Try not to laugh but what do you think about this
No, I am not a redneck but I do have a muscle car back ground and since everything is coming off the car anyway, I am thinking about replacing all the brake lines with SS ones. Is that over the Top, or too far over the top???
It Would be a shame to clean everything up and then have the old lines just sitting there, so If I was going to replace them why not use SS???
Fire away as I put on my Nomex Boxers this morning......
[Edit by BNC on [TIME]1107101670[/TIME]]
"While you are there", I would. You can have the mounting hardware gold plated too. Gold does not corrode you know. I know a guy who restored a Austin-Healey 3000 and GPed most of the fasteners in the engine compartment.
Just make sure you car is not nicer than mine .
HTH's
[Edit by DukeM535Ti on [TIME]1107101737[/TIME]]
HTH's
[QUOTE="BNC"]No, I am not a redneck but I do have a muscle car back ground and since everything is coming off the car anyway, I am thinking about replacing all the brake lines with SS ones. Is that over the Top, or too far over the top???
[Edit by BNC on [TIME]1107101670[/TIME]][/QUOTE]
I went to SS brake hoses on my '72 Coupe, as set on the e28 when I did the "Big brake" swap, and have a set to go on the e30. I guess you could say I'm a believer in this upgrade, so, yes, do it as long as they're made by a professional.
The braking feel is enhanced quite a bit, with noticeably less pedal travel.
I also bought and used a Motive Products pressure bleeder which cleaned out the whole brake and clutch hydraulics "while I was in there".
I replaced mine when I did the big brake upgrade "while I was in there". Make sure you get the SS lines with teflon protective covering. It helps keep grit out of the SS braids, which helps them last longer. I agree with fastpat, get a pressure bleeder and clean out the whole system after the install.
Mike
Mike
[QUOTE="BNC"]Yeah, the SS brake Hoses( if you will) are a give me, I am talking about the Hardlines that run from the front to the back of the car and possibly the fuel lines as well.....but thanks for the replies anyway, all and any info greatly appreciated....[/QUOTE]
Ahhhh, I see. Tkere are a couple of companies that will make these for you, and will bent them in advance if you send them the old lines. They advertise in some of the street rod magazines.
I'd only do this if my old lines were seriously rusted, it's a lot of trouble I'd guess, but would last longer than the car will.
I'd stay away from trying to replace the stock hard lines unless they're unserviceable. I've replaced all the hard lines on my '57 Chevy, which has fewer than an E28 (especially one with ABS) and it's a real PITA to get the contours the way you want, especially on the long runs. It'll be even more of a PITA with stainless, as you can't double-flare it and will need to use brass sealing "cones," whereas regular steel lines can be double-flared and require no sealing devices. Also, with steel lines, forming them is much easier and can be done adequately with relatively inexpensive tools -- for stainless, you must buy the high-$$$ tools.
Brad, this is how drivable cars become 'trailer queens'. Each part that gets detailed makes the next piece look bad and then when it is perfect, you hate to drive it because of the wear and tear. Having to clean up the body, chassis, suspension and the engine compartment after getting caught in a rain or worse a cloud of newly hatched ladybugs, etc. eats up alot of your free time (if there is such a thing!) Seems like more fun to spend the time exercising the car on all the excellent 'twisties' in our back yard.
It's hard to know where to stop when the urge to make the car a little bit nicer bites you, huh? Good luck with the project!
Marshall
Marshall
Yeah, I know. But While I'm there...yadaX3. This car will not be my daily driver, but a Sunday Driver, Nice day driver etc....Or what some may call a #2 car, #1 being a restored non driver, #2 being a restored slight driver...
I guess you need to know me better....LOL
The little things will drive me nuts, I shoulda done this , I shoulda done that etc....
But I will drive it, but to be able to insure it for what it will appraise for, it can't be my Daily Driver....
I am still not sure what I am going to do yet but just thought I would ask...
Thanks for your opinion though, they all matter,
