BMW E34 TOURING TRANSMISSION SWAP / RESTORATION
Hi Guys
Just figured i put my project out there. I have owned a 1993 525it for over six years. It was originally silver with a silver grey interior. The interior was trashed when i got the car. I took the entire interior out including the seats, carpet, dash, pillar covers and center console, and door panels and replaced them to black. The interior took me about two years to complete due to nonavailability of black touring rear seats at all the local junk yards and ebay. I have the car painted black 5 years ago. Over the years i have gone with the bigger 540i brake system, H & R lowering springs up front with bilstein sports struts, headlining reface, front bumper air ducts.
I figured i will wait till the GM transmission go out before doing a 5 speed swap but the bitch will not die. So at the end of the march, i figured it was time to do the 5 speed swap. And so it started.
images before the project started
- Beamter
Hi Guys
Thanks for the feedback. I used a product called purple power to decrease both the engine bay and tire wells. I can't remember the name of the material i used but i picked it up from Hancock fabric. It was said to be headline material but it has a suede fluffy feel to it. Hope that helps!!!!
- Beamter
Just got in from working on the car and decided to do some updates.
Here is a better picture of the finished tire well
I figured sine i was under the car, might as well start cleaning it for repaint
Here is what the other side looks like before cleaning
Here are some of the refinished goodies
Time to start putting the strut back together
Got a little lazy and just repainted the calipers, they looked really bad. So today i spent an hour wire brushing them. Here is a look at what some extra effort yields.
- Beamter
Yep. It's a pretty simple task, made easier by it being in multiple pieces. It's also quite affordable to buy the pieces new, although the side's are NLA in black colour. You do need a working sunroof, though, or at least a non-stripped out manual override nut.wkohler wrote:It's not hard to remove the headlining. There is a procedure to doing the roof panels that involves having a working roof.
Car looks great, it's amazing what a simple clean does to the appearance of the underside!
I only use 3m super 77, I've had bad experiences with other sprays. Even with different 3m products.mooseheadm5 wrote:Perfect! What about adhesive?
http://www.amazon.com/3M-Super-Multipur ... m+super+77
And yes you have to remove the headliner from the car.
Purple power is the shit.doyfola wrote:Hi Guys
Nice job! brings back many memories. A touring is a hell of a car with a manual trans.
The hardest part on mine was grinding a friggen slot on the head of the fracture bolt in order to remove it so as to be able to change out the pedal box. Aside from that the manual trans install was a breeze. Best of luck on a worry free completion.
I learned yesterday that those bolts will unscrew with a pair of channel locks ( or tongue and groove pliers).RDAvena wrote:Nice job! brings back many memories. A touring is a hell of a car with a manual trans.
Latest updates
Hi Guys
I truly appreciate all the positive feedback. It has kept me motivated to keep this project going.
So far I have been able to install the manual pedals. True to the comments, the bolt under the steering was a true nightmare to get out. I also finished the wiring for both the cruse control, reverse lights and removed the automatic transmission computer.
Strut are installed on the car
Power train
I was originally going to stick to the original engine and do a the 5 speed swap. But as it is it has turned to a full resto. I was thinking it would not complete without dong some engine modification of some sorts. I have been seeking the advice of some of my gear head buddies. And the con-censors was to do a 3.0 smoker. That would entail pistons and rods from an m54b30 block, crankshaft and intake cam. I set out to the junkyard to find a 3.0 block and found this !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thats right a 1995 e36 m3 . I proceeded to gut that bad boy.
I took the engine, transmission, drive shaft, front and rear brake calipers front and rear, steering wheel. Got back and stripped it down.
Engine tear down
Hi guys
Once again thanks for all the positive feedback. You keep me going when i'm about to quit on this project.
I decided to tear down the engine cause i wanted to know what i was dealing with although it was said to have 89k miles on it, and possibly wanted to do some upgrades.
So here we go
Looking good so far
That's a good looking block? No slug?
impressive
Head off
Now i'm impressed
What the Hell!!!!!!!!!!!!!
Forged pistons???????????????
Time for purple power and paint
I think i need some bling
That's right, 2 hours of fine wire brushing and a bout with the dremel tool, then clear coat. What an effect!!!!!!!!!!!!!
So here we go
Looking good so far
impressive
Head off
Now i'm impressed
Let's see how it looks on the block ?
Now that's sexy
I think i'm in love!!!!!!!!
E34 oil pan after overnight deep in purple power.
nmmmmmmmmmmm not too bad lets try the wire brushing effect
I'm going for it
Hell ya. Please note this is not for the faint of heart. Oil pan took 4 hours to get the effect and then heat resistant clear coat. This is what the block looks like
Head cleaned and ready for machine shop
Now that's sexy
I'm going for it
Under coating
I think i time i started finishing this part
These are the products i picked up from the local parts store. If you are thinking for doing something similar, take the time to mask off all the bolts and mounting points. You don't want this in your bolt holes. It is rust resistant, paint-able, sound insulating and rubberized. I will be taking a couple of days off this project. It has taken 4 hours every night and all of my weekend for the last 3 weeks. I NEED A BREAK. Lol
BMW E34 TOURING TRANSMISSION SWAP / RESTORATION UPDATE
Hi guys
I am sorry it has taken so long to do an update. It has been really hectic working on the project nights and weekends with not much rest. And being that i wasn't originally planing to do a full nuts and bolts restoration, which it has very much turned out to be. Plus i did not have much of an original budget ($1000.00) for the 5 speed project. I have gone way north of that. Total spending has now entered + $4000.00 and climbing. Plus delays in parts arrival. But who really cares (Wife). lol
At any point i'll take off from where i left this. New 3.0 m3 gaskets finally arrived
Head and cams finally installed to specifications
loving the look
Since i wire brushed all the brackets, lets see what the cover would look like?
Vanos rebuild kit finally arrive
Engine is almost done
Refinished the power steering / Self leveling suspension
loving the look
