Posted: Feb 13, 2005 12:47 AM
by fastpat
Brian the Parts Pimp supplied me with some electrical parts, which did indeed fit the back-up light connector which had one male pin that had pulled off the wire.:@
As Brian informed me, these connectors are somewhat hard to pick out from the list on the BMW parts manual, so I had to guess which one. Seems there are two that fit, one shorter than the other but works. The 61131369419, did work when I installed it, but it was a little short in the plug housing, so 61131371605 is probably the correct one, it's 4.2mm longer.
Also, Brian, the lighted shift knob plugs and pins worked just fine, thanks again. :D
