What do these symptoms sound like?
Ok - e28 noob here. My e12 is an M10 kJet car, so this is very foreign to me...
Car is an 86 535i exec. Sometimes it pulls as it should - long and strong to the rev limiter. Today (in the heat), it was .. well. it felt like the ol' 4 cyl e12. It's done this before, and I pulled over, had a listen, no clatter or catastrophe, so gave it a few revs. Suddenly its back to life. Today the same trick didn't work. In the cool evening, its alive again, though that could be coincidence.
My initial feeling is AFM. It idles pretty rich, but is super smooth from 1000rpm up. I wonder if I have a sticky AFM? Is there a good FAQon the AFM? Am I barking up the wrong tree?
[QUOTE="Shawn D."]I'd check the in-tank pump for proper operation. If it isn't working, you can get vapor lock. Note that the in-tank pump is a supplemental pump, not the main pump; thus, even if it is inoperative, the car will run fine under most conditions.[/QUOTE]
How does one check this pump for proper operation?
[QUOTE="Shawn D."]I'd check the in-tank pump for proper operation.[/QUOTE]
[QUOTE="Mike E"]How does one check this pump for proper operation?[/QUOTE]
Isolate (i.e. disconnect) the main pump.
1) Can you hear the aux pump running? If yes, it's probably OK.
2) If you cannot hear it running, is it getting voltage?
3) If it is not getting voltage, why is it not getting voltage?
4) Continue with "standard" malfunction analysis!
