not seeing the lock control unit by the speaker
Guest
Post by Guest »
i took out the front passenger speaker, and took out the piece of carpet around it... where is this thing? is it up inside the hole of the speaker? i see nothing other than a pack of wires held together with white plastic, thats clipped just below the speaker hole on the inside.. is that what i'm looking for?
it is located above the glove box,I believe.... not your ECU but the little black box
Guest
Post by Guest »
ok so its got a black case over it, but its gray and it says -motronic bosch- is that it? i guess if so i'll try to see if theres a loose connection somewhere... power locks dont work again for the 10th time in a month
No that is your ECU, above that but you are in the right area...
Buy a Bentley!!!
Guest
Post by Guest »
dammit.. above there i cant see crap.. yea i need a bentley
John in VA
Post by John in VA »
Gotta reach WAY up in the channe above the speaker hole - 2 small screws hold the control unit in place. Small / skinny arms help!
Guest
Post by Guest »
ok. So its above the ECU or in the speaker hole.... ???????????
John in VA
On my '86, I stuck my hand and arm into the speaker hole, feeling straight up to reach the control unit. You may see the sharp tips of the 2 screws facing toward you if you've removed the kick panel carpet piece.
It's even MORE fun putting it back!!
pdx 528e
Post by pdx 528e »
[QUOTE="John in VA"]On my '86, I stuck my hand and arm into the speaker hole, feeling straight up to reach the control unit. You may see the sharp tips of the 2 screws facing toward you if you've removed the kick panel carpet piece.
It's even MORE fun putting it back!![/QUOTE]
To aid putting it back.. thread the screws into the unit partially, and then feed the box up the speaker hole and slip it into the larger portion of the screw holes, its designed so that you can slip the screw heads through, and then pull the box down into the smaller portion of the screw holes for tightening.
Its probably about 5 to 6 inches above the speaker, dead center of the speaker hole. Make sure your battery is disconnected before removing it. Above the ECU, in my car, there is the idle control module. Perhaps in different model years and cars they had different locations?
Guest
Post by Guest »
alright thaks pdx, now i know.
