Noob to M30's
Shadow
Post by Shadow »
I have a feeling this is going to uncork some power alittle. :shock:
That is all sorts of bad ass. I can't wait to see the next dyno plot.
jim325
Post by jim325 »
When will you be making those for b34 heads to sell? :alright:
If your not thinking of building some for resale, can you try to think of it?
clongo
Post by clongo »
jim325 wrote:When will you be making those for b34 heads to sell? :alright:
I would also be interested in one!
Shadow
Post by Shadow »
T_C_D wrote:That should be worth substantial HP where you want it! Great job.
This guy used a 666 mani just like that on a stock m20.
Looks like it has a cam or something. You know how high rpm power completely dies on these engines normally.
I wonder if the m30 is more restrictive then the m20 though.
Good & Tight
Post by Good & Tight »
Should be an improvement over a stock manifold, guess we will have to see. As far as making more of them, I would wait to see the results.
Had to reconfigure the thermostat housing to make it fit. Engine bay is filthy from sitting so long.
heinrich535i
Post by heinrich535i »
sig pic says it all, BOSS
Good & Tight
New BOV placement.
I like the Tial products in black. Which TB did you use?
Those short runner manifolds are something else. I always wanted to try one but never made the step.
Assuming that dyno is an M20B25 with the short runner manifold, its missing a lot of midrange. The stock manifold is good for that, but sometimes you get a little more peak cylinder pressure than it can handle. Mine was making 380 rwtq from 4000 past 5000 RPM, with peak power of 384 rwhp at around 6400. I don't know if the short runner manifold at the same boost pressure would have made the car faster or not.
Frybrid 524td
Post by Frybrid 524td »
Wow.
Good & Tight
Found this video of the track rental day.
http://www.youtube.com/watch?v=SzK79nnW ... r_embedded
Cool Otis. How did that video come about?
DangerWillRbnsn
Post by DangerWillRbnsn »
Good & Tight wrote:Found this video of the track rental day.
Cool, I used to race my Mustangs at that track before I moved out here to Vegas!
RED89E34
Post by RED89E34 »
This has been a fun read!
Good & Tight
Built Ford C4....
Meet M30 bellhousing.. :banana:
Courtesy of the badest mofo on the planet Paul Burke..!!!! :alright: Can't wait to get this badboy in there.
Holy Shit! It finally happened! :banana:
:shock: :shock: Instant salivation!
chocolatier
Post by chocolatier »
Shit just got real!
JesterMX6
Post by JesterMX6 »
beautiful
clongo
Post by clongo »
This is going to be awesome!!!!! :shock:
clongo wrote:This is going to be awesome!!!!! :shock:
Agreed.
M. Holtmeier
Post by M. Holtmeier »
Holy. Crap. :shock:
rundatrack
Post by rundatrack »
Good Shit Otis
Always great to see your improvements. Remember when I first saw you putting in work with that m10 and didn't do any real welding or anything. Now look at you.
Good show bro
G
I have only one question. 5 1/2+ years later, are you really still a noob? ;)
Looks great, Otis, I hope it performs to your expectations.
Good & Tight
Alright had a few hours to play today. Pulled out the old tranny and got the C4 under the car.
Old twin disc setup next to the torque converter. That pilot bearing puller tools works like a dream.
Reverse pattern shifter, awkward moment putting it in but it's needed.
Here it is strapped down to the tranny jack. Couldn't imagine installing the tranny without it.
Here's a side by side next to the 5 speed, the C4 is similar in weight.
Shadow
Post by Shadow »
What's the 1/4 mile goal ? :cool:
acho
Post by acho »
Nice job Otis! Let me know once its ready for a test drive.
M. Holtmeier
Would you consider selling the twin plate setup?
Good & Tight
Twin plate not for sale, yet. It's coming together....
Ok, trans is in, cooler mounted.
Picked up the drive shaft today.
Trans cooler mounted were gas tank was.
Rear diff flange adapter to spicer 1310 U joint.
Ended up going with a billet trans yoke that had removable caps in order to install the driveshaft easily. It also has the beefier 1350 Ujoint. Drive shaft custom made with .083 thick, 3" tubing.
It's getting there, in the process of fabbing up the transmission mount.....
