Wheel Help
Wheel Help
Hello,
Can someone tell me if wheels with these specs will fit an E28:
Front - 16x8.5 ET10
Rear - 16x9.5 ET14
Thanks,
Alex
Front - 16x8.5 ET10
Rear - 16x9.5 ET14
Thanks,
Alex
- Beamter
- Beamter
Only if you trim or pull the fenders, which means they don't fit. The car pictured also has M-tech flares. On a car without them, the wheels he asked about will protrude past the fender lip and any proper tires will rub the fender a lot. So, no, they do not fit. You can make them fit, just as you can make nearly anything fit if you have a cutoff wheel and a welder, but they do not fit a stock E28.kzolee wrote:16x9 ET8 fits.
Let me guess, Ronal ACT painted white?
While they were on my car briefly, I sold them because there were almost NO tire options for the size I wanted to run for the rears. And besides trimming/rolling the rear fenders, you would still have to run with significant negative camber to clear the rear fenders. I was not willing to go that far. Too bad, those wheels look awesome.
looking for a bbs wheel
i'm looking for ( 2) 8 1/2 j x 16 h2 bbs wheels
its an older wheel, i don't what they came on.
anybody know them? they are not in any bbs listing i've looked at.
thanks, dave
thanks, dave
Re:
Had to resurrect this one.kzolee wrote:16x9 ET8 fits.
Any more info on this fitment?
Just scored some 16x8/9 et35/8 remotecs and really want them on without too much fuss.
My 535 is lowered 40/60 on spaxx and has M5 arches. currently sitting on 15x7 with loads of rubber (205/60 15).
Any advice would help. Can I get a relatively sensible tyre on there with no cutting/rolling?
Re: Wheel Help
You'll need spacers. 20mm for the front and 10mm for the back most likely, but I'm not 100% sure on that.
They won't fit without the spacers, those are late model 3-series wheels most likely.
Re: Wheel Help
Jeremy wrote:You'll need spacers. 20mm for the front and 10mm for the back most likely, but I'm not 100% sure on that.
Thanks Jeremy, but 10mm for the back would put me into poke city.
The fronts should be ok with 10-15mm spacers but i want to make the back fit before i start on that.
Kzolee's picture shows some pretty sensible looking tyres and minimal poke on 16x9 et8 at the back. just wondering if there has been any work done to the rear to fit these or is it just a good choice of tyre (hoping for the latter)
Re: Wheel Help
You said they're et35. A 10mm spacer puts it at et25. That's not "poke city" for 16x9.
Re: Wheel Help
Jeremy wrote:You said they're et35. A 10mm spacer puts it at et25. That's not "poke city" for 16x9.
Thats on the front.
rears are et8.
