Posted: Mar 02, 2005 1:03 AM
by fastpat
Finally, after some prodding, the seller came through and my 3.64 limited slip diff arrived today. Here's a few photos.
Cleaned up pretty nicely. filled with Redline 75/90, and according to some calculation I did a few years ago, this is the best ration for a 535is. :p
Posted: Mar 02, 2005 2:32 AM
by shifty
Good stuff, Pat! You're really gonna like that 3.64!! I hope you don't mind turning 4k + RPM on the highway, though, if you drive over 85 usually. :)
That reminds me that I reeeeeeeeally need to clean up my new-to-me 3.46 diff. It has gunk all over the rear cover and corrosion all over the actual pumpkin. I'm thinking of leaving the corrosion since it'll protect the diff but cleaning the rear cover since it's, uh, dirty. :D
Posted: Mar 02, 2005 8:48 AM
by fastpat
With a 25.2 inch diameter tire I should turn about 3350 rpm at 85 in 5th gear, Shifty. Most of the time my speeds vary between 65-80 on the commute to work, where I spend most of my driving time. :p
Posted: Mar 02, 2005 9:26 AM
by Jim in CO - 533i
What model donated the 3.64 ? Trying to decide between the 3.46 and 3.64 myself. I drive a two lane road - 40 miles - to work each day. Speeds about 65mph but this is Colorado. Altitude averages about 6000ft. Thus the need for a little more zip to make up for the hp drop at altitude. The 3.25 keeps the engine below optimal in 5th and 4th is just a little too busy.
Posted: Mar 02, 2005 12:34 PM
by fastpat
The 3.64 came from a late 635CSi, and is just about the most rare ratio. I've been looking for at least 4 years for one.
For your use and ease of locating a diff, the 3.46 LS is optimal in my opinion, and fairly easy to locate. Many Mid-eighties e23's (7-series) had this diff and a surprising number of them had limited slips. :)
[Edit by fastpat on [TIME]1109784910[/TIME]]
Posted: Mar 02, 2005 1:49 PM
by JBort
Pat,
Check the "Bay-Area" board for a message I left ya!
Posted: Mar 02, 2005 6:25 PM
by fastpat
[QUOTE="JBort"]Pat,
Check the "Bay-Area" board for a message I left ya![/QUOTE]
I got it, Jay, sent you private mail. :)
