BMW E34 TOURING TRANSMISSION SWAP / RESTORATION
time to finish the front suspension
New center, center link, tie rod and lower control arm installed
Brake bust plated back in place
Mistakenly forgot to order new hobs for the e34, thought i did but the ones i ordered were for my e28 so i had to reuse the old one which were still in good shape but first
Engine marriage
Hi guys
figured i send you some updates. the engine is finally in the car but due to the fact that i am using the m3 tranny. I have been looking of a driveshaft from a pre 1992 525i manual with the big output shaft and smaller diameter differential bolts. I have a driveshaft from a 1995 manual but it wont work. Due to the smaller output shaft and larger diff bolts. but here are the pictures from the installation.
Re: Engine marriage
Just noticed this; I might be able to help you out if you can't find one closer to home. I parted out an '89 525i manual last year and still have a bunch of drivetrain bits in my shed. Shipping shouldn't be too big an issue... PM on its way.doyfola wrote:Hi guys
figured i send you some updates. the engine is finally in the car but due to the fact that i am using the m3 tranny. I have been looking of a driveshaft from a pre 1992 525i manual with the big output shaft and smaller diameter differential bolts. I have a driveshaft from a 1995 manual but it wont work. Due to the smaller output shaft and larger diff bolts...
Re: Engine marriage
Don't think that will work. He needs a driveshaft from an early (91-92) m50 5 speed car with a ZF310z.davintosh wrote:Just noticed this; I might be able to help you out if you can't find one closer to home. I parted out an '89 525i manual last year and still have a bunch of drivetrain bits in my shed. Shipping shouldn't be too big an issue... PM on its way.doyfola wrote:Hi guys
UPDATES
Hi Guys
I kow its been a while but between the car and work stressing me out a took a 3 week vacation to west Africa and U.K. Nothing like the home land to recharge your battery. Good news is i was able to put the car back togetter before i left.
few images from my trip
Sunrise over London
Saw this bad boy on a walk
Ask for cocanut in Lagos and this is what they do.
Final part of the project. Rear end replacement. The car was originally fitted with a 4.1 lsd. On my initial test drive i busted out the subframe bushing with the super agressive cluch. I was doing 40 mph on 5th gear at 4000 rpm, that wont cut it, replacement diff required. And so it begins
Rear bumper, exhust and driveshaft removed again.
subframe and diff dropped
I'll have to do something about this
Rear tire walls need some attention
Cleand and repainted rear tire walls
http://i1180.photobucket.com/albums/x41 ... 0019-1.jpg[/img]
http://i1180.photobucket.com/albums/x41 ... 0020-1.jpg[/img]
