G260/5 Fluid capacity conundrum.
DGM Calgary
Post by DGM Calgary »
My shifter was getting a little notchy (noticably so - autosolutions is normally notchy, but I felt a difference and decided to drain and fill the MTL).
Bentley says 1.25l
Drained for 15 minutes (warm and level). Could only get 500ml of MTL through the fill plug. Had to pull the reverse light switch to get the additional 500ml in.
I recall this happened last time I filled it (1.5 years ago) and I didn't get the opportunity to post the problem. Any similar experiences or ideas?
WTF?
Madhungarian
Post by Madhungarian »
Arghh. Took me a long time to find the "reply" button, but there are tons of options how to use it and jazz it up???! I would trash the cute stuff. We are claver enough to dream up our own. Food for thougt.
Strange as that tranny has a breathing opening on top. Could be a vapor lock to the switch, which is a problematic part to begin with? Maybe moving the shifter around while draining could answer this Q. I had one opened and I don't see any reason for it other than a stuck breathing valve? Is it clean, or you have signs of leak anywhere?
DGM Calgary
Let me clarify - I drained it - completely. It would only take 500ml of fluid then flowed out the fill plug. It would have to have a pound of sludge in the casing to take up that kind of room.
I'm wondering why the lowered capacity.
I didn't measure how much came out.
fastpat
Post by fastpat »
[QUOTE="DGM Calgary"]My shifter was getting a little notchy (noticably so - autosolutions is normally notchy, but I felt a difference and decided to drain and fill the MTL).
Bentley says 1.25l
WTF?[/QUOTE]
I've refilled my Getrag 260 to the normal capacity without problems, don't know why you're having problems.
Additionally, I filled a Getrag 265 with it's required amount, measured in a graduated pitcher, and it came right up to but not out of the fill plug just like the book says.
DGM Calgary
Well, someday when this puppy fails, or I have the cash to shorten my other driveshaft and pop in the G265 - I'll crack this one open and check. Weird.
500ml. That's less than half the advertized capacity.
fastpat
Post by fastpat »
[QUOTE="DGM Calgary"]Well, someday when this puppy fails, or I have the cash to shorten my other driveshaft and pop in the G265 - I'll crack this one open and check. Weird.
500ml. That's less than half the advertized capacity.[/QUOTE]
I don't think I'd drive the car with the tranny half full of oil. Are you sure you're on a level surface, and are using the correct filling technique?
Dave_in_VA
Post by Dave_in_VA »
When changing the oil in my 260/6 I got less than half a pint of oil out.
DGM Calgary
Yeah, level, proper technique. Using a graduated syringe and a length of tubing filling from a graduated measuring cup. It has 1l of fluid in now, but that's because it was filled the rest of the way through the hole where the reverse light switch goes. I'tll be fine, I'm sure. Has been for 3 years now.
I'm still looking forward to a post mortem to find out if there's actually a pound of sludge displacing fluid in the bottom of the casing. The magnet on the drain comes up clean.
Again...Weird.
fastpat
Post by fastpat »
[QUOTE="DGM Calgary"]Yeah, level, proper technique. Using a graduated syringe and a length of tubing filling from a graduated measuring cup. It has 1l of fluid in now, but that's because it was filled the rest of the way through the hole where the reverse light switch goes. I'tll be fine, I'm sure. Has been for 3 years now.
Again...Weird.[/QUOTE]
Hmm, it sure is weird. If you have a friend in either aircraft engine rebuilding and inspection and access to a flexible borescope OR someone in a hospital with access to a flexible pediatric bronchoscope (borrow the light source too), you can look around in your tranny to see if something's up. the two scopes are the same thing, different prices for medically certified ones.
You could also get some small diameter bottle brushes, bend them at an angle and see if you can sweep up something from the botton of the tranny further than you can reach.
Just a thought.
