S38B36 flywheel on M30 B34 engine
We have a fitting problem regarding the sensor, what is the solution?
- Beamter
As I said on Facebook, you cannot use it unless you also change your injection to Motronic 1.3 from an E32 or E34. It may be possible to drill a hole in the side and insert a dowel pin to act as the trigger for the sensor, but it must be EXACT or the timing will be off.
What car is this in and what injection is it running?
We put one on a lightened flywheel that was sans trigger. With the one pictured you might be missing the outer area between PP bolts where it would usually go.
Like Moose said if you add it... it better be in just the right spot and I would verify this on engine by marking the current trigger location carefully then transferring to the new flywheel which is what we did. It has nothing to do with where you 'think' TDC would be. It's way off from TDC lining up with the TDC sensor. I think it leads by almost 90 degrees or such.
Then it better be secured very well since if it flies off you are kaput. We milled a slot and added a small bar with two screws and loctite. Then the PP bolted down over this so it's not coming off. I might have a picture still.
Then you also need to balance the new assembly IMO. We balanced the flywheel then balance again with PP added. I've yet to see a PP as well balanced as OE BMW flywheel btw. The PP always throws the balance off no matter how you orient it.
The car is a E28 with motronic 1,1. M30B34 enginemooseheadm5 wrote:As I said on Facebook, you cannot use it unless you also change your injection to Motronic 1.3 from an E32 or E34. It may be possible to drill a hole in the side and insert a dowel pin to act as the trigger for the sensor, but it must be EXACT or the timing will be off.
What does PP stand for?
and is there a photo of thefltwheel with the modification available?
- Beamter
not sure a tab would work with the 6 ears for the pressure plate potentially sending signals too, i can't remember if the ears are close enough to the path the ref sensor reads to be a problem. i had that flywheel on my m30b35 in the 81 633 and moved it to the m88/3 in the new shark.
it doesn't take much for a tab, here is one i made for a 635 to avoid pulling the tranny
on the average flywheel yes but this one is a little different with the tabs hanging out, i can't remember if they are in a bad position to provide false triggering
tn535i wrote:On all that I've seen on M30 and M20's the tab stands proud enough from anything else it should not be triggered from either the machined FW, PP or even a torque converter like you show.
