Does anyone have access to BMW or machine shop data to confirm that the M30 and S38 deck heights are both 217.5 mm? I'm getting ready to order custom pistons and rods and so I'm double checking all of my measurements.
Devinder
deck height
Bert-Ola,
This is what I thought too but I have reason to suspect that it is actually 217.5 mm. I first noticed the problem when I measured the compression height on my M30b32 pistons. The CH is 39.8 mm and they stick out just above the deck. So, I measured the deck height on this block and it's 217.5 mm. I thought maybe it had been decked so I also measured my 3.0CS engine and it's 217.5. My spare S38 block is also 217.5.
Devinder
Devinder
I've always thought the deck height on all M10/M30/M90/M88/S38 are 218,0 mm.
Would be good to have the confirmed deck height.
Devinder,
I'm willing to give you right on this!
Today I measured my M30B35 which are standing without head in my garage.
Piston height should be 39,85 mm according to Mahle parts catalogue.
Rod length 135 mm.
Crank 86 mm.
At TDC the piston on #1 cylinder stick out about 0,3 mm, and #6 about 0,4 mm.
This makes:
39,85+135+(86/2)=217,85
217,85-0,35=217,5 (which would give Devinder right)
Rod length 135 mm.
Crank 86 mm.
This makes:
