745i 013ecu question
- Beamter
The 013 ecu in my car has connects to 2 separate harness. One is for the motor & the other side is for the tranny. Can someone tell me which plug (ecu side) is which?
Re: 745i 013ecu question
I emailed you a picture of the plugs on the 013. I am out of town so could not photobucket it, but maybe you can and post in the ecent it is needed in the future.
95% sure the outermost plug with the EPROM(s) that you install to remove the boost limit is the ECU side.
