Who has these Hood Struts?
They are E23. The first-gen 7 Series. Actually, one of the E24 hood shocks is the same as these E23 shocks, but then you'd only have one shock if you bought E24 hood shocks! You want E23 hood shocks.
They're a direct bolt-on upgrade. Remove the old ones and install the new ones. 5 minutes per side for even a beginner. A hood shock swap was one of my very first non-oil-change jobs on my first 528e.
They make a HUGE improvement when you're trying to get at something in the back of the engine bay. Really. The only problem is that, if you have a low ceiling garage, you better watch out!
Here are two comparison pics to show you the difference. As you can see, the E23 hood shocks make the hood nearly straight up.
Kyle in NO's 535iS with stock hood shocks:
Icehaus Dave's 535iS with E23 hood shocks. Wow, I just realized how often I post pics of Dave's gorgeous 5er!
Thanks Shifty! So now I must buy some E23 Hood Shocks. Part number I found is 51 23 869 147.
Here is the difference in the specs:
APPLICATION-------BMW 7 SERIES E 23.........APPLICATION-------BMW 7 SERIES E 28
YEAR------------------4.76-8.86..............................YEAR------------------5/81-
OE-NR----------------51.23.1.869.147..................OE-NR----------------51.23.1.927.129
Lift Code-------------1101012................................Lift Code-------------1101041
STABILUS Code---1513BN.................................STABILUS Code---1462BW
USE -------------------Engine Hood.......................USE -------------------Engine Hood
MILE-------------------8mm......................................MILE-------------------8mm
TUBE -----------------18mm...................................TUBE -----------------18mm
EXT.LENGTH-------500mm.................................EXT.LENGTH-------440mm
STROKE-------------206mm.................................STROKE--------------168mm
FORCE---------------230 Newton.........................FORCE---------------380 Newton
--> There is a 60mm difference in Ext. Length.
