Posted: Feb 03, 2005 12:38 AM
by ChefShawn
thank you
Posted: Feb 03, 2005 8:34 AM
by Shawn D.
What's the width and offset of the proposed wheels?
I suggest you see
The E28 Wheel & Tire Tutorial.
Posted: Feb 03, 2005 10:54 AM
by fastpat
[QUOTE="ChefShawn"]thank you[/QUOTE]
What is the hub bore of the proposed wheels? If it's the same as the e39, you'll need hubcentric rings to adapt the wheels to the e28 hub. As Shawn states, you'll also need to know the offset of the wheels. In the size you propose, a better wheel is one designed for e38 7-series. They have the correct center bore, and in size 17x8 most of them (but not all) are 20mm offset and with a 225/-18 tire, 40 series if memory serves, they will fit most e28's.
