Noob M30B35 Build
Re: Noob M30B35 Build. 2014-10-13: Fixed Fuel Problem
The table for the stock B35 (which has domed pistons) has a lot more advance at low loads compared to the table for the stock B34 (which has dished pistons). This actually mirrors my experience with a high(ish) compression M10. Despite the higher CR, it wanted plenty of "vacuum advance" just like a stock M10B18 (which again has domed pistons). I ran as much as 52deg. My M30B32 (flat top pistons) however does not benefit from so much advance at light loads.
Also a stock M50 map tops out at 43deg, and that's with a much smaller bore, central spark plug, and dished piston. After seeing that as well as stock Eta maps I could believe that the 179 table really has 54 in it.
Of course it doesn't hurt to error on the safe side, especially at the higher loads. And on these maps that are indexed to MAF voltage or whatever it's hard to know exactly how much load the value represents unless you have a way of logging the actual voltage while driving.
Thanks. Good intel. Question: What does a motor "wants more vacuum advance" mean? For more performance? To generate more vacuum pressure?12valves wrote:The table for the stock B35 (which has domed pistons) has a lot more advance at low loads compared to the table for the stock B34 (which has dished pistons). This actually mirrors my experience with a high(ish) compression M10. Despite the higher CR, it wanted plenty of "vacuum advance" just like a stock M10B18 (which again has domed pistons). I ran as much as 52deg. My M30B32 (flat top pistons) however does not benefit from so much advance at light loads.
Vacuum advance refers to the timing at part throttle, which is generally more advanced than at WOT. At part throttle there is a certain amount of vacuum in the intake, while at WOT there is essentially none. Cars that didn't get computer-controlled ignition timing often had a vacuum hose running to the distributor, so the vacuum would actuate a lever in the distributor resulting in more spark advance.What does a motor "wants more vacuum advance" mean?
So for example, on this map they didn't bother to tune for part-throttle conditions at all. The downside to this would be subpar fuel mileage and throttle response.
Super helpful!12valves wrote:Vacuum advance refers to the timing at part throttle, which is generally more advanced than at WOT. At part throttle there is a certain amount of vacuum in the intake, while at WOT there is essentially none. Cars that didn't get computer-controlled ignition timing often had a vacuum hose running to the distributor, so the vacuum would actuate a lever in the distributor resulting in more spark advance.What does a motor "wants more vacuum advance" mean?So for example, on this map they didn't bother to tune for part-throttle conditions at all. The downside to this would be subpar fuel mileage and throttle response.
On our cars WOT is determined by the TPS, right? I mean you are either at WOT with the throttle or not, right?
FWIW, my throttle response has always felt fine (and still does with this latest tune) across the range.
However my fuel mileage has suckaged. I'm getting about 16mpg... I expected better with this motor.
Yeah, that's a good question. I'm not sure about Motronic 1.3. Some versions of Motronic have a potentiometer TPS, others a switch, and some have a completely separate set of maps for WOT.
But I was speaking about it generally. Since the X axis of the map is the amount of air going in, WOT would be over towards the right somewhere, whereas cruising at part-throttle would be towards the left.
1.3/179 ecu has a separate maps for fuel and timing for WOT. I was wondering what caused it to switch to it; just tps or something else. Fwiw, I'm not touching my WOT maps because we spent a lot of time with them on the dyno.
I backed off my P/T timing more and really got confident the knocking is gone. The map ended up looking pretty homogeneous but not too dis-similar to the Alpina B10 3.5 tune. I like the fact that it appears someone put some time into it, so that's what I've been using last few days. No pings.
So now vlad has Alpina wheels AND an Alpina tune. I think ill put an Alpina badge on it now.
Dont't forget the 'I was in Romania, and did'nt bought the first E28 I saw' sticker.
It looks like, the guys in Bovensiepen knew something about high compression engines, in the eighties. l
I am a fan of this topic, btw.
Today, at 3400 miles since the engine was installed, I did an oil and filter change. Oil came out looking exactly as you'd expect oil at 3400 miles to look. I will be sending the oil to Blackstone for analysis; just because I think it's fun, not because I think I'll learn anything, but who knows.
While the oil was out I also pulled the plugs and put my endoscope into the motor to see what I could see.
First, the plugs look fine (I had checked them once at about 500 miles):
I scoped inside the head from the oil fill. It was hard to get the camera oriented, but I was able to capture this still of one of the cam lobes. Looks fine to me, but what do I know?
Then I put the scope in each cylinder through the spark plug hole. All 6 looked very similar (I did not rotate the engine, so only 1 & 6 had the pistons down enough to really see the cylinder walls). There is slight scoring in 1 & 6 that looks like this:
This Youtube video shows much more detail. You can also see carbon build up on the piston face. http://youtu.be/vsBkdFA_dck
In #5 I was able to see the top side of an exhaust valve. There's some carbon build up there that this short video does an ok job of showing (watch to the end).
http://youtu.be/ZIu3hoGgUrQ
In #6 more scoring is visible; similar to #1. This video: http://youtu.be/035Dl0uTsyk
I don't know enough to know if that scoring is concerning at 3400 miles or not. There's not much I can do about it, so even if it is concerning I'm going to just live my life in denial. But I'd love 'experts' thoughts if you have any. Thanks.
Re: Noob M30B35 Build. 2014-12-7: Pics of the Insides!
Looks pretty good to me. Borescopes have a way of distorting things and making them seem out of proportion.
I'm so glad to find you thread! I have a 1987 BMW 535is in red in completely original condition beautifully kept inside and out. I love my car except that's an automatic. Even though it drives very strong I'm going to install a manual transmission as soon as I can...I even bought a donor 1986 533i. I've done quite a lot of research and althou I've never done this type of job, I'm pretty confident I can pull it off. Thanks for taking the time to post your work! Awesome work!
Re: Noob M30B35 Build. 2014-05-24: Engine is out!!!
You'll recall I found this stuff to replace the firewall insulation:
UPDATE May 8, 2020: DO NOT USE THIS STUFF in an engine bay or where there's heat! Using this stuff as I did was a HORRIBLE MISTAKE as the rubber melts and drips making a mess.
Before anyone else goes and follows me down this path: This stuff has a big problem: the rubberized backing melts at high temperatures, turns to liquid and drips out the bottom of the car.
The good news is that it has enough oil content that it's easy to clean off.
My knocking/pinging is back. It didn't happen yesterday. But it did the day before and today. Between 2000-4000rpm under partial/medium throttle & load.
Until I get a professional to help me with this I've put the OEM 179 ECU and AFM back in. Wants to stall at idle in this configuration, but it ain't pinging.
I have a nearly identical motor in my E30. I had an issue with cutting out under high load that was probably related to my original harness and/or my CPS. My idle would also vary a bit as when first starting out when cold. I probably didn't HAVE to ditch the WAR chip system but I felt it could have contributed to my issues and I realized there are better systems out there. I'm curious to see what you come up with? My car had 208 hp and 240 tq on a Dyno Dynamics machine FWIW but I felt like it wasn't optimized. I eventually went with megasquirt 3X and am still involved with wiring it up but I have no doubt it will operate like I want it to when all is said and done. Good luck and I appreciate all your documentation.
How would you describe the performance difference from the Miller setup to the stock ecu/afm? How about the air/fuel ratios? This is interesting since the tunes you (and I) are running had less part-throttle timing than the stock 179 tune.
Tim
Tim
ZMOG! I just spent about 2 hours on the phone with Paul Burke. My head is about to esplode from all the informations. I feel like an idiot for not trying to get a-hold of him months ago.
Here's what he wants me to do:
- I gapped my plugs to .027" based on Bentley. He wants me to gap them at 0.32-0.35".
- He's given me an ignition map that is linear to use as a starting position. See below. **
- Get an AFR baseline at warm engine idle by adjusting fuel so that I'm doing 13.8 AFR (instead of the 14.7 I have now). Record what delta I had to apply (currently 137) because that will inform the magnitude of the changes I need to make in other parts of the map.
- Block off the vacuum line to the AFR so that it is static. This will remove one variable.
- Double check/test my TPS. He saw another car where the TPS was not signalling at all. I may test this at the ECU to ensure I didn't eff something up in building out the wiring harness.
- I feel much smarter about the relationship between timing, fuel, vacuum, and air-flow. I still can't echo it back but I'm getting smarter about it.
- He expects me to see 218-220hp and 240trq from this motor.
- He's seen IE exhausts where they're causing too much back pressure. We will run a test using the MAF as a sensor to see how much air is actually flowing to determine this.
- My 22lbs injectors should be fine, but are just on the edge of flowing enough at peak power.
I spent about 2 hours with Dan Miller this evening. Turns out he lives near Seattle and Brody from Miller Performance put me in touch with him.
I'll document things more when I'm 100% sure, but after driving the car and saying "I know what's wrong" he fixed the ping with a few graceful strokes of his mouse pointer on my tune.
I've thought I've had this liked before so I'm not going to declare victory just yet but based on my spirited driving tonight I'm cautiously optimistic...
You'll recall that the mounting tabs on main relay holder on the donor wiring harness was broken. I didn't notice this until after the motor was installed and up until today had not finished tidying up the wiring to the relays and C101.
I also hadn't figured out a way to secure the 1.3 diagnostics connector.
This is what it looked like before; note flopping main relay and diagnostics connector and unprotected wires:
A while back I bought a new set of wiring-harness connectors from a board member with the plan of splicing in the good main relay holder. I have been procrastinating doing this because I still didn't have a way to mount the diagnostic connector.
When I parted out the 88 528e I found my solution. See the bracket on the right side of this photo? That's the bracket used on Super-Etas.
DSC_1918 by t i g, on Flickr
I have no idea where it was mounted in that application, but here's where I put it:
I just bent it and used an M6 bolt with a big washer to mount it.
Here's a really exciting shot of wire splicing in progress.
Yay, nice and tidy:
Yay, nice and tidy:
So clean. Goals....
Also, didnt you have the B35 airbox mounted?
Hm, must have been another thread I was thinking of. Anyway, the B34 look isnt bad, but with a cover that nice, i would want to flash it every time the hood was up. Just a personal preference.
Going FI one day, or just sticking to high comp? (Been a minute since I followed up this thread, i might have missed a few updates on your plans)
This engine will never be FI.trevmmeister wrote:Hm, must have been another thread I was thinking of. Anyway, the B34 look isnt bad, but with a cover that nice, i would want to flash it every time the hood was up. Just a personal preference.
I will need to substantially modify that 924 Turbo air filter assembly to make it fit. There's really no reason to do it other than I think it would an interesting project and create something unique.
cek wrote:Super helpful!12valves wrote:Vacuum advance refers to the timing at part throttle, which is generally more advanced than at WOT. At part throttle there is a certain amount of vacuum in the intake, while at WOT there is essentially none. Cars that didn't get computer-controlled ignition timing often had a vacuum hose running to the distributor, so the vacuum would actuate a lever in the distributor resulting in more spark advance.What does a motor "wants more vacuum advance" mean?So for example, on this map they didn't bother to tune for part-throttle conditions at all. The downside to this would be subpar fuel mileage and throttle response.
This is my original tune from Miller. The car pulls hard and feels good but is very rich and is no where near optimal with this tune. I have been able to get it close but not where it needs to be. After looking at the other tunes, I can see why.
I am going to tune this month and going to try to start with a good base and go from there. My engine is Paul Burke 10.5:1 pistons, N31 cam, 24lbs injectors, ported b35 head and intake. Bav auto style headers, no cat, IE exhaust
Any input would be appreciated ... Sorry about the highjack CEK
Email me and I'll send you my tune. Super happy with it as it is right now.shwaa wrote:
Re:
Bear with me. I am trying to re-create the "tube of wires and connector " because they got fragged pretty badly on my e34 (m30b35). So far I have used 2gauge wire from the starter to the alternator and plan on re-creating the connector wire with correct gauge wire. What is currently stumping me is the wire that seems to be coming from the wire that goes from the starter to the alternator or visa versa. Is it a ground, for the tube, or is it a ground for that "connector" from starter to alternator ?
Wires in question are bottom of page just left of center.
Any help would be appreciated.
another pic showing which wire im talking about... its the one to the left.
Someone was asking about crank nuts on Facebook and someone else asserted they didn't think a crank nut could fly off on it's own if not tightened correctly. I went to find my posts where I talked about my own personal near-catesrophic disaster regarding this and realized that I never actually posted it to this thread. I get feedback from people all the time that this thread has been helpful to them, so I want it to be complete.
So, here's what happened (copied from Vlad's thread):
Seems to be a lack of blades. I only count the tips of 4 blades present. I found one down by the battery. Hmmm... I wonder where the other 5 went?
Ok, got a chance to look at the car. No dead animals or evidence of animal dismemberment apparent.
After moving the car I found one more blade and...
This washer.
OMFG.
You know what this means, right?
That I'm a hack mechanic who should't be building engines?
It also explains the oil leaking into the crank pulley. I sure hope that driving several thousand miles without a tight crank nut (which is nowhere to be found) didn't do any damage.
Kyle in NO wrote:Dig the sheared piece out of the crank snout with a pick and install a new key. They are cheap.cek wrote:CJ asks "if the woodruff key is sheared, what do we do? Crush the car?"Kyle in NO wrote:If the woodruff key isn't sheared, you should be fine.
Oh, and don't touch my engine.
http://www.autohausaz.com/search/produc ... 7119951485
cek wrote:Oh, I tightened it. I did it on the stand though and just to about 200lbs. It's supposed to be 325. I also didn't put locktite on it.demetk wrote:Holy crap. You mean you never tightened that nut? Don't you have a checklist or something?cek wrote:It also explains the oil leaking into the crank pulley. I sure hope that driving several thousand miles without a tight crank nut (which is nowhere to be found) didn't do any damage.
Me, I don't do checklists but whenever I install something I make sure to finish that particular process. Less chance of forgetting something.
I'm not the first to do this, which sorta makes me feel better.
cek wrote:Or, my memory is wrong and I actually failed to tighten it. Someone above asked "don't you have a checklist? you fucking idiot!"jodystevens wrote:200ft/lb and it still came loose
No and yes.
Next time I will.
cek wrote:Thank you Blunt:
Thank you Strictly BMW:
But, as it turns out I probably didn't need that nut because, I just happened to see this:
I just assumed it had previously fallen out and was lost. But now it's clear that it was the nut that destroyed the fan, not just the washer. I'm glad it didn't dent the underside of the hood!
Regardless, I'm using the new one. I actually should have another used one somewhere (two donor motors) but I can't find it among all my parts.
I have now convinced myself that I never REALLY torqued this nut down. I would have remembered having to use something to prevent the engine from turning, because that much torque turns the motor even if the motor is in gear and the brakes are on. It is also enough to break the 3/8" to 1/2" socket adapter I have. I tried using the shorter 3/8" socket today because the longer one won't fit with the radiator in.
For now I got to 180ft/lbs before the adapter broke. I won't be driving the car before Tuesday and I've ordered a shorter 36mm socket from Amazon that will allow the torque wrench in there.
cek wrote:Ah, yes. I got the right socket and torqued the nut to 325ftlbs.
I have been driving Vlad this week. His PO is in town, and we're trying to get together so he can see what I've done to his baby.
I have not have not had a chance to put him up on the lift to double check, but I'm confident its still leaking at the rear. But now I don't think I'll have to pull the engine, just the transmission.
And, for the record, the engine now has 11,256 miles on it since I put it in and is running flawlessly. No leaks either.
If it esploded tomorrow I'd still be pretty damn proud of myself.
Nice work. I have a similar engine I built but with the N21 cam, electric only fan, and megasquirt tuning in slow progress. How do you like that cam? FWIW I torqued the crank nut to like 270 ft lbs. If I recall correctly for whatever reason Paul Burke recommended and I haven't had an issue with it.
