Noob to M30's
Good & Tight
Post by Good & Tight »
TheGraye28 wrote:Wow G&T, reading this whole thing is friggin awesome. I'm in the planning stages now and it seems to me the an HX40 would satisfy all my goals.
Quick Q, when you were running in the 4-450 HP range, this was on an B34 block with M90 head, correct? Do you have any idea what kind of compression ratio you were running? I know B35 is about 9.0 to 1, and I think I could make a tad more HP with less lag on a twin scroll manifold.
I previously had a HX40 powered 302 in a volvo 740... I find it hilarious that I could have made more power more reliably with this old boat anchor. :rofl:
Yes, still running the B34/M90 head, I would guess the compression is 8.1. I believe the M90 head is nothing but a B34 head.
Good & Tight
Finally mounted the goPro and went for a little test run. I have a few more vids to upload if you guys want to see them.
These runs were on 17-18psi.
http://www.youtube.com/watch?v=TLWO2MKP ... e=youtu.be
2nd to 3rd gear pull.
http://www.youtube.com/watch?v=dollmBsVWhg
TheGraye28
Post by TheGraye28 »
Awesome!! Sounds like you might be needing some more gear soon!
Good & Tight
TheGraye28 wrote:Awesome!! Sounds like you might be needing some more gear soon!
It's a 2.93, getting from point A to B happens fairly quick.
Mrkanda
Post by Mrkanda »
How streetable is that beast? How would such an engine perform in a loaded E34? I'm getting a '92 535i5 that I hope could be a refined yet potent street killer, maybe 350-450hp? Sounds like you're the man with the plan! ;-)
Good & Tight
Haven't updated in awhile.
Had some stock steelies widened to 10" wrapped with 275/50/15
Here's a quick little vid
http://youtu.be/5zYZFSmxtqk
It's full on redneck now!
Good & Tight
T_C_D wrote:It's full on redneck now!
YEEEEHAAWWWWW....!!!!!!!
bornagain
Re: Noob to M30's
Post by bornagain »
Correct me if im wrong but your tires are on the wrong side..... Either way, Otis, you are a driving force to keep me going at my e30m30, i finally got it back together with a new tranny after nuking mine at 28psi and 600cc water meth, i pulled it apart to see the insides and verify that it was infact the tranny that had the knocking sound and i found the gears melted together. Still looking to put down a good pass or 2 this year.
TheGraye28
Re: Noob to M30's
I demand updates! Calling Otis!
M. Holtmeier
Re: Noob to M30's
Post by M. Holtmeier »
Nein!
He's too busy to post here. Leave the man alone so he can do work! :laugh:
Good & Tight
Re: Noob to M30's
New personal best. Re-furbished the front suspension and added coil overs with new front runners. Also added a 75 shot of nitrous and took it real well :laugh: 9's are close....!
M. Holtmeier
Re: Noob to M30's
Whoa. Nice work. :beer:
Re: Noob to M30's
Awesome Otis.
TheGraye28
Re: Noob to M30's
Congrats!! Keeping all us mere mortals motivated.
acho
Re: Noob to M30's
Post by acho »
Job well done Otis!
Good & Tight
Re: Noob to M30's
Thanks guys here's a in car vid.
http://youtu.be/OiinFhUomjg
SF-535is
Re: Noob to M30's
Post by SF-535is »
Any changes to your setup?
Always awesome to see your vids.
Good & Tight
Re: Noob to M30's
SF-535is wrote:Any changes to your setup?
Thanks, I refurbished the front end, new control arms, tie rods, shocks, coil overs, new front skinnies. Did the alignment with a set of jack stands and string, toed in 1/8".
Was surprised myself how straight it went...! Going to shoot for 9's this year, would be incredible to do it on this junk yard M30 motor:lol:eyecrazy
acho
Re: Noob to M30's
Post by acho »
Car looks awesome Otis and I really like the skinnies!
What setup are those?
zrossa
Re: Noob to M30's
Post by zrossa »
Nice Run!
Which turbo did you use? Hx40? Hx55?
Cheers,
Douglas
Good & Tight
Re: Noob to M30's
acho wrote:Car looks awesome Otis and I really like the skinnies!
Thanks Acho, I had 4 lug to 5 lug adapters made. They are a 5 lug Ford bolt pattern.
zrossa wrote:Nice Run!
Cheers,
Douglas
Borg Warner SX300 91/79 divided housing.
Good & Tight
Re: Noob to M30's
Long time without any updates, car is running flawless, so I've had the itch to freshen up the front end appearance wise and shed some weight.
Really didn't have a game plan, just started taking the front end off and grabbed the sawzall.
Here's what it's looked like for over 5 years, old E21 chopped up BBS spoiler.
How this thing stayed on at 160+mph by 6 self tapping is beyond me.
Draining coolant...just water with some water wetter.
Then the cutting began...
Welded one plate on, and ran out of mig wire, called it day.
Here's the replacement for the front. It will need a good amount of work once I cut away half of it for the intercooler.
http://www.ebay.com/itm/151629857777?_t ... EBIDX%3AIT
I'm guessing about 15-20 lbs will be removed.
Here's the pile. Lights and grills are going back in, it's a street car after all.
Top shot
Both frame block off plates welded in place and primed.
Might change the belt while I'm in there, I'm guessing it's original also. Lol
Stay tuned for updates....
Xenocide
Re: Noob to M30's
Post by Xenocide »
Good & Tight wrote:it's a street car after all.
:rofl: :rofl: :rofl:
Thanks man, I needed that!
Car is looking great, thanks for the updates!
acho
Re: Noob to M30's
Post by acho »
Cool man! Keep us all updated.. :lol:
bornagain
Re: Noob to M30's
Post by bornagain »
hey otis would you be able to send me your msqs? im tring to do some comparing, no im not running e85 but i would assume i would have to pull some timing out but i could get a good baseline start on the new setup in the e30. Thanks in advance
Shadow
Re: Noob to M30's
Post by Shadow »
why?
Good & Tight
Re: Noob to M30's
bornagain wrote:hey otis would you be able to send me your msqs? im tring to do some comparing, no im not running e85 but i would assume i would have to pull some timing out but i could get a good baseline start on the new setup in the e30. Thanks in advance
Sure no problem, what's your email..?
bornagain
Re: Noob to M30's
Post by bornagain »
Thanks Otis,
Sburlingham at gonissan.ca
Good & Tight
Re: Noob to M30's
MSQ sent.
Luckily I'm a parts hoarder and had some stuff laying around.
Welded on the frame extensions, need some more tubing to complete it.
Been running a E34 2.5 radiator for 5+ years now, surprisingly with no cooling issues. Had this E28 3.4 unit laying around, so now is the time to put it to use, luckily I didn't toss it out. The only draw back is it has no expansion tank.
To solve the expansion tank problem I had this M20 one laying around. Here's it's new resting place. Had to rotate the BOV 180* to make it fit.
