Posted: Mar 23, 2013 5:39 PM
Thanks! That's what I used. The package is pictured. $20 per roll.Sonador1984 wrote:Great build, and what A stunning E28.
A tip for masking the centers up: Fine line tape
Measure diameter of area to be painted. Draw circle on thin card. Draw a concentric circle of diameter, say, 4" larger. Cut out inner circle. Cut round outer circle to make a ring-shaped stencil. Overlay wheel with stencil. Tape stencil down well. Mask off behind/around stencil. Spray. Reuse stencil for all 4 wheels.wkohler wrote:Thanks for the comments. I investigated several options for masking the hole. I have a compass with an x-acto knife on it and I couldn't get it centered. I have some leftover vapor barrier scraps that I was going to use for this but the problem is that you really cannot reposition it without distortion. I certainly appreciate the suggestion. I think I might give it a shot again before I do the next wheel. We will see.
I have no idea what was used on the spoiler. I didn't do it. Mike did it. He said it is flexible and won't crack. He used the same stuff on my mirrors.
Just saw this...cibie wrote:Chris,
Just an idea to help with your painting, use Duck Tape sheets: Take a quality compass divider to trace a circle & then cut the inside of the circle out.
If Duck Tape sheets are no good because they'll leave residue on your wheels,
1. Line a sturdy sheet of paper with packaging tape.
2. Apply masking tape over the packaging tape. Make sure you start on one end so you can peel off later.
3. Do the compass divider trick.
4. Cut the inside of the circle out.
5. Peel off the masking tape & apply to your wheel.
Don
With my Alpina rear spoiler, I made a template with the boot closed, then cut out the shapes on some clear stone guard decal sheets. With a fine mist of water, a heat gun, and a plastic applicator, it went on seamlessly. I'll take a photo for you when it isn't night time.Karl Grau wrote:
Are you doing anything with that rear spoiler to prevent chafing on the paint?
+1Das_Prachtstraße wrote:With my Alpina rear spoiler, I made a template with the boot closed, then cut out the shapes on some clear stone guard decal sheets. With a fine mist of water, a heat gun, and a plastic applicator, it went on seamlessly. I'll take a photo for you when it isn't night time.Karl Grau wrote:
Car looks great, Chris.
I need to do this on mine as well.......Das_Prachtstraße wrote:With my Alpina rear spoiler, I made a template with the boot closed, then cut out the shapes on some clear stone guard decal sheets. With a fine mist of water, a heat gun, and a plastic applicator, it went on seamlessly. I'll take a photo for you when it isn't night time.Karl Grau wrote:
If you make a template please copy it as i need to redo the black centers on my wheels as well......great job BTWwkohler wrote:Thanks for the comments. I investigated several options for masking the hole. I have a compass with an x-acto knife on it and I couldn't get it centered. I have some leftover vapor barrier scraps that I was going to use for this but the problem is that you really cannot reposition it without distortion. I certainly appreciate the suggestion. I think I might give it a shot again before I do the next wheel. We will see.
great jobwkohler wrote:
