FUBAR 528e, Gauging Condition of the M90
sail_or_drive
Re: FUBAR 535e Build 12/18/17 BIG UPDATE many pics
Post by sail_or_drive »
What a great story! Props for doing the engine swap, that's big time courageous for a first car.
thugginrobby
Re: FUBAR Bronzit 535e Build (6/29 RTAB done and vid thing)
Post by thugginrobby »
LeiseyJr wrote:
thugginrobby wrote:Time to replace that 528e badge with a 535i ;)
535e maybe but never 535i, it will always be an eta in my heart.
How long did the swap from an m20 to m30 take you? Was there anything major about the swap? Very interesting build thread
LeiseyJr
Post by LeiseyJr »
It didn't take too long if you have all part it is a easy weekend job. It took us awhile because, we had to Frankenstein a transmission. The major part about the swap is you need a 535i, basically. It hurts we parted out a good 535i, if I were to do it next time I would part one in a wreck or a rotted out one. The next major things are tapping the intake manifold as well as welding the correct coolant tank expansion bracket. The swap is essentially plug n' play, need to make a sticky.
LeiseyJr
Re: FUBAR 535e Build 12/28/17 Blew Up Dogleg
Post by LeiseyJr »
I've had a fairly loud rumbling in my transmission, and Christmas night at like 11pm ish the layshaft bearin blew up. Pretty funny stuff, in my transmission that cost about triple what I own right now. Anyway though, I dropped mi novia off and then was driving home and a straight cut gear sound started happening intermittently, then BOOM. Pics of carnage below
Fluid:
ImageDegleg Adventure by samleisey, on Flickr
Drain Plug:
5th Gear basically tried to eat the bearing and yeah...
TRans is Fubar, all it needs is layshaft and input shaft. Everything else is perfect, but chances of finding dogleg core are slim.
LUCKILY I HAVE A $5 SPARE, and it is being assembled and we will see how it does.
knunger
Re: FUBAR 535e Build 12/28/17 Fubar'd Dogleg/Dogleg Rebuild
Post by knunger »
That's one helluva set of sacks you're swingin' there, son.
Keep it comin'
LeiseyJr
Post by LeiseyJr »
So yeah blew up dogleg. I have had a core dogleg, that I have been slacking to fix, and now of course I am forced to fix my spare. This was the 1st dogleg I happened to find, the guy I got it from said it was a G262/5 and would trade for a M50 dipstick tube and dipstick. The guy put no effort into trying to figure out what he had and I gladly made the trade. It is actually believed to be from my fathers E30 M3 many years ago and was traded around and forgotten about. Anyway, when I ended up with it, time had happened and it wouldn't go into reverse and the mounting tab was broken. A month or two after I stumbled on the Euro E24 adn acquired the dogleg, bell-housing shifter, and D/S to put in my car. Since that trans went through all the gears I through it all in straight from junkyard 180K, and out put fresh fluid. As you can imagine someone that junked a slicktop euro E24 with cloth recorders, dirty motor, lsd and dogleg probably didn't do frequent transmission fluid changes. Despite this I used it like I stole it, tracked it, drifted it, clutch kicked it, and it was leaking some fluid. I stayed on top of that, but none the less the notorious dogleg rumble came and went away when I put the clutch in. I told myself it was input shaft bearing and normal getrag rattle. It went on 11pm of Christmas night, had to get towed.
So my spare transmission needed to get fixed. I printed out factory service manual, put it in binder and got to work. This would't have been possible though without dad as he has manufactured a couple special tools. I also learned to weld, he designed stand and I welded it together. This was the first step to work on these boxes properly.
ImageDegleg Rebuild by samleisey, on Flickr
Than to verify damage to my junkyard special
*sigh* Yeah dogleg has been Fubar'd.
The front case had already been taken off my spare, when I started to rebuild it but then stopped. So all I needed to do was remove back case, fix reverse, 3rd was acting up now and get tab welded on, through the grapevine I found a small restoration shop that would do it. Dad machined a tab and the guy at the shop would do his magic.
That is much better, than it was just a matter of reassembly. Reverse was messed up because trans was sitting around so moisture froze up reverse detent and 3rd gear syncro just got a little jammed up fro us moving it around. So those were pretty simple
This is very tricky as you have to hold down ball bearings and spring through a tiny hole, while pushing in case on to and making sure reverse idler spacer thingie is lined up AND making sure guide pins Dad machined don't bind up. Didn't really get pics, as I was focusing.
This is what it looks like on paper with shift rods and detent, ball bearings are highlighted in black dots.
ImageFun stuff by samleisey, on Flickr
This is what real life looks like, As you can see there is not a lot of room to maneuver and you have to push balls all the way down and then push case at same time.
That was fun, once that was done, I was very happily to see that all 5 gear worked. I hate RTV and gasket was sketchy. So I unfortunately had to use RTV, as my Nana says, "If a little is good, than a lot is great."
Now I am waiting on input shaft and layshaft bearings, in the meantime I installed a new chip and strut brace.
Car is almost running again, and if anyone knows of a core dogleg let me know.
Re: FUBAR 535e Build 12/30/17 Dogleg Rebuild
You are a lucky boy. Growing mad skills. Thanks for letting us follow along.
Let us know how you like SSSquid's B34 chip...
LeiseyJr
Post by LeiseyJr »
tschultz wrote:Let us know how you like SSSquid's B34 chip...
Well finally put car together and breaking in trans, the new chip seems to run a lot smoother through the whole rpm range. Not sure if it pulls as hard, but that might be beacuse powerband is so smooth that on cam feeling a I use to have is gone so. Overall though a lot smooher to just drive around.
LeiseyJr
Post by LeiseyJr »
Dogleg is working!!! Did 160ish miles tody so far so good just trying to gently break in the bearings, it shifts nice and is quiet, gonna change trans fluid soon and than really test chip at WOT.
Strut Bar made a big differernce as well even passengers noticed rides smoother less crashy over bumps and feels different cornering.
LeiseyJr
Post by LeiseyJr »
It's still shocking that I took part the Getrag 265 CR and put it back together, but it's doing well so far. The Korman chip is superior, SSSquid is smoother but for performance driving I plug in the Korman chip. You can tell they put a lot of time into their tunes, but I feel like they lack M30 experience, so they didn't extract as much as Korman did. I also finally found center caps, the E38 style 5 centercaps have always been weird looking on my car. You can tell they are for a round car. I put in E34 Style 5 center-caps on and I prefer them 10x over on my non-bumper car.
ImageIMG_0779 by samleisey, on Flickr
ImageIMG_0828 by samleisey, on Flickr
ImageIMG_0834 by samleisey, on Flickr
Trackday is coming up soon, or an open lapping day Anyway. PFC 06 pads will be going on and I'll see how she does. On same old D102's as I can't afford anything better right now for rubber. Should be fun as always though
LeiseyJr
Re: FUBAR 535e Build 3/8/18 Stayin' Alive
Post by LeiseyJr »
https://youtu.be/_rks1sr1NZE
Car did great other than I need to fix ABS, I flatfooted my RF so bad. It's just handy especially when learning this track which is not just dedicated, fun corners but technical and tight. Rae pads only on the front moved bias way to far forward as well but still good fun. Also, the fucking oil leak is still a disaster, and I will have to remove the transmission yet again. It's the back of the head. I DONT GET IT.
Got a job at discount tire, getting ready for college, trying to pass AP Calculus, so much fun stuff.
lizard
Post by lizard »
One of my favorite threads. Wonderful to read about a young man and his car.
Burnze
Post by Burnze »
This is awesome, love the pictures. Keep up the great work.
LeiseyJr
Post by LeiseyJr »
I've been trying get the 80's race car look on my daily driver because I just think its cool. So I did a mono-wiper thing to really take advantage of my rebuilt wiper assembly, just removed passenger wiper and placed the drivers wipe on the passenger spline thing. That way when Hurricane Harvey happens I'll be blind but cool at the same time. If it's really bad when it rains I will change back to stock for others safety.
ImageIMG_1060 by samleisey, on Flickr
ImageIMG_1061 by samleisey, on Flickr
ImageIMG_1013 by samleisey, on Flickr
Plans in Order of Importance:
-Stop Oil falling on the ground
-ABS
-Hankook RS4's
-Race Pads ALL AROUND
-Obtain Replica Euro bumper from CEP
-Mount Front Euro front federalization to CEP bumper
-Get Adapter Brackets
-Make or find a front lip or spoiler to rip off on Houston roads
-Skid Plate
LeiseyJr
Post by LeiseyJr »
Tried to install camber plates Dad also rewelded my broken swaybar mount that I ripped out sliding on backroad, camber plates were a massive fail. I told myself steering would stop binding for 30 miles. Hopefully Turner gives me a refund
ImageCamber Plates and Sawybar shit by samleisey, on Flickr
I than installed an airdam, very happy with how car looks other than rims. Hopefully I will source 16' cool rims, would like Riken Meshes.
ImageAirdam Thing by samleisey, on Flickr
Also tightened rear swaybar and it handles beautifully now. It drives so well, with just one adjustment. PFC 097 is ordered and 08's will be ordered for the rear. RS4's are seeming harder and harder to get it but I will save for them. Prom also happened so that chapter in my life is complete and still working way to hard at Discount Tire.
Re: FUBAR 535e"s" Build 5/7/18 AMERICAN BUMPER RETURN
How do you like the headers? I have heard they don't do much to a stock B34...
LeiseyJr
Post by LeiseyJr »
tschultz wrote:How do you like the headers? I have heard they don't do much to a stock B34...
It helps it breathe with cam And I love the way my car sounds. They look cool and ceramic coating is quite nice. Only thing I dislike is the way my muffler guy welded the flange to it but its fine. In short, I like them a lot for sound.
LeiseyJr
Post by LeiseyJr »
Update, car is doing well for the most part. Slave cylinder went out and I had to drive to work and home without a clutch, learned that and how to shift without a clutch. That was fun. On to brighter news I have finally gotten a full set of RS4's, race pads all around and Recaro Profi. The seat and the tires are a very important accomplishment to me because I've always wanted though and I actually worked towards those goals and got them. Brake pedal is now grip taped due to the original cover falling off. Life is going well, just working at Discount is a lot of hard, fast paced work but its paying for all this stuff before I go to college.
ImageIMG_1699 by samleisey, on Flickr
ImageIMG_1734 by samleisey, on Flickr
ImageIMG_1705 by samleisey, on Flickr
ImageIMG_1950 by samleisey, on Flickr
ImageIMG_1928 by samleisey, on Flickr
Also the oil leak is fixed
LeiseyJr
Re: FUBAR 535e"s" Build 6/26/18 Racer Boi update
Post by LeiseyJr »
https://youtu.be/hdkbEFkyogE
Finally got some time to take it out this morning brought my helmet just to capture some moments. Just drove around and explored, found a new dirt road. Despite this cars visual flaws, mechanically it is fantastic. I can't wait to drive some events with it in the fall.
LeiseyJr
Post by LeiseyJr »
I TRACKED MY JUNK FINALLY!
I need camber in the front, its eating shoulders but I just ignored it. I will be ordering Irelands Adj. street camber plates, I dont need much and those should do it. It was also running really hot, discovered a had a little coolant leak a day later. I was topping it with water for last 2 sessions and it was super close to the red. I should've been more concerned but I had to just drive before being trapped in a door room.
This vid was my 4th session going this direction on the track, and MSRH is a lot better going CW. Car felt at home, and I am super happy with how it did. It will be parked at the house on lift while I am trapped in downtown Houston at U of H. My plans will be to take it to events whenever possible and once I get camber plates car is in a place where I can pack it, drive it and go home. Which is what I wanted it's finally time to just drive the shit out of this bitch. Hopefully next summer I can get another Internship type thing to buy a E46 330, or E36 M3 as a daily.
https://www.youtube.com/watch?v=jDgJuc7-wvc&t=637s
Oh yeah I put in Moosehead UCAB and it made front end way stiffer, Houston streets are brutal now. I really ruined this car as a daily, its my fault but fuck is it fun to drive on track.
LeiseyJr
Re: FUBAR 535e"s" Build 8/13/18 Getting Seat Time!
Post by LeiseyJr »
LeiseyJr
Post by LeiseyJr »
ImageMSRH 2018 by samleisey, on Flickr
This thing looks like shit, but I am fucking proud to say I built this junk.
LeiseyJr
Re: FUBAR 535e"s" Build 9/4/18 VINTAGE Steering Wheel
Post by LeiseyJr »
On track, I was having issues with the Mtech for my short arms it was just to big. So I've been looking for something smaller, my range was 350-360mm I was looking at Nardi, Momo, Sparco and one of Renown wheels. The problem is I no longer have an income, since I am doing full time college in a dorm. This whole steering wheel thing has been bugging me for awhile so I just needed to put something together cheap to make sure smaller was what I was looking for. I somehow found a used hub on Ebay for $40 its a real Momo one. It needed the horn wire repaired, and its missing the rubber cover thing. I bought that since I knew I was going to be replacing the steering wheel, plus it was a good deal. Then I was just waiting for the right wheel, I was looking around on Ebay for awhile and finally came across this junk.
ImageBWA by samleisey, on Flickr
It looked cool and bigger in the picture, very vague description but it was $100 and had a horn button. I impulsivly bought it due to price, and I already had a hub. It should bolt on right? LOL When I actually went back and looked at the pictures, I counted 5 bolts. That was funny. I then bought a Grant Adapter Momo 6 bolt to 5 bolt thingie, which still hasn't come in. Thanks Summit! Anyway Dad drilled holes in my used Hub and tapped them to mount it in. I was very worried about this though, and wasting my money.
I posted on some Facebook Groups and found out this thing was ancient, it's at least 1980ish, maybe older. BWA is the make of the steering wheel, and it is their Gamma model. Which was verified by some old ads I found. They came in a 13" and 14" size, which is bascially 330mm or 350mm, I would like 350 because 330mm just blocks every single gauge. I know this because I got stock with a 13" one, overall though I love how thick the wheel is. It is a little bendy at the top but due to age and I don't know what life it lived before me it's understandable. It does block my speedo but the smaller wheel makes it a lot easier for me personally to drive.
https://www.flickr.com/photos/132920043 ... datetaken/
The wheel is beat up, but it is amazing the horn button, original hub and bolts which came with it when purchased new a long time ago has stayed with it. I think it was a cool find, and I will make sure it lives on. I will restore it once I am sure it will be in there a long time. I will most likely look for a 14 inch though. This piece of shit car will never be done, next post will probably be converting fronts to coilovers just so I can get camber and lower front 1/2 inch. Stay tuned!
LeiseyJr
Re: FUBAR 535e"s" Build 9/4/18 Budget Euro Front?
Post by LeiseyJr »
I still have never liked the 535is front, so this will be an attempt to do the front end how I've always envisioned. First you have to rip a perfectly good car apart.
ImageBoredom by samleisey, on Flickr
Next you find a style youre kindve going for
A forum member here luckily has the Pfeba spoiler thing/airdam whatchamacall it I am looking for. Which will be on the way soon enough, and cheaper then the $600 Classic Euro parts wants. I then needed a early front valance, and Sherman gave me rusted out one for free which is not only early but it's euro. I am also lucky enough to have a father that will repair all the rust, as I probably would've hacked it together as is.
My plan for the front bumper is I have a mangled E23 front bumper and I have the chrome pieces and will cut and trim to fit, but I am missing a corner. Still unsure what to do about that, but I will figure that out. This will go over another thing from Shermans scrap pile which is an E28 Federalization bar. If the E23 doesn't work, I can get a plastic bumper from Classic Euro Parts.
I also sourced Euro Turns for $40
ImageBlink 182 by samleisey, on Flickr
I have a left on the way as well with a lens for $50, so I need to buy the right lens. At least now I have fairly junked housing that I wont feel bad cutting up.
Hopefully this goes okay
Classes are going fairly okay, and I'm in the process of being rehired on Saturdays for Discount.
Re: FUBAR 535e"s" Build 9/11/18 Budget Euro Front?
Curious to see how this comes a long. I have seen a lot of budget versions that end up never being completed. I have often wondered about e24 bits on E28, and I supposed E23 could fit similarly well if shortened and customized slightly. Worth a try with the price you got those parts for.
Personally, I think the 535is/M5 spoiler set up is pretty good looking. It's the non-spoiler US cars that bug me, mainly with the front bumper sticking out so far...
LeiseyJr
Post by LeiseyJr »
tschultz wrote:Curious to see how this comes a long. I have seen a lot of budget versions that end up never being completed. I have often wondered about e24 bits on E28, and I supposed E23 could fit similarly well if shortened and customized slightly. Worth a try with the price you got those parts for.
I liked the look but my frame rail is a bit crooked, so bumper was crooked this also meant I could not tuck it because it was all wonky. The E23 center chrome piece is the perfect bend, the side pieces have the right curve, just need to be trimme d. It's a shame I am missing one it'd be way easier with the other side. Hopefully Ebay Saves the day.
LeiseyJr wrote: The E23 center chrome piece is the perfect bend, the side pieces have the right curve, just need to be trimme d. It's a shame I am missing one it'd be way easier with the other side. Hopefully Ebay Saves the day.
Which side do you need?
LeiseyJr
Post by LeiseyJr »
1st 5er wrote:
LeiseyJr wrote: The E23 center chrome piece is the perfect bend, the side pieces have the right curve, just need to be trimmed. It's a shame I am missing one it'd be way easier with the other side. Hopefully Ebay Saves the day.
The left side, and only a right side on Ebay :laugh:
LeiseyJr
Re: FUBAR 535e"s" Build 9/23/18 Getting there..
Post by LeiseyJr »
Found the left side, mocked it up and stuff. Still waiting for Euro Turns from Germany as well as a lens from Schmiedmann , and Pfeba front spoiler. I am also unsure of whether or not I will be using the Federalization bar. It will be a lot easier to mount chrome to valance. However Federalization Bar, will allow for a bumper on the front. So... we will see how that goes. I'm basically waiting on parts when I have everything and can make a full game plan
ImageMock Up by samleisey, on Flickr
