Page 26 of 89
Posted: Aug 11, 2013 12:58 AM
ldsbeaker wrote:1st 5er wrote:The Touring is no longer on ramps and jackstands.
That's IT?!?
Sorry, but that's all I've got, at present.
Posted: Aug 13, 2013 1:02 AM
by davintosh
Drove the e32 home from Colorado.
~975 miles. The car did great. The bargain tires on it; not so much.
Posted: Aug 13, 2013 9:03 AM
by cddallara
Replaced the broken door handle on our Sienna. The new one is slightly off in color and fitment, but at a third of the cost of oem, my expectations can't be too high I guess.
I also learned one can't leave neutral or negative feedback to a 'proven seller' within 7 days of auction close. Wtf is that all about? I got the part, installed it, and am neutral on it. I guess I installed it too quick?
Posted: Aug 13, 2013 9:27 AM
by rmiddendorf
cddallara wrote:Replaced the broken door handle on our Sienna. The new one is slightly off in color and fitment, but at a third of the cost of oem, my expectations can't be too high I guess.
I strongly dislike eBay. eBay is dead to me.
Posted: Aug 13, 2013 1:09 PM
davintosh wrote:Drove the e32 home from Colorado.
Considering... I'm glad both you and the E32 made the journey.
Now your next road trip should take you
a more direct route
where you'll have caravan company for all but about 200 miles each way.
Posted: Aug 24, 2013 11:21 PM
by tig
The weather's been so lovely in Seattle this summer that I've been driving the 911 to work quite a bit. I am loving the Bluetooth enabled head-unit I have in Vlad both for hand's free phone use, and for streaming audio.
Ages ago I put a 3.5mm audio plug in the Porsche connected to aux out of the pre-Bluetooth head unit. But this was clunky and I couldn't do hand's free phone.
I decided to try one of the inexpensive Bluetooth units you can buy now. I picked this up on Amazon for $39.99 figuring it would be worth a try.
Kinivo BTC450 Bluetooth Hands-Free Car Kit for Cars with Aux Input Jack (3.5 mm) - supports aptX
Installation is a bit of a hack job, but the nice thing is that it's all easily removable for when I show the car.
I used the included double-sided sticky to attach the control/mic unit to the steering column. It's relatively easy to reach while driving and is nice and out of the way.
The unit plugs into a cig lighter outlet and while I hate having something like this mar the look of the dash, it's not too bad, and as I said above, easily removable. The wire to the control/mic unit is stuffed between the knee-kick panel and the dash and the 3.5mm cored to the aux input snakes through the lock hole the glove box.
As I use it more I'll report on how well it performs for hand's free phone use. For audio streamed from the phone it's excellent.
Posted: Aug 25, 2013 11:03 AM
by a
When I last drove the Rat, it came home with hot LR wheel. I got it up in the air and fiddled with the brake. During a break, I went upstairs and priced a new drum from AutoZone 42$ and there was one in stock at the store 2 1/2 miles away. Its Chinese,of course, but it is massive compared to the old drum. It had eroded away to a a noticeably smaller size. The inside diameter was oversized enough to allow the adjuster to drop and jam the shoes. There was quite a bit of dust and rust. I wired brushed everything, greased the flanges and put the new drum on.
I had re-used the drums and rotors when I replaced almost everything else in the brake system. The drum was zorched , it was blued around the outboard braking surface. The lip was cracked and missing in spots. A chunk falling into the brake may have set this scenario off.
Posted: Aug 25, 2013 5:26 PM
by w0014170
Replaced the crankshaft position sensor in the parking lot of the grocery store. Friggen car
Posted: Aug 25, 2013 8:01 PM
by oldskool
More Gorilla tape on the upper radiator hose for the E30. Cut and shortened it again so the fan will stop chewing away on it. Sheesh. Damn high-maintenance BMW.
Posted: Aug 25, 2013 8:43 PM
by Mike in Seattle
Posted: Aug 25, 2013 8:52 PM
by alabbasi
I had to pull my 88 Euro Mercedes Benz 560SEC and my Euro 79 450SEL 6.9 from the painter who was supposed to paint it he had had it for several months and when i went to see him, I found the 6.9 sitting outside with a flat tire and the window rolled down.
Nice guy, and I don't begrudge him, but it was appropriate for me to take them and put them in covered storage and look for alternative means (i.e myself) to paint them.
Aside from this, I replaced the door check on my 1997 Mercedes Benz E420 and along with the rear window regulator. The door check has been coming apart for a long time so not a moment too soon.
I was hoping to dismantle my spare M100 6.9 and M117 4.5 engine but I ran out of time.
Posted: Aug 25, 2013 8:54 PM
by ACHTUNG
Installed a new battery in the Highlander.
Posted: Aug 25, 2013 9:09 PM
by TSMacNeil
Installed some e38 basketweaves on the e34...(reluctantly)
Put a car cover over the M3 in the garage (reluctantly)
Posted: Aug 25, 2013 10:26 PM
Picked up the big piece of 1st 5er's new powa package today.
Well bought it, it should be at the house tomorrow night.
Posted: Aug 25, 2013 10:49 PM
by TSMacNeil
1st 5er wrote:Picked up the big piece of 1st 5er's new powa package today.
oooofff
I'm feeling love
Posted: Aug 25, 2013 10:50 PM
TSMacNeil wrote:1st 5er wrote:Picked up the big piece of 1st 5er's new powa package today.
oooofff
I'm feeling love
Another project, and she still loves me. So, yes, oooofff.
Posted: Aug 25, 2013 11:05 PM
by Ray's Classic
Currently waiting arrival of new gas tank pump for the M535i. Has the known symptom of reduced gas flow when cornering hard (often age related pump) or low fuel level.
New pump should sort it and provide better fuel pressure. Car has always given darn good mileage - partly because of its v.tall gearing.
Posted: Aug 25, 2013 11:22 PM
Yesterday was wash and wax for the E36 I can't seem to get enthusiastic about. Looks good clean and shinny.
Today the E12 went under the sponge and looks a whole lot better. Along with some shadowline touch up. And fixing the sunroof. Fuse, no. Switch, no. Relay??? Bingo. It's an odd design, mechanically latching, or is it cutout? Either way odd, and the same as E28s. Yes, of course I had a spare.
Posted: Aug 26, 2013 10:48 PM
by jkarr
Took the starter off of my F100 to diagnose an awful grinding noise and inability to start. Discovered it was the ring gear on the flywheel. Wept silently as I realized that it requires a transmission pull to repair...
Posted: Aug 27, 2013 12:24 AM
by cddallara
Audio is finally happening in the wagon.
GAS 10 channel crossover
Ppi amp
GAS e34t10 sub box
Don't ever, ever buy a Becker radio.
Posted: Aug 27, 2013 12:34 AM
1st 5er wrote:... it should be at the house tomorrow night.
We made it.
to a couple of good friends.
Posted: Aug 27, 2013 9:22 AM
by djazz
You have more projects than I do.
Style 65s?
Staggered?
Do they need a home?
Posted: Aug 27, 2013 9:34 AM
by djazz
On another note I found at least part of why the beast has a shifty rear end through high power curves. The guide rod boots look like my mastiff has been chewing on them and wishbones are on their way out too.
I don't want any surprises in 52 days, 9 hours, 22 minutes, and 4 seconds.
Posted: Aug 27, 2013 9:38 AM
by jhall
Fixed leaks, replaced drier and recharged the A/C in the 7. I tried pulling gas into the low side first. She would only take a few ounces. So I flipped the tank and went in liquid, took a good pound, but then stopped taking refrigerant again. Luckily it tripped the lpco, so then I throttled the car to draw it down and metered in the rest of the charge. Result, Ice cold A/C and a lake underneath the car everywhere I stop. Just in time too, because this week... its hot...
Also replaced the water valves on the 7 with a salvaged set and fixed some frayed wires to the valves. This stopped the heat coming out of the defroster vents and footwells.
Removed the dash vent and looked down at my mixing motor flaps. The passenger side seems to be stuck half way. So my next order of business is to remove the center console and try to mend this without tearing out the dash.
On the bright side I think that is my last HVAC problem on that car, so all should be well until something else breaks.
Posted: Aug 27, 2013 12:12 PM
THIS ^^^
Couldn't resist... "Is it October yet?"
Posted: Aug 27, 2013 6:16 PM
by leadphut
Finally started working on my MG. After learning the correct way to wire the points and condenser, she fired up and shot a bunch of bird seed out the tail pipe. It's as if a small animal had made a home.
Next I need to bleed the brakes and clutch and then take her for a spin.
Posted: Aug 28, 2013 12:11 PM
by davintosh
Last night I considered adding another one to the stable. A '98 M3 came up on the local CL for cheap, so the wife & I went to take a look. Not worth my time.
It seemed to run well and drove without any surprises, but it had been repainted a weird non-original color and had oodles of little glitches about it that made me think "don't want" from the get-go. For example, I went to open the driver's door and the trim around the handle kept me from opening it. I opened the passenger door and the door trim fell off. I asked the guy who was showing it (who was not the owner) whether the sunroof worked; he said yes, so I opened it, then it wouldn't close. Good thing it wasn't raining.
I was the first one to look at the car, and walked on it. The kid who was trying to sell it seemed really disappointed. He even texted me three times afterward telling me that he figured out a few of the glitches (including the non-closing sunroof) & got the squeaking from under the car to quit. Sorry; looking for a car, not a basket case.
I was going to link the photos that were in the CL ad, but this morning it's gone. Maybe I hurt his feelings.
Edit: It's back, and $500 cheaper than it was before.
http://siouxfalls.craigslist.org/cto/4028351707.html
Isn't that a lovely color?
Posted: Aug 28, 2013 4:08 PM
by leadphut
I think you're fine. I would never own an e36.
Posted: Aug 28, 2013 9:06 PM
by alabbasi
That's a great car to put a grin on your face without having to go a million miles an hour. I rebuilt a 73 B convertible a few years ago (seriously, I sprayed it down with glue and drove it through the moss catalog).
Sadly, every time i took it on the highway, I felt like someone was trying to kill me so I sold it and bought an 84 Mercedes Benz 500SL. Not as much fun behind the wheel but it has enough power to get you out of hairy situations.
Posted: Aug 29, 2013 12:55 AM
Clamped 1st 5er's #5 injector hose on both ends.
Easy peasy with the intake runner removed.
