Fluke 88 and a carb tuner!! I should come down I-64East to see ya so we can do mine ...Pattonky wrote:I just got through syncing my throttle bodies with a carb tuner. Only 1 and 6 were off at all. 1 was a little high and 6 was a little low. This made a big difference in the idle. The car seemed to kind of cycle before the adjustment and the idle fluctuated from about 870 to as high as 1050. After adjustment she rides more steady between 890-950. I don't think the adjustment of the throttle bodies altered the RPM so much as it allowed the motor to maintain a more constant rpm. RPM taken with Fluke 88. I suppose I am just kind of posting with the hope that this might be useful info to somebody.
Balancing S38 ITBs
- Location: Hidin' in a bowl of rice ready to put a cap in an a$$
Re: Balancing S38 ITBs
Are you having trouble with your idle or are you just pulling my chain over the tools to do the work? I will confess that I am a believer in having good tools to work with when I do something.
Dean,
I was lucky enough to meet Alim this summer, who lives in ABQ. I am in Santa Fe for the summer. He currently is tuning his throttles using your Mantis. We threw it on my car, which runs very well. The throttles were very uneven and after 5 minutes of adjusting them, it was amazing. The thing runs like a scorned dog! What a difference. I cannot thank you enough for sending this thing around. Now we are working on Alim's car, on which we have some baselining to do over this next week.
Many thanks,
jeff
Many thanks,
jeff
Thank you Dean. I just finished getting my throttles adjusted too! Worked out very well and I did notice a difference at idle and just off idle.
The Mantisometer was simple to set up and use - genius idea! Thanks for loaning it out.
I have some pics and videos here: https://www.dropbox.com/sh/sh8u2e3g8gmu ... ZISJa?dl=0
Great to hear that it worked out. After getting it back I replaced the tubing as it started to yellow and took it and my M5 to the SoCal Vintage BMW meet for a little show and tell. Hooked it up to a couple S38s but the owners weren't brave enough to turn any screws. I don't blame them. Parking lot tuneups never end well. You really need to work through the mechanicals (valves and throttle plates) first. This is the last step.
It was sent to Matt - Defacto in CT after the show. UPS says it arrived on the Oct 13th. Matt, if you see this message, or the PM or my email, can you confirm that you do indeed have it and let me know when you are planning to return it.
Of course if you have any questions post them here or PM/email me.
Thanks,
Dean
Thanks,
Dean
Hi Dean - if it's made it out to the East Coast and doesn't have another date booked, perhaps I can pick it up from Matt and go through the process with my e28. Maybe even the Touring? Should be physically the same process, I think.....
Maybe get a balancing-fest together? November gets relatively open, in-between sports seasons for the kids means the weekends open up a little.....
So I'm done with the use of the Mantismanometer on both the e28M5 (s38B35) and the e34 M5 Touring (S38B38), and it went very well! I went through cleaning the needle valves and new orings, valve adjustment and butterfly settings in the run-up to the Mantis' arrival. I had also roughly set the vacuum on each intake with a gauge - new Oring, full-tight, then out one turn, then set to a rough-bouncing-about-9-inches-of-vacuum with a gauge and a pinched hose. Even that was an improvement for both cars. Then with the Mantis local and a couple of decent weather days I got the real balancing act done.
The touring started fairly balanced right from the rough-set of one-turn-out. On the e28 I did end up moving the screws more than I thought I would to attain leveled readings. The e28's screws were highly variable before I removed them, two almost totally closed and one about 1.5 turns out (that was the factory set with yellow caps). Position isn't what matters, the level of vacuum is, but it did seem strange that there was so much variance in how tight the needle was set.
Also, I'm really not sure what I was smoking, but I did connect the hoses 1-2-3-4-5-6 front to back on both cars, and I'm almost certain that when I adjusted the touring, the cylinder 1 port moved the right-most line of fluid, and on the e28 it adjusted the left-most.
Either way, I got both cars nicely set. The e28 in particular is now more manageable on-off throttle than it had been, and has back all of the immediate off-idle 'pop' that it had been missing after a tank of bad gas on the way home from TedFest in June. It's FAR smoother idling around at parking-lot speeds, and even sounds better. The B38 in the Touring is a far different engine management, which may be why the difference is not *as* noticeable, but there is still a notable improvement all-around.
Really great tool, and MANY THANKS TO DEAN for making it available to the community!
If there is anyone relatively local (NY Tri-State) that wants to do a round of tuning please let me know ASAP. Dean has someone lined up on the Left Coast as the next destination. If I don't hear from anyone semi-local in the next week or so I'll send it westward-ho!
Now that I have finally finished with the exhaust, and purchased all the requisite other bits means I actually should probably do this...
What is the current schedule for the Mantismanometer?
Any chance to get a hold of it before the Vintage?
Ben,
chances are good. It is ready to ship. Send me your contact information (real name, shipping address, phone number, etc) off line and I'll get it in the mail this week.
I have had to refurb the unit a few times, so if I am pivoting off the free rental program to now include a use fee to cover incidentals.
2017 pricing is as as follows:
$25 to get it shipped out.(USPS) plus,
$100 deposit (includes use fee) for a total of,
$125 due at time of rental (pal pay to healeybn7@yahoo.com)
Two week rental time unless agreed-to up front.
You will have to pay for shipping it back to me and when returned, you will receive $75 back on paypal.
I can send you an updated pdf that includes corrections and tips from others. Be sure to read the pdf before ordering the Mantis as you may want to have a set of o-rings on hand before starting. This is the last step in the tuning process, so valves should be dialed in before hand as well.
Dean
Dean
I will not need it before the end of April, so it doesn't make sense to get it this exact moment.
Hope a couple more people can squeeze in before me. End of April/ beginning of may would be perfect. I will keep following in here!
If you set your throttle plates ahead of time, another option is to meet up at Vintage (assuming it is the So Cal Vintage in Woodland Hills) and tune it "live on the grass".BenGerman wrote:I will not need it before the end of April, so it doesn't make sense to get it this exact moment.
I just wanted to clarify my thoughts about the change in deposit. The ~$20 use fee isn't intended to discourage anyone from borrowing the tool. After paypal fees and rounding it probably nets to $15 and I would be happy to reconsider if with a little encouragement.
It has been borrowed a lot over the past few years. Shipping is supposed to be smooth but stuff just seems to happen to it as it moves around.
There was a time where the unit was dropped off at a UPS store, mislabeled and sent to the wrong address. Thankfully I received a box of jerseys that were meant for someone else and we eventually exchanged packages. And then there was a time when the box arrived open and the dial indicator was missing... and then there was a time when the oil cap wasn't screwed on and it looked like a box of donor organs...
Let me know what works for you. Happy to help.
Dean
I know it´s been tow years since your post, but I´m just getting to adjusting the ITBs in my E28 ///M5; which by the way it´s the only one in existence in Colombia, South America. It´s been kinda rough restoring this monster due to the unavailability of parts, not to mention knowledge about this specific subject. Anyway, I want to thank all those who took part in this conversation; I was delightfully enlightened on the subject. By the way, I have installed a Megasquirt II module.
Just a quick update on the Mantis Manometer.
Since putting it together a couple years ago and making it available for enthusiast use, it has been in almost constant circulation. It came as a surprise to me that some of you would like to have your own manometers, so I built a few for enthusiasts and shops.
The current "rental unit" was refurbished a month ago and I guess it was nice enough that the techs at ACE Performance convinced the boss to buy it instead of sending it back.
Yesterday I ordered enough supplies to make three manometers. I'll keep a rental unit in circulation, build one for myself, and offer one for purchase. While it is a simple device it is time consuming to assemble as a couple parts require machining.
If you are waiting to borrow the tool, Jason Rhee is next in line and will receive a brand new rental. If you want to buy one, check back shortly and I'll post some photos of a finished product and hopefully have a good handle on a price.
Thanks for your support,
Dean
Dean
- Beamter
I would be interested in owning one of those and would happily pop them onto the Moosehead site for you to sell if you wanted.
Paul,
Wow. That is very generous. I'll get cracking on making a few and PM you shortly so we can chat about small print stuff.
Dean
Dean
Great product. Extremely well made these will sell to the S38 enthusiast community very well
Would like to hop on the list to get the Mantis Meter, really could use it.
PM sent. You are on the list, second in line, but you can buy one and skip the queue:)Valve_clatter wrote:Would like to hop on the list to get the Mantis Meter, really could use it.
Dean
The new Mantis Manometer is just about ready. Here is a sneak peak before I pack it for Jason.
The R2 version now comes "factory" vacuum tested and calibrated to -292 mBar or ~8.5 inHg. A fill line location is now indicated so no guessing on the fluid volume, and a more compact light weight design should allow you to get it closer to the car. With the preset calibration it will be easier to achieve BMWs average ideal intake specification.
The loaner tool which you are viewing still comes with the breakable hinge pin for easy USPS shipping, but I am assembling a run of tools that are mounted to a single board and can be shipped in a shipping tube.
I am pretty happy with this final design. I'll post some close up photos once they are officially for sale via Moosehead (and yes I still need to call you).
Thank you everyone for your ideas and feedback. We made a good tool together!
Enjoy,
Dean
Enjoy,
Dean
Fantastic. If you end up making enough to offer through Pauls' website, I'd be grateful to help make those mantis' legs stretch across the pacific. It would be nice to have one in circulation around Australia and I'll be in need of the tool very soon so please keep me posted. Literally.
Father's Day proved to be a productive time to work on the Manometers.
So I already have my own 'home grown' way of doing this but I'm tempted. You have done a nice job including the design and name. I would probably balance much more often and mine is probably due.
Does it need to have the height you used or is that just in case one is left open so it doesn't suck all the fluid out ? In other words if you had a way to prevent an accidental open tube couldn't it be much shorter and shallow fill level? Is that something you have tested for? And I assume it will work just as well if you plug three and just use three (Triumph Triple) or two or four, other motorcycles for example.
At work a couple of us are working on what started as a bootleg project idea where I made the first few sets of parts on my lathe at home. Now it's got drawings and a machine shop making the first parts and we are talking to others for packaging and assembly. We don't know if we will sell hundreds or thousands but it's really more of a service to our customers and it is fun to see it take on a life of it's own .
If you can tap into the right outlets you might go into production yourself.
Dean,
Thanks so much for making these. Put me down for a purchase of one. Are they available yet?
best,
jeff
best,
jeff
It is 32" tall. There needs to be a bit of height above the fluid level in the event the ITBs are wildly out of balance and the small tall tubes allow the vacuum to pull the fluid up far enough to make adjusting easy. I am assuming that all tubes will be connected and there will be a plug on the fill tube. There are multiple warnings in the instructions. Worst case is you draw in some oil and refill the manometer. I would think that wouldn't happen more than one time. I haven't done it yet, but I suspect it would be a "leaning experience". It is one of the reasons I decided to use Marvel Mystery Oil instead of a water based fluid. You never know.tn535i wrote: Does it need to have the height you used or is that just in case one is left open so it doesn't suck all the fluid out ? In other words if you had a way to prevent an accidental open tube couldn't it be much shorter and shallow fill level? Is that something you have tested for? And I assume it will work just as well if you plug three and just use three (Triumph Triple) or two or four, other motorcycles for example.
I don't see why you could not use two, three, or four of the ports and just plug the other two. I have a set of Jenevy style ITBs on our Ford Zetec/Europa. I am planning to use it once I create vacuum ports. It should prove pretty universal.
To calibrate the tool the amount of fluid in the fill tube is critical as it the amount of sealed air above it the fill fluid. The tall tube makes it easy to add just the right amount. If you look closely at the photos you see two different fill tube heights. That was due to a small difference in the ID of the fill tubes. I suppose you could use a shorter fatter hose, or a small cylinder in the manifold, or make a larger manifold with a large capacity for reserve fluid.... Hmm.
It would be very exciting if these take off and I have to look for a manufacturing source. Congratulations on your project!
Dean
For those interested Mantis-Manometers are available for sale at:
http://www.mantismanometers.bigcartel.com
You will have an option to purchase just the manometer or the manometer plus the dial indicator with ITB mount. Price includes shipping.
Thank you all for your support and enthusiasm.
Dean
Dean
If you tried to contact me through the web site, we just updated the bigcartel-Manometer email address and added payment options for Paypal/Visa/Mastercard/etc. We should be good to go for real orders. If you have any questions or concerns, please reach out via PM or here. I'll keep a close eye on mye28 to make sure we don't drop the ball in any way.
Thanks,
Dean
Thanks,
Dean
I'm in.
Thanks for doing this.
Fantastic. Dean can you please pass on package dimensions and weight so I can get an estimate for international shipping? As your website doesn't support international shipping I'll have it shipped through my freight forwarding address if it's not viable to ship via a US based friend of mine. Thanks in advance!
I just could not figure out how to enable international shipping. Thanks for hanging in there.
The best packaging I found is through a USPS medium shipping tube (or triangle). It is 36"x 6"x 6". Weight 3lbs without the dial indicator option. Getting the weight down with this new design should pay off with shipping savings for everyone!
The box says it is for international shipping...
