Dieselboost's 524compoundTD
CoyoteStarfish
Post by CoyoteStarfish »
From what I understand, as long as you supply enough pressure and volume of fuel you can run larger cam plates without loss of high end power. On a forum for Cummins engines someone suggested that if we could supply enough pressure and volume of fuel with a quality lift pump and fuel regulator we could run 4mm cam plates. That is a little crazy in my opinion, I would be happy with a 2.8/3.2mm plate used in a stock Cummins, and just supply it with adequate fueling.
Also take a look at this:
http://www.youtube.com/watch?v=LbG4INpF0Ks
Looks like a M21 engine with a heavily modified P7100 injection pump, is that what you're thinking of doing?
DieselBoost
Post by DieselBoost »
yes that is roosamaster pump....that guy who own that car wrote me in youtube..
but yes mercedes row ip.
DieselBoost
new video in daylight
HERE! http://www.youtube.com/watch?v=3pI6qduZ3jM
Alleslowbuged
Post by Alleslowbuged »
Hi,
like that "tractor" sound of a M21 with a straight pipe.
Funny, that you also lost a headgasket though a wasetgate problem, i have lost my second headgasket 2 or 3 hour after restart the engine, because a small boostpipe for the bosstcontroller has get a leakage and i have driven on the autobahn with whatever boost pressure.
Did you have shedule to go on the dyno agian, i would really love to know how much power increases through the the 12mm plunger.
I was on the 1/4 mile this weekend, but could not really decrease my toptime, best run was a 15,2s. Did you was on the dragstrip with your bimmer?
@CoyoteStarfish
In summary you have to make 3 major mods on a pump:
1. bigger plunger for faster injection
2. more advance timing for good high rpm power
3. governor mod, for more fuel at higher RPM than 3500
The hardware mods are not that difficult, if you have the necessary tools, but to find a good setup without a test device and/or a lot of experiency will be nearly imossible. I have 10 years of pump experience and still working since last christmas on my vw pump, to find the best hardware combination and a good setup. The last pump change has been finished in 55min between engine stop and start, so you could imaging how often i have dismount the pump since christmas.
Best Regards from germany
Alleslowbuged
DieselBoost
i think im not going to dyno in this moment.... because i will use max 1.7bar boost now.
in finland one 324TD e30 has 12mm plunger with 1.6bar boost and 245hp
i was in dragstrip, but fuel liftpump failure ruined that day. so my car was only in parking lot.
but my friend has 15.6sec time with top speed of 159km/h
and....it was rainy day...so no grip untill 4gear
i think it was quite good time for those weather conditions.
Alleslowbuged
Hi,
i drive also max. boost pressure of 1.6 - 1.7 bar in my car. Is the gearbox and differential stock in the car of your friend? The top speed of 159 km/h sound really really quick and should bring a time of below 15s, my top speed is arround 135km/h up to 140km/h, either with a differential ratio of 2.93 or with stock ratio of 3.15.
Why don`t go on the dyno with 1.6 bar, i would really love to see the different in peakpower and also in the power curve vs. engine speed.
Best Regards and always a tight headgasket
Alleslowbuged
DieselBoost
gearbox are stock (260) but differential is from 520i
time will tell... there is waiting list of months in dyno....so maybe later.
whatever in next summer i have totally new engine. so then we are talking power seriously.
now there is too small turbo, so i cant get more than 250hp.
DieselBoost
check out our facebook group Team3fd
there is our cars.
updating is little bit slow, sorry :D
altus22
Post by altus22 »
How much intercooling do you have? Is it water to air or air to air? Do you know what your peak intake temperature is?
DieselBoost
altus22 wrote:How much intercooling do you have? Is it water to air or air to air? Do you know what your peak intake temperature is?
i dont remember measures. (see my project pics)
but less.
ic is custom made for my car. by erikoishitsaus raatikainen who make coolers for racing cars.
he is one of the bestest aluminum welders in finland.
so i dont use china coolers.
but ic is quite large and very effective.
ic is air to air type....i have no use for air to water. only dragcars and pulling tractors have benefit of that type ic
DieselBoost
Now we are talking about serious shit...
while im working with my 524TD
in same carage is something else...
it is Mb 190 300superturbodiesel project of my friend.. actually same guy who owns that other 524TD..
in mb is about 400whp now.
this is only mild test drive. we tested it in asphalt and there wasnt any grip when accelerating full power from 80km/t speed with 4th gear.
http://www.youtube.com/watch?v=tOvmMgQt9oI
http://www.youtube.com/watch?v=fAGidcDBK10
Zubcho
Post by Zubcho »
wow :shock:
DieselBoost
Okay AGAIN! i must slow down my project...
Out of money
:x
DieselBoost
Juts discovered more broken waterhoses from my car :facepalm:
and second irritating thing..... expansion tank pressure cap is not working properly.
i can only say....upper waterhose was like a piece of rock.
anyway...engine is running fine now, only must get new cap for expansion tank and few new hoses.
in next engine.....i will make waterpipes not bloody hoses DAMN THOSE HOSES!!!
DieselBoost
attlast winter came.
So i tested my oilburner
-12c temperature, no block heater, summer type diesel, dry fuel system....
http://www.youtube.com/user/boostturbo? ... sAp6Tx-MYY
then strikes summer type diesel
http://www.youtube.com/user/boostturbo? ... rpsbGCdtHU
:laugh: :rofl: Love the cold start!
DieselBoost
Goodbyes for my garage...
so now is the time to leave my loved carage, it was expensive to keep and our team have own place now.
we are buildin new big carage for our team in my friends ranch. old large cowshed is very cool place for our purpose.
there is room for about six cars.
it smells bit a cow doodoo but it doesnt matter :laugh:
DieselBoost
hello.
I fixed few problems.
1. new expansion tank with newer model plastic cap, water overpressure problem is now fixed....new cap works.
2. fuel lift pump cable connection was poor but now it is fixed
3. engine doesnt start. 4h in warm garage + 20litre winter type fuel with 2litre gas and 1dl 2t oil. and there is now block heater.
now engine is running smooth
:cool:
DieselBoost
What happens when our team gets bored?
http://www.youtube.com/watch?v=VsKPssXMeMQ
DieselBoost
Finally i got something good stuff in here....
my friend allowed to upload this vid of his 524TD acceleration testing from last summer.
this engine is maded from scrap parts.
http://www.youtube.com/watch?v=aLZBaPKgk_g
Zubcho
Post by Zubcho »
Pls give as some pics and more info about the upgrades you have made.
DieselBoost
Zubcho wrote:Pls give as some pics and more info about the upgrades you have made.
about my car or my friends car?
http://irc-galleria.net/user/Laskeuma/picture/104062814
this is from my friends 524TD
Zubcho
Post by Zubcho »
About your car ;)
DieselBoost
ok.....
chassis front
-Koni sport adjustable shock absorters with cobra 45mm lowering springs.
-all powerflex urethane bushes
-all arms replaced with new ones
Chassis rear
-Bilstein new stock shock absorters with cobra 35mm lowering springs
-Powerflex urethane main bushes
-differential is from 520i and it is quite short
Engine
M21D24 from 1991 324TD
engine is refurbished, exception block which is opened only for replacing oil pump with new one.
cylinderhead is cleaned and valves and valve seats are machined, surface is machined.
stock head gasket gemented with vht copper gasket gemetn.
stock head studs
stock cam with timing littlebit earlier.
injection pump with cummins 12mm rotorhead and cummins stock cam plate. and many fine tunes by Pp-Diesel
Timing is 1.15mm before tdc
-gearbox stock getrac 260 5
-Clutch sachsracing 240mm(m5) with stock plate
-528i solid flywheel (240mm)
modified intake manifold
Large intercooler and radiator maded by I Raatikainen
(Erikoishitsaus raatikainen)
stock (524TD)exhaust manifold with my fitting flange with exhaust temperature and exhaust pressure outputs.
Turbo
Master Power SUPER 70 F-2 REFLOW
Model: 802315-063
compressor: 56,5mm
compressor a/r: .70
Turbine: 58,5mm
exhaust a/r: .63
flange: T3
power: 350-490hv
3" downpipe and 3" straight pipe
exteriour
-Color Toytota 162
-Rims ? 17" 7" wide
-Tires hankook ventus k110 215R1745
-rear wing from opel ascona c irmscher
so... nothing very special included for this ;)
there is about 200+?????? power now.
These mods with stock injection pump i had 191hp
now.... much more....
superturbo engine is underconstruction....and in ice...... until i get new job....
DieselBoost
so..... some people are thinking to get more liftpressure for injection pump....
i got answers from my pump builder....
never exceed casing pressure of injection pump...
DieselBoost
damn... my wet dream
I need more money and bigger garage :D
In some day i will get a "real" diesel car for my diesel performance projects
http://farm4.static.flickr.com/3403/358 ... 4d7f11.jpg
This is little bit too bligbling for me..... maybe race truck look fits better to me ;)
DieselBoost
now im working with water/methanol spray system in my 524
only bad thing is that..... im totally broke...
so must use my creativity with this.....and freebie parts :)
this is my plan...
-two car headlight washer pumps connected in sequence to get about 4bar pressure.
- oil burner nozzle
-pressure Switch
-limit pressure valve
-self maded tank
-flow controller valve
to increasing water pressure i connect hose from turbo to water tank..
when pumps are making 4bar then boost make extra pressure about 2bar in tank..... i got allmost 6bar waterpressure
and nozzle fitted just before intake manifold
im not making this to get more power...... only to get exhausta/burning gasses little bit cooler and engine lasting longer.
CoyoteStarfish
If you want pressure...I suggest you don't use vane style fluid pumps designed for flow and volume. I would use compressed air to pressurize a sealed tank of water/methanol using a small and cheap air compressor designed for inflating tires to pressurize a tank with water/methanol inside.
One option, If you fill the tank with 75% mix and leave 25% air and pressurize it to something crazy like 9 or 10(135-140PSI) bar, it should have enough pressure to push the entire charge of mix out of the tank. You can use a fuel pressure regulator to regulate the pressure of mix leaving the tank if you need to.
Second option is more difficult and more expensive, use the same idea as above but leave the compressor attached, wire it up to a pressure shut-off switch that will limit tank pressure to your desired pressure.
Frybrid 524td
Post by Frybrid 524td »
Methanol injection isn't advisable in an IDI engine based on what I've read. I plan on adding just water injection at some point after turbo, I/C, and head upgrades.
DieselBoost
Frybrid 524td wrote:Methanol injection isn't advisable in an IDI engine based on what I've read. I plan on adding just water injection at some point after turbo, I/C, and head upgrades.
Ok..... in finland we have used methanol/water injection for years..... and it works fine.... in our engines..... only point is dont put too much methanol max 30%
