Doable? It's brilliantBig Bronze Rim wrote:Totally doable.alijonny wrote:AHA! no MAF. hmm so a super cheesy BOV with duck call attached is totally possible?
My 535is Turbo Buildup Thread! - update 11/26//09
http://www.youtube.com/watch?v=W_Qul7MiImkatle28e wrote:Doable? It's brilliantBig Bronze Rim wrote:Totally doable.alijonny wrote:AHA! no MAF. hmm so a super cheesy BOV with duck call attached is totally possible?
Mildly amusing but damn that would get annoying.
Start by reading the FAQ. And no, the compression isn't too high. It's actually fairly low, at 8:1. My m30b35 is 9:1 which is still not too high for FI. Turboing your car isn't something you want to jump into without first educating yourself as best you can on the subject.777665 wrote:i also want to turbo my 535isn but was told that id have to change uhhlott of the internals of my engine because of its high compression is that correct i want to buy the parts this winter so it will be done by spring i have no idea how to do this what i need etc moses
Updates!
Just thought I'd throw up a little update on the car. About a month ago I upgraded my brakes to the 540i F/R setup. The stock brakes were in desperate need of replacing and just weren't up to the task of slowing down the car with all the new power. Front calipers were reman TRW units and the rears were used pulled off of a 740il. They were painted with Duplicolor caliper spray paint. I also addes a set of Speedbleeders. These are highly recommended! I upgraded to SS lines all around. Pads are Centric Posi-Quiet semi-mets (for those that don't know, Centric is owned by Stoptech) Rotors are drilled and slotted units from R1 Concepts. Very nice pieces, maybe not quite Brembo quality but nice nonetheless. They have a nice anti rust coating and over a month later not a lick of rust in site on the hat or vanes.
All I can say is that I am amazed by the performance of the brakes. Initial bite is fantastic and the pedal has a nice firm feel. Modulation is now much easier. I feel that the SS lines also contribute and are a great upgrade, even to a stock system. Overall stopping power is excellent, but I have no quantitative testing to report. The Centric pads are very nice and are very low dusting. The dust they do make is more of a silvery grey and is less noticealbe than "black" dust. I will give some more long term feedback on them as time passes.
The next upgrade was to the suspension. Having ridden in LJ's (Nebraska_e28) car with Spax springs and Bilstein sports, I knew that was the setup I wanted to go with. The ride is very firm but composed and easy to live with on a daily basis. I replaced the front swaybar endlinks and reinforced the sway bar mounting tabs on the strut tubes to prevent them from failing when I upgrade bars. I also repalced the rear dogbones. The car now handles the way I feel it should. It's more fitting to the rest of the performance of the car. I only have some pics of the components but will be getting so fresh full body shots of the car, hopefully this weekend.
Here are the plates I made to weld to the strut tube.
And here is current engine bay shot for good measure.
- Beamter
- Beamter
hmm maybe a trip to the local scrap yard is in order for a piece of plate steel. muhahaha!
Also, in the phase of mocking up the mani, did you already have your turbo? I'm trying to find a junk unit similar to what I'm going to have for mock up purposes until I gain enough bread to get the real deal...and get it running.
I scored some 3" mandrel bends for my exhaust via a later model GMC truck whose owner just needed dual exhaust. I gained one 90*elbow,two 45* elbows and one goofy 110* or whatever elbow. yeah!
It is better if you have the turbo to mock everything up as available space disappears quite quickly and there is lots of stuff to cram under the hood. Hood clearance, downpipe and wastegate clearance are all things that are dependant on your turbo and it almost makes having it a necessity.
Nice score on the mandrel bends.
Recently I had become curious what my car would sound like without a cat so I set out to remove it and replace it with a test pipe. Removal was no where as easy as I had anticipated it would be. I made the mistake of not flanging the connection and using u-bolt style clamps which cut into the metal and almost "swage" the two pieces of pipe together. This makes it hard to pull the pipes apart. I ended up having to cut a notch into the cat with a die grinder to get it off.
When I eneded up getting it out of the car I was greeted with a cat that sounded like a maraca. The brick is pretty much wasted being blown apart and melted. This is with about 8 months of driving and tuning. It definitely did not hold up well and had to have been costing be power. Looking through the matrix with a light shows a good portion of what was left is clogged. I cut a section of tubing to replace the cat and clamped it in place with Dynaflex Truseal clamps which are awesome. I haven't driven the car far yet with it out but the exhaust note is almost unchanged at idle but sounds so much raspier and has much more character than it did with the cat under load.
It's much worse even that it looks in the pics as it is has crumbled inside the matrix and it is hard to get it to show up in a pic.
- Beamter
I've seen the triangles for sale before. Heres some
http://frugalmechanic.com/auto-part/723 ... ust-flange
Well, I can say that after having driven the car today without a cat it sounds a little throatier under load but definitely not loud. It doesn't even come close to loud like a Tri-Flow on an NA car. Boost builds a few hundred rpm earlier and I would be willing to bet that post turbine EGTs are also down (I don't monitor them). It also feels like it revs much freer now.
- Beamter
I can attest to the the triflow on a NA car, had this setup & got tired of it quick! Although I am quite curious how a triflow would sound on a FI ride. I'm sure it's even faster than before. Might be making another scoot down that way, will keep ya posted.Big Bronze Rim wrote:Well, I can say that after having driven the car today without a cat it sounds a little throatier under load but definitely not loud. It doesn't even come close to loud like a Tri-Flow on an NA car. Boost builds a few hundred rpm earlier and I would be willing to bet that post turbine EGTs are also down (I don't monitor them). It also feels like it revs much freer now.
Not surprisingly, my car felt the same once the cat. was gone too. As you stated there was no climactic failure, I wonder how many other cats. suffered this same demise and thier driver's are none the wiser. I think you're right on with the inclusion of tuning having an impact on the failure.Big Bronze Rim wrote:Well, I can say that after having driven the car today without a cat it sounds a little throatier under load but definitely not loud. It doesn't even come close to loud like a Tri-Flow on an NA car. Boost builds a few hundred rpm earlier and I would be willing to bet that post turbine EGTs are also down (I don't monitor them). It also feels like it revs much freer now.
Those are exactly what I am using now. They are great! So easy to use and easy to remove the exhaust when needed. I can't wait to get my car on the dyno in November. I need to get the car tuned to 10-12 psi so I get this compressor closer to the heart of its efficiency.turbodan wrote:
My favorite kind of exhaust clamp. I wub dem.
Great thread!! Ive been pondering doing a turbo on my 83 6er for quite some time now. I looked at TCD and have talked to them a few times now, but it's really out of my price range. Im also very keen to do all the work on my own anyway.
Ive had a chat with George K about his experiences with megasquirt, and i think im going to do this as well. Ive got a spare ECU for my car and would love to be able to utilize it to build the new ECU. Ive also got a friend down here in Oz whose mechanic is very good at building one-off turbo set-ups. Dont know if youve ever seen Julian Seegers B7 replica 6er? He is running MoTec though which is much more expensive but is a cool system. Currently he is putting out around 515whp with 540lb/ft at the wheels too. After getting a ride in that car, id be happy with 1/2 that!!!
Anyway, keep up the good work, ill be learning more about metal fabricating in the next year or so, which would definitely help bring the costs down!!
cheers,
-Jeff
cheers,
-Jeff
