Posted: Feb 03, 2005 6:55 PM
by Threeshifter
Does the clamp need to be loosened so that the splined shaft can slide back an forth? Mine is pretty well stuck in one place.
Posted: Feb 03, 2005 8:11 PM
by Steve Haygood
loosen it so it can slide freely...the kind of question a good supplier answers.....;)
Posted: Feb 03, 2005 8:41 PM
by smackmybutter535i
loosen the large nut near the spline with a big set of channel locks. mine didn't come with much lubrication so I opened it up and slopped some grease in there and slid it back together. install, adjust accordingly make sure you use new self locking nuts, a new flexible coupling and a new center bearing, then tighten the spline when everything is installed. If you dont have a lift, it's a real bitch to install if your laying on your back with the car on jackstands. But its doable. Have fun!!!!
Posted: Feb 03, 2005 8:43 PM
by Threeshifter
Sent you an email today.
Axels look goody good!! They do not have that 5 degrees of rotational play.
Cant wait to install
Posted: Feb 03, 2005 8:48 PM
by Threeshifter
Finally read the Benltey- duh. 17 ft-lbs of torque on the locking nut. Specs it in the center bearing section 15.4.4
