Opinions on oil consumption.
after chowing a quart a week for the firsts few months, its finally trickled off to add half a quart at the 1500 mile mark or so....
I also had to "re-hydrate" the all the seals in a motor that had been sitting in a junkyard for lord knows how long... but I'm at the 8 month mark IIRC, and so far so good.
I loose about 1.5 quarts per oil change of 3k-4k. I loose most of it thru leakage and not thru the combustion chamber.
Id say that 1 quart per oil change is pretty good/average for 130k+ engines.
Higher sustained engine speeds would produce more oil flow at higher oil pressure per time than stop and go where the engine is at idle form some time. This might lead to more leakage depending on the path.
Higher piston velocities I would think would produce more oil film between the rings and the cylinder.
It is also recommended that heavier oils should be used for sustained high speed driving. This may help reduce oil consumption thru the rings on the long hauls.
Are you referring to the magic additives that revive your seals?
I would recommend not using these products. They essentially swell the polymer components of the seals so that they expand to create higher loading against sealing surfaces. The problem is that this process breaks the polymers down and over time they can deflate and extrude thru the gaps between parts. It will essentially break down the polymers.
just needed to recondition them after sitting for ages... run castrol GTX 10-30 from 7-04 to ~3 weeks ago, and 5-30 from here on out. no additives.
just needed time to get all settled again, it used to smoke something fierce under engine braking... YIPE!
now it clean as far as I can see... seems leak a mite bit more, I'll have to address that issue as I go.
I find this interesting (Ch 4 pg 4, Bentley):
I also find it disconcerting to notice that my engine never even burns a half a quart every 3000 miles, no matter how I drive it. The motor has 16,000 miles on it. I wondered for a while if I had seized pistons rings, as it had cold running issues. My car sat, after its rebuild, for the greater part of ten years. Most of the lurching went away when I installed a hose clamp on the valve cover breather hose.
[Edit by pdx 528e on [TIME]1111465536[/TIME]]
BMW states that the maximum allowable oil conumption for the engines covered by this manual is 1 quart per 390 miles. This is why the oil level must be checked, and occasionally corrected, between oil changes.
Wow that is interesting. I see it in my Bentley too. That means we are on not out of tolerance until we consume 7.7 quarts of oil per 3k oil change interval!
the Borman6 uses a qt of 20/50 every 1.2- 1.5 k. This has remained steadty since I bought it with 150k . its nearly 297K now. It leaks from the head gsket around #1 cylinder. I use 84 cent a qt oil and 3$ filters changed out at 3-4k intervals. I'm not gonna touch the motor until it gets much worse. I have never even taken off the valve cover. On trips I can go 2kmiles and not use any oil. But maybe this is due to usually changing it before the trip.
I use about 1 qt about every 4k if I run normal. Normal meaning keeping the rpm's under 3.5k or so. If I push hard, then about every 3k then. Hard meaning running autobahn speed with rps over 3.5k. I have been using Castrol 5W-50 syntec year round with no problems. When I get a quart low I just change the oil and filter, instead of adding another and then changing at 5k.
