Need measurement help..........!!!..............
Can one of you get me the length of the shift rod for a 265 tranny with a sheet metal console?
Trying to install the one I received from BMW did not work and the rod seems to be a least 1" too long. It is 1 220 565. I chunked the original one, yea I know. So I am not sure if this is actually too long or if I am doing something wrong on install. I received the alternate shift rod listed in the ETK and other than a bend in it, the length is the same. BTW, the 565 rod was 16 Euro and the one with a bend was over 62 Euro, I told them to keep it.
I am a little perplexed and this is keeping me from getting the drive shaft in and the exhaust on.
I just received my exhaust tip from BNC and that baby is nice. I also received the metal brackets and other stuff from MacMaster Carr and am ready to finish this Mutha! I will be going to the garage everyday after work now that the temp are OK and we have light.
You do know about the Bentley problem in that area, right?
Yep. I have the straight rod with a sheet metal console.
JBort
Post by JBort »
Duke,
I just so happen to have the tranny out of my '85 project 535.
265 tranny and sheet metal shift console, too!!
I measure 148 mm from centerline pin to centerline pin, along the shift rod.
HTH
[Edit by JBort on [TIME]1111543252[/TIME]]
Madhungarian
Post by Madhungarian »
I have mine out too. Measured 5 inches pin center to pincenter.
What is the Bentley problem in this area??? :? Does it apply to the sheet metal console too?
[Edit by Madhungarian on [TIME]1111540503[/TIME]]
THANKS GUYS............I do indeed have the wrong one. It is for a 260/5 and I will sell it CHEAP!!!
