surface down while they spun the thing around under the cutter with the cutter offset from the center. You should be able to see that. Run your fingernail across the surface and if you can feel it it's a no go. If it feels smooth then bolt it up on the crank and use an indicator to see if it's true when you spin it. Put inward pressure on the Flywheel to be sure it's up against the thrust bearing and rotate a little at a time. Spec might be 0.1mm or about .004" total run out IIRC but I would want it to be about 1/2 that or less. If it's not it's no longer true enough to use without turning it at which point you could put the step back in it and rebalance but still have those gaps.
To be on the page with Kyle it kinda scares me. The proper way to lighten is to put in a lathe and start hogging material out of the backside. Grind the friction surface smooth and also rebalance. This is how we lightened one we did. I'm lucky to have access to a lathe at work and honestly what's been done abbove looks like a lot more work.
I took the time out of most all of yesterdays work day to read this thread front to back (almost). I hit every page and learned a heck of a lot. It really makes me want to dive into rebuilding one of these just so it can look like your final product. The powder coating, plating, painting; everything looks superb, and I'm sure that OCD personality of yours loves every bit of it.
Keep the updates rolling. It for pretty intense when people were on your ass for wanting to drop the engine out the bottom. Glad that worked out well!
In for moar updates!
tn535i Makes good points as usual, and I thought that picture looked familiar. Anyway, I agree, it should be stepped, given how a diaphram pressure plate works it may or may not reduce clamping pressure, but it would diminish the effective life of the clutch by the 1 or 2MM of the step. I've also seen flywheels, as in the last one I had surfaced by a machinist I hold in high regard, flycut like this one, but then machined down to reestablish the step. I had no issues with it and was actually using a lighterweight E12/533 clutch in a 535 in order to try to limit pedal pressure in what was then my wife's car.
Given the fear, uncertainty, and doubt I now have about this flywheel, I'm probably going to source another flywheel (or lighten the one I have that's still attached to Vlad's old motor).
FWIW, here's how the PP sits on this flywheel:
I still am not quite sure what problem you guys are talking about.
Note that my machinist balanced this flywheel and said it was good to go.
I don't think it's a throwaway, it just needs a little more. Stock there is a step, the surface the friction disc rides on is 1-2MM higher than where the pressure plate ears mount. That provides additional preload. It could still be machined in after removing the locating dowels.
On weight it's odd if it's ~17 pounds. That is roughly the weight of a E12 flywheel, without additional machining. 535's are in the 22 range and 533s in the 14.5 area. Since you're going B35 you don't need the motronic tabs would tend to help ID it. Nothing wrong with an E12 flywheel as long as you're M1.1 or 3, not M1.0A.
Fixed.Mike W. wrote:Stock there is a step, the surface the friction disc rides on is 1-2MM Higher than where the pressure plate ears mount.
Correct you are, I misspoke. Corrected.BuzzBomb wrote:Fixed.Mike W. wrote:Stock there is a step, the surface the friction disc rides on is 1-2MM Higher than where the pressure plate ears mount.
