Page 3 of 4
Re: e46 Heater Valve Retrofit
Posted: Aug 06, 2020 12:43 AM
by anchored
I also did this mod with my e24.
Wrote a nice guide about how to do it and how to mount it properly.
http://bigcoupe.com/phpBB2/viewtopic.php?f=2&t=31889
Posted: Mar 15, 2021 3:33 PM
by Tulsa6
I did this retrofit yesterday to my 88 535i; I have been through 3 brand new valves 64 11 1 373 191 - of which Schmiddmann would not warranty theirs (less than a year old - started leaking) because I did not have any proof I had the work done at a BMW Authorized repair center. Somehow, optimism got the best of me, so I bought one from the local BMW dealership, which promptly leaked and was replaced under warranty even though I installed it. Less than 2 years and it is also leaking but BMW will not warranty their new one. While I thought about taking up FCP Euro on their lifetime warranty, I just am done with leaks and who's to say BMW will have these for the time I still have the car.
So, as luck would have it, I went to LKQ pull a part just as a heavy rain started, but I had a list of around 8-9 cars that would have this valve and chose ones from the cleanest looking cars. I saw this with e30's, BTW, get a valve, bracket and wiring while you can, the yards no longer have 6 to 8 e30's at a given time, but the e46's are there now.
I've installed it but the current plan is to wait for a couple of 7/64" male spade connectors to get here before I do the wiring. But we'll see, I may solder the e46 connector in since I have no plans on going back. I followed "anchored"'s method of cutting of the e46 bracket with tin snips and elongated the holes in the e46 bracket so that with some shorter screws, it mounts to the m30 e28 bracket. I used a sharkbite 1" straight knurled hose coupling that has a perfect fit for the inner hose diameters. Also, there were 2 BMW hoses in my e28 stash that fit the application perfectly: 64 21 1 363 470. I don't know why I had two - you only need one - and cut about an 1 1/2" off the big fluted end, and it seem to be the perfect length to attach to the outlet to the heater core inlet. Correct me if you see I've reverse something, sleep deprivation seems to be a constant for me, and thinking correctly not so much.
Posted: Mar 16, 2021 10:32 AM
by Shawn D.
Glad to see folks are still finding variations on how to mount these! I've had one for a while and intend to mill a new housing to better fit the E28, but just haven't gotten around to it.
Posted: Mar 20, 2021 2:40 PM
by Tulsa6
Shawn D. wrote: Mar 16, 2021 10:32 AM
Planning on doing my daily 525e next - should have done it a long time ago, but put in a manually operated VW valve.
Posted: Aug 18, 2021 4:48 AM
by Maaaate
My 535’s heater has, until about a year ago, been great. Since then it’s been lukewarm to ineffective, and I’ve spent a lot of time on this link. Given the vehicle’s age I assumed it was the heater valve. People’s reported experience with repair kits has put me off, and I got an indicative price of $700 Australian for a BMW-sourced replacement, so I took the E46 path.
When I got the $70 valve, the wrecker had included the connector and about 6” of wiring – thank you Peninsula BM. The wire colours didn’t match the E46 ETM I checked and, bench testing, it worked no matter which way round the positive and negative were connected – no idea why. I also tested it inverted.
It seemed like too hard work to make the complicated plumbing routing others have used to get round the changed flow direction for the valve, so I installed it inverted to keep the inlet to the valve at the top (thanks RonW) as follows:
• hacksaw off the three mounting lugs and file the plastic case smooth so it will fit between the brake hydraulic pipe and the bulkhead
• sort out the wiring connection from the new valve to the existing connection – it’s inaccessible once the valve is in place. I used a connector block so I could check out the function before committing to solder and shrink wrap. If you cut the plug for the old valve off, leave an inch or so of wire so it can be reused if needed.
• from the local parts store get a ¾ inch 90 degree elbow hose and about a foot of ¾ inch straight hose
• remove the old valve, spilling coolant everywhere
• take off the hose from the back of the cylinder head
• remove the hose which connected the valve to the lower of the two heater pipes. You might be able to adapt this – see following – instead of buying the 90 degree elbow.
• disconnect the hose from the front of the engine to the top heater pipe, at the heater and attach it to the lower of the heater pipes. This allows the two hoses into the valve to line up beside each other.
• cut the 90 degree elbow so that it joins the top heater pipe to the lower of the two pipes on the now inverted E46 valve. Set the length so that the valve tucks behind the metal hydraulic pressure pipe.
• Cut the straight ¾ inch hose, to go between the back of the cylinder head and the upper pipe on the valve, a few inches longer than needed. Here’s the only difficult part – the pipe at the back of the cylinder head is slightly large for the ¾ inch hose to fit on easily and it’s very hard to get any purchase towards the end to force it on – reminded me of George Burns’ comment about shooting pool with a rope. I found a 1 inch plastic electric duct pipe which enclosed the hose. Cut the duct pipe a bit shorter than the ¾ inch hose leaving the inch or so to go onto the cylinder head pipe proud. It was then surprisingly easy to push the hose on. Cut the hose to length and connect to the top pipe on the valve.
• Use a zip tie to locate the valve against the hydraulic pipe.
Reversing the connections to the heater core reverses the flow through the heater core - probably time for a reverse flush – the connection from the back of the cylinder head is still connected to the heater valve inlet and the new outlet from the core is still connected to the hose running to the front of the engine. Looking at the photo, I think the valve could be mounted higher up if the lower hose was rotated accordingly.
Testing went ok, except overnight there was a major leak. Couldn’t see where it came from, but tightening all the hose clamps fixed it. All good on a longer test drive. The photo - if the link has worked - shows how simple the hose connections are.
Given what a pain the job was, leaning over and working down the back of the engine compartment, I could handle $150 for an oem valve, but $700?
Constructive criticism appreciated.
Posted: Aug 18, 2021 9:06 AM
by Shawn D.
Looks good, Maaaate!
Posted: Mar 26, 2022 6:43 AM
by Tulsa6
A year later, and the 535i valve has worked great - first time to The Vintage, and a trip up north after that - twice - and it still works good. Like I said before, I should have done this years ago, and never bought the valve kits or the current iteration of the valve from BMW.
The 525e daily, however, is still not shutting off completely. I bought another salvage yard valve just in case, but going to verify the in/out are correct and try again.
I replaced the heater core on the 525e at the beginning of the pandemic and then last year, had to replace the one on the 535i when it started leaking.
Recommendation: if you ever remove a dash board on a car that is new to you, replace the heater core while it's out, then you won't have to remove it again a few years later...
Posted: Mar 26, 2022 12:42 PM
Tulsa6 wrote: Mar 26, 2022 6:43 AM
... if you ever remove a dash board on a car that is new to you, replace the heater core while it's out, then you won't have to remove it again a few years later...
Except you don't have to remove the dash to do the heater core, but you do have to remove and discharge the A/C. So if I had working A/C, especially if it was R12 A/C, I would not preemptively do it and blow the charge.
Posted: Mar 31, 2022 8:05 AM
by Tulsa6
Mike W. wrote: Mar 26, 2022 12:42 PM
Good point Mike; the A/C has been working since 1998 when I had an Sanden style compressor installed and recharged with R12. It had some R12 added 3 years ago when I had it checked, but I did not want to mess with it otherwise.
Some notes on the m20 e46 valve installation since I couldn't find a flow diagram for the e28; the 2nd e46 heater valve seems to be working on it's first road test - no leak through like the first one I used:
m20 - how I installed it - possibly reference flow diagrams from an e30 to determine this but it has been over a year since I configured the install:
bottom of heater core hose to top connection of e46 valve (top was inlet on oem valve)
bottom e46 valve to back of head hose
Posted: Dec 13, 2022 12:32 AM
by indycar89
Posted: Dec 26, 2022 12:52 PM
by chilone
I'm super glad I came across this thread! When I got my 1987 535is, the heater valve was not there and bypassed. I've been pondering what to do about this. I figured a different valve could be used, so I'll be trying this.
Thanks to everyone who's contributed!
Posted: Jan 05, 2023 10:09 AM
by szacsi72
Hi guys,
I've decided to do this 'upgrade' (repair, for me), and I decided I'd make some adapters hence I don't like cutting up things and zipties....
Please let me know if you'd need a piece. I'm making 5 units as of now. They'll be laser-cut from 2mm 304 stainless steel. You just put the stock E46 rubber groomets trough the holes, then push the unit into it. Pictures of 3D printed prototype. The actual end-product sits a bit more away from the brake MC, so you can easily plug it in.
I'll update with pricing, but expect a low prices. You'll also be able to buy complete sets from me, I've stocked up some brand new Febi valves too.
David
Posted: Jan 05, 2023 1:03 PM
by chilone
szacsi72 wrote: Jan 05, 2023 10:09 AM
Hi guys,
David
That kicks major ass, David!
Posted: Jan 05, 2023 4:32 PM
by milarsky
I'll take one please!!!
Posted: Jan 09, 2023 8:43 AM
by szacsi72
Hi Guys,
The adapter plate will be $15 a piece; a kit, including the adapter plate and a brand new FEBI unit will be $115.
Please send me a PM if you want one!
David
Posted: Jan 09, 2023 5:38 PM
by MisterFixit
szacsi72 wrote: Jan 09, 2023 8:43 AM
Hi Guys,
David
David - does this include overseas shipping ???
Milarsky,
I am also interested in this retrofit / upgrade. Please let me know what is involved, additional parts needed, anything that will help me decide to go ahead!
Andy
Posted: Jan 12, 2023 8:33 AM
by szacsi72
MisterFixit wrote: Jan 09, 2023 5:38 PM
Hi Guys,
David
Milarsky,
Andy
Hi Andy,
No, none of my prices include shipping. If one of you decides to buy multiple items, shipping will be of much better value.
David
Posted: Jan 12, 2023 9:38 AM
by jimoreno
I'll take one too please!
Posted: Jan 13, 2023 7:43 AM
by lswoboda
Hello,
This is great! I’d like to purchase the full kit, please—the plate and a new Febi valve.
Thank you!
Posted: Jan 13, 2023 10:58 AM
by milarsky
szacsi72 wrote: Jan 12, 2023 8:33 AM
Milarsky,
Andy
Hi Andy,
David
PM
Posted: Jan 13, 2023 12:28 PM
by szacsi72
PM'd you all. Thank you.
Posted: Jan 16, 2023 10:15 AM
by szacsi72
They are here!:)
Posted: Jan 19, 2023 7:05 AM
by szacsi72
Hi guys,
This part number works perfectly with the E46 heater valve. I believe the part number says it's for the outer temp sensor, but it's the same.
61132359999
I've bought a vemo-kit that comes with pins included, no soldering or hacking required. Set me back $12.
Posted: Jan 27, 2023 7:56 AM
by szacsi72
FYI the plates are sold out. Let me know if you guys want more; I'm happy to make a second batch if there's need for it.
David
Posted: Jan 27, 2023 10:18 AM
szacsi72 wrote: Jan 27, 2023 7:56 AM
David
Put me down for 1.
Posted: Jan 27, 2023 9:40 PM
by shallam
Put me down for one as well.
Posted: Jan 28, 2023 8:01 AM
by thrty8street
Put me down, too.
Posted: Jan 28, 2023 3:27 PM
by _marshall
Add me to the list as well.
Posted: Jan 30, 2023 2:53 PM
by lswoboda
szacsi72 wrote: Jan 16, 2023 10:15 AM
They are here!:)
Mine arrived today safe and sound with the Febi valve!
Mine is the one with the writing on it!
Thank you for putting together a total solution and for shipping it so quickly.
LSwoboda
Posted: Jan 31, 2023 5:30 AM
by szacsi72
lswoboda wrote: Jan 30, 2023 2:53 PM
They are here!:)
LSwoboda
Thank you and glad I could help!
Since a lot of you asked, I'm making another 5 adapter sheets.
Pricing:
-Adapter sheet: $15
-FEBI Valve + adapter sheet set: $120
-FEBI Valve + adapter sheet + VEMO connector set: $140
Shipping to US (roughly):
-Sheet: $25
-Sets: $35
I will clarify these when ordering, since the pricing is constantly changing. The FEBIs also became a tad more expensive at my local parts shop :/
Here's a picture of my engine bay with it installed (still need to connect the lines, hopefully I'll have some time next week):
