Dynaliner installed to replace the crumbling sound deadening material on the firewall.Cooperman wrote:Bump for update
Heater valve rebuilt
Dogleg 'Sport' transmission resealed, surface corrosion removed, filled with Redline MTL, hardware replaced, new crossmember powdercoated, IE urethane mount and AutoSolutions SSK installed
E34 M5 3.8 guibo and new/longer hardware (search Duke's old posts for reasoning)
BMP brass clutch pivot pin installed
New reverse switch
UUC steel braided slave to master cylinder hose
New direction with the intake: no more restrictive B35 cork. Paul B. sourced a nice S38B36 throttle assembly and made some adapter plates for mounting to the B35 head he's putting the finishing touches on (all new valvetrain, custom cam, etc).
Picked up an S38B35 air accumulator to use as a mock up for a custom aluminum air accumulator to more efficiently plumb in the output from the TCD S3 water-air intercooler
Ceramic coating on all heat shields (+ NOS Hartge passenger shock pillar to firewall brake line heat shield), exhaust (3" TCD) and oil pan
TIG'd an AN -10 bung on the oil pan for turbo oil return line
Landed an authentic Hartge handbrake handle
Received a black suede shift boot with Motorsport stitching from Shift Style to match the seats and steering wheel
New trunk gasket
Removed one-piece hood liner and foam
Installed BMP 3-piece hood liner
Sold the M-Systems wheels to a good home in SD
Deal fell through on the BBS 16's
Went with a nice set of Hartge Design C 17" wheels found here on the board (since first seeing them August 2009 in Monterey on RonP's stunning H5S which took first to my second in the concours, I've been in love with them. The decision was a no-brainer since the car was already sporting Hartge plasticware: airdam, side skirts and rear valance)..in the process of being refinished.
There's probably more, but rest assured I haven't lost interest in the project. Thanks for the interest. Pics soon...
