Sputtering on boost...
Posted: Oct 27, 2014 6:53 PM
by LTCol
need help guys...
the car just started sputtering when hitting boost...normal acceleration is fine though... what could it be?
** i checked the coil wires for damage but i dont see any damage.
** i checked the plugs, its running 'Bosch +5 HR7DC' - not sure if this is the right plugs to run for my setup (previous owner installed it)
** could this be vac/boost leak?
thanks!
E30 M30B35 GT3582r topmount Tial 44mm wastegate Tial 50mm bov 3" straight exhaust
Re: Sputtering on boost...
Posted: Oct 28, 2014 10:00 AM
by Brad D.
What is plug gap? What are you using for engine management and what is the air fuel ratio when the sputtering occurs?
Posted: Oct 28, 2014 7:48 PM
by LTCol
ill check the plug gap when i get to work, using MSPNP and af around 12-13 when sputtering occurs
Posted: Oct 29, 2014 1:41 PM
by turbodan
Plug gap, wires, cap or rotor are most likely. Wires aren't something you can check visually. They may not arc at idle either but under boost with a much denser mix in the combustion chamber they may be leaking. If you've never replaced them or its been a long time they are a possibility.
I was running around .024" on the gap I think. Not much but it didn't cause any driveability issues. It may have helped that I was running an MSD Blaster CDI instead of the stock inductive coil.
Posted: Oct 29, 2014 4:09 PM
by Brad D.
turbodan wrote:Plug gap, wires, cap or rotor are most likely. Wires aren't something you can check visually. They may not arc at idle either but under boost with a much denser mix in the combustion chamber they may be leaking. If you've never replaced them or its been a long time they are a possibility.
With the stock coil and cap/rotor I was running 0.025" with no problems up to 12 psi. Anything more and you may have problems depending on boost level. My feeling is that it is likely ignition related.
Posted: Oct 29, 2014 8:07 PM
by marc79euro645
I would suspect the vr signal might be dropping out. You should datalog it happening and study it. Tuning the two pots can help stabilize the vr signal, mega manual has a chapter on it.
good luck
marc
Posted: Oct 30, 2014 9:05 PM
by EricF
One lesson learned in the Volvo world is that there are a number of variables influencing the gap you can run at a given boost level. Even with a good baseline sometimes its difficult to open the gap up. And anything over a certain gap will blow out.
I have had cars that will run .025-6 easily, and those that I couldn't open past .023. The other thing to keep in mind is that copper plugs wear very quickly in boost. I used to re-gap every other oil change, and needed to.
Posted: Oct 30, 2014 11:05 PM
by LTCol
Thanks guys! found the culprit! 2 foul plugs and a small hole in the vacuum hose to the wastegate.
cheers! lets boost!
