T4 Hot side size?!
Posted: Aug 04, 2016 12:38 PM
by smhheidari
What size of hot side are you guys running?
Im shooting for 500whp stock b34 block + b35 head.
Got E85 setup already done and ready to go.
Im running 44mm and RSI turbo manifold non split pulse.
3.5" straight exhaust.
Re: T4 Hot side size?!
Posted: Aug 04, 2016 6:33 PM
by T_C_D
.58 or .69
It's going to be very laggy with 7.4CR and the tubular manifold and B35 cam.
Posted: Aug 04, 2016 7:11 PM
by smhheidari
Whats the recommended CR for that power range and E85?
Posted: Aug 04, 2016 7:17 PM
by T_C_D
smhheidari wrote:Whats the recommended CR for that power range and E85?
Probably 9.0CR. Use a b35 bottom end if avalable.
Posted: Aug 04, 2016 9:55 PM
by smhheidari
Which E32s have the b34 style mounting casting blocks?
I heard before 1/88, is this correct?
ETK doesnt show any difference between pre 88 and post 88.
Posted: Aug 04, 2016 9:57 PM
by T_C_D
smhheidari wrote:Which E32s have the b34 style mounting casting blocks?
and all 88/89 e24 635csi.
Posted: Aug 06, 2016 9:41 AM
by Cjames570
I'm with TCD.... I would go up in compression for sure.... even if you just get back to 8:1 with a stock b34 head
To help answer your question though, I'm running a 6266 with a .81 hot side and getting full boost (20-21lb) at ~3300..... this is on a b34 with a b35 cam
Posted: Aug 06, 2016 8:27 PM
by smhheidari
how much CR i get with dirty b34 pistons/b35 head?
Posted: Aug 07, 2016 11:59 AM
by M. Holtmeier
Borg S300 .91 twin scroll. Currently at 17.5 psi with e85. Full boost by 4kish. Stock b34 with some headwork, valves and a PB cam. Still taking it easy with the tune, I'll have more concrete characteristics when I get on a dyno. So far the car doesn't feel too laggy.
Posted: Aug 08, 2016 7:51 PM
by smhheidari
Borg S3xx is my first option, but they dont come with anything less than .88.
I found this tho:
http://www.ebay.com/itm/322199073964?_t ... EBIDX%3AIT
@M. Holtmeier
How high your engine revs?
Posted: Aug 08, 2016 9:51 PM
by M. Holtmeier
Stock Redline.
I would switch to a twin scroll manifold.
Posted: Aug 10, 2016 7:54 PM
by smhheidari
Where can i get one for reasonable price?
Posted: Aug 10, 2016 8:05 PM
by M. Holtmeier
That's just it, twin scroll m30 turbo manifolds are pretty much all custom built to order.
Posted: Aug 26, 2016 9:51 PM
by Bigdoug92
M. Holtmeier wrote:Borg S300 .91 twin scroll. Currently at 17.5 psi with e85. Full boost by 4kish. Stock b34 with some headwork, valves and a PB cam. Still taking it easy with the tune, I'll have more concrete characteristics when I get on a dyno. So far the car doesn't feel too laggy.
Which S300 are you running? Getting a smoking good deal on a new one and can decide between the S362 and S366.
Posted: Aug 27, 2016 7:30 AM
by M. Holtmeier
S366.
Posted: Aug 27, 2016 2:57 PM
by Bigdoug92
.91 A/R divided or .88 A/R open?
Posted: Aug 27, 2016 3:00 PM
by M. Holtmeier
.91 divided.
Posted: Aug 27, 2016 3:43 PM
by Bigdoug92
when do you see boost start to come in? You said in a previous post is full by 4k.
also who's manifold are you running?
