Dieselboost's 524compoundTD
about my car or my friends car?Zubcho wrote:Pls give as some pics and more info about the upgrades you have made.
http://irc-galleria.net/user/Laskeuma/picture/104062814
this is from my friends 524TD
About your carDieselBoost wrote:about my car or my friends car?Zubcho wrote:Pls give as some pics and more info about the upgrades you have made.
ok.....
chassis front
-Koni sport adjustable shock absorters with cobra 45mm lowering springs.
-all powerflex urethane bushes
-all arms replaced with new ones
Chassis rear
-Bilstein new stock shock absorters with cobra 35mm lowering springs
-Powerflex urethane main bushes
-differential is from 520i and it is quite short
Engine
M21D24 from 1991 324TD
engine is refurbished, exception block which is opened only for replacing oil pump with new one.
cylinderhead is cleaned and valves and valve seats are machined, surface is machined.
stock head gasket gemented with vht copper gasket gemetn.
stock head studs
stock cam with timing littlebit earlier.
injection pump with cummins 12mm rotorhead and cummins stock cam plate. and many fine tunes by Pp-Diesel
Timing is 1.15mm before tdc
-gearbox stock getrac 260 5
-Clutch sachsracing 240mm(m5) with stock plate
-528i solid flywheel (240mm)
modified intake manifold
Large intercooler and radiator maded by I Raatikainen
(Erikoishitsaus raatikainen)
stock (524TD)exhaust manifold with my fitting flange with exhaust temperature and exhaust pressure outputs.
Turbo
Master Power SUPER 70 F-2 REFLOW
Model: 802315-063
compressor: 56,5mm
compressor a/r: .70
Turbine: 58,5mm
exhaust a/r: .63
flange: T3
power: 350-490hv
3" downpipe and 3" straight pipe
exteriour
-Color Toytota 162
-Rims ? 17" 7" wide
-Tires hankook ventus k110 215R1745
-rear wing from opel ascona c irmscher
so... nothing very special included for this
there is about 200+?????? power now.
These mods with stock injection pump i had 191hp
now.... much more....
superturbo engine is underconstruction....and in ice...... until i get new job....
chassis front
Chassis rear
Engine
stock head studs
Turbo
Model: 802315-063
compressor: 56,5mm
compressor a/r: .70
Turbine: 58,5mm
exhaust a/r: .63
flange: T3
power: 350-490hv
exteriour
-Color Toytota 162
-Rims ? 17" 7" wide
damn... my wet dream
I need more money and bigger garage
In some day i will get a "real" diesel car for my diesel performance projects
http://farm4.static.flickr.com/3403/358 ... 4d7f11.jpg
This is little bit too bligbling for me..... maybe race truck look fits better to me
now im working with water/methanol spray system in my 524
only bad thing is that..... im totally broke...
so must use my creativity with this.....and freebie parts
this is my plan...
-two car headlight washer pumps connected in sequence to get about 4bar pressure.
- oil burner nozzle
-pressure Switch
-limit pressure valve
-self maded tank
-flow controller valve
to increasing water pressure i connect hose from turbo to water tank..
when pumps are making 4bar then boost make extra pressure about 2bar in tank..... i got allmost 6bar waterpressure
and nozzle fitted just before intake manifold
im not making this to get more power...... only to get exhausta/burning gasses little bit cooler and engine lasting longer.
this is my plan...
- oil burner nozzle
-pressure Switch
-self maded tank
If you want pressure...I suggest you don't use vane style fluid pumps designed for flow and volume. I would use compressed air to pressurize a sealed tank of water/methanol using a small and cheap air compressor designed for inflating tires to pressurize a tank with water/methanol inside.
One option, If you fill the tank with 75% mix and leave 25% air and pressurize it to something crazy like 9 or 10(135-140PSI) bar, it should have enough pressure to push the entire charge of mix out of the tank. You can use a fuel pressure regulator to regulate the pressure of mix leaving the tank if you need to.
Second option is more difficult and more expensive, use the same idea as above but leave the compressor attached, wire it up to a pressure shut-off switch that will limit tank pressure to your desired pressure.
Ok..... in finland we have used methanol/water injection for years..... and it works fine.... in our engines..... only point is dont put too much methanol max 30%Frybrid 524td wrote:Methanol injection isn't advisable in an IDI engine based on what I've read. I plan on adding just water injection at some point after turbo, I/C, and head upgrades.
only thing is that those small compressors cant take it.CoyoteStarfish wrote:If you want pressure...I suggest you don't use vane style fluid pumps designed for flow and volume. I would use compressed air to pressurize a sealed tank of water/methanol using a small and cheap air compressor designed for inflating tires to pressurize a tank with water/methanol inside.
and if you use those HEADLIGHT washer pumps which are larger.... they can make pressure..... one friend told that he has measured allmost 13bar pressure with those.
this system is what im going to make is used largely in here.
and it works.
and allmost all my parts are free.
i just got pressure switch for free.
Hay guys. I'm a total newb when it comes to diesels but I'm pretty comfartable boosting m20s. So just to be clear if I want a moddest increase in boost say 1.5 bar i'd just need to put a bigger turbo and a stronger internal wastegate? No bigger injectors or other mods. Sounds like the factory pump will handle the rest with no mods for my power goals.
yes.... no bigger mods..... only fine tuning with injection pump...einstein57 wrote:Hay guys. I'm a total newb when it comes to diesels but I'm pretty comfartable boosting m20s. So just to be clear if I want a moddest increase in boost say 1.5 bar i'd just need to put a bigger turbo and a stronger internal wastegate? No bigger injectors or other mods. Sounds like the factory pump will handle the rest with no mods for my power goals.
FWIW I'm planning to swap in some 4HP24 internals into my 4HP22 sometime this summer to beef it up a bit (That and my A clutch pack needs tending to).einstein57 wrote:Guess we will find out how much torque an auto can take
http://www.ashcroft-transmissions.co.uk ... oductId=51
Ok nothing new on my car.... but....
I just got back to home from dyno....
quite nice dyno run from my friends mb 190D over 380bhp and about 560nm torque
with water spray system power decreased about 5kw but this was only water.... not methanol/water mix
funny thing was when we was going to dyno, my friend tested his car and when 3rd gear was in..... suddenly BOOM!.... and there wasn't 3rd gear anymore.....
engine is basically unopened non turbo om603 300D engine
mods are
-garrett gt40 turbo
-holysmokediesel injectionpump with 7mm plungers
-large chinacooler
-special exhaustmanifold and 3.5" exhaust system
-special plenum
-devils own water/alcohol injection system
mods are
-garrett gt40 turbo
-large chinacooler
-special plenum
new st mercedes burnout video http://www.youtube.com/watch?v=NMP6FBJF6lQ
Here!CoyoteStarfish wrote:Oh DB, where art thou? Haven't heard from you in a while.
And unfortunately there is nothing new with my project
but i can tell few funny things with other cars
that 190diesel is now former one... engine exploded
but there is now new engine OM606 24valve turbodiesel with all fun stuff from old engine...
but it seems that my project is really on ice until i get that new job...
I love diesel...
I have a E36 ti (Compact) with a M57 swap (i am yet to complete)
but you can read through my thread on bimmerforums if you like..
i must get one of those 324 / 524tds engines to fiddle with..
i also have a Cummins 5.9 with a P7100 pump... makes about 350whp with the original turbo & injectors... it's unbeleiveable !
here's a link to my E36 M57 thread:
http://forums.bimmerforums.com/forum/sh ... ?t=1558481
and here's a picture of my Cummins truck drifting:
