Do e23 4-pot calipers fit anything other than an e23?
Bolt spacing is the same as e12 and earlier, can't say for e28. Centering on the rotor may vary. Won't fit 2002 or e21, bolt spacing is different. Only a single inlet, so they are not a bolt on for e12 or earlier which use dual line fronts.
Basically, they're good for e23's...
As far as pad size, mefinks you be high, mon -- e28 pads are not much if any larger than e12 pads, just a different shape.
[Edit by Velocewest on [TIME]1110238145[/TIME]]
