Banned from myE28.com access from home?(after avatar upload)
StolenFox
Post by StolenFox »
Anyone know why I cannot access this site on my home network even though the broadband is fine and I can go anywhere else I want on the interwebz?
No problem getting on here at work....
S.F.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Do you get an error message? PM me your IP address at home and I can look in the error logs for the site.
StolenFox
Post by StolenFox »
well, i think i figured it out....
Tried to upload a new avatar pic just a minute ago and now it wont let me access here from work via our network. Log on using my laptop's wireless card and we are good to go. Now that I think about it, I tried to upload the same pic (V8 engine shot) from home when this mess started.
Can any of the mods help "reset" my access. I promise I'll never, ever try to upload another avatar!
S.F.
StolenFox
Post by StolenFox »
Justin_FL wrote:Do you get an error message? PM me your IP address at home and I can look in the error logs for the site.
How do I find the IP address for my home & work networks?
S.F.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
You can goto http://ip-lookup.net/
I need the address to see if you are getting snagged by ZB Block-- it uses a combination of malicious behavior filtering and black lists. These aren't perfect so innocents can be blocked but you should get an obvious page describing what has happened.
I don't need your work address, I see what happened, but do send me your home address.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Hmm, yeah, looks like ZB Block sees the phpBB avatar upload as a malicious action so it instantly banned you.
I disabled the rule for now so avatar uploads should work properly.
Your work IP should be removed from block now and probably your home one, too. I cleared out the list.
adrian in florida
Post by adrian in florida »
Justin , you rock.
I'm just sayin.
You provide better service for free than my IT group does for my organization and they get paid a lot
Post by unt0uchable »
adrian in florida wrote:Justin , you rock.
I'm just sayin.
Correct. Winnar winnnar. It's appreciated all around.
StolenFox
Post by StolenFox »
Justin_FL wrote:You can goto http://ip-lookup.net/
Justin FTW!!! Work is back online, i'll pm you the home IP this afternoon.
S.F.
StolenFox
Post by StolenFox »
Yeah, so I messed it up again.... Tried to upload the avatar pic and it gave me the boot. Would you mind resetting me again?
Screw the avatar!
Thank you.
S.F.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
StolenFox wrote:Yeah, so I messed it up again.... Tried to upload the avatar pic and it gave me the boot. Would you mind resetting me again?
Screw the avatar!
Thank you.
S.F.
I believe the issue is now resolved, see if you can upload an avatar. It worked for me.
I'm just sayin.
One of these people loves their work.
Thanks Justin!
