What should my m30b34 be making at 15psi?
Posted: Feb 26, 2017 8:06 PM
by Logan1994
Ok here is my setup.. m30b34 mls, arps, 42lb injectors, intank walbro 255, comp 61mm turbo .58 ar, megasquirt ms2, tial wastegate with 10psi spring, manual boost controller, and a/a intercooler. I just got it tuned locally on 15psi. The numbers are 270whp and 312lb of torque on a mustang dyno. To me it seems low but figured I would ask. Tuner said my injectors are maxed out and suggested some 1000cc injectors before turning up the boost. Now I have seen that some people say the 42lb injectors are good til about 350whp. Any help is appreciated.. may have to dumb it down for me to understand but I will try. My plan is to push the motor to the edge maybe 20+ psi.
Re: What should my m30b34 be making at 15psi?
Posted: Feb 27, 2017 12:07 PM
by T_C_D
What manifold? TCD manifold makes a consistent 345/395 at 15psi on a Dynojet. No way the 42lbers are maxed out. If tubular manifold, power level is higher and the Mustang Dyno readings are way way low. 100lb injectors are a stupid suggestion and that makes me wonder about your tuner. 60lbers are more than enough.
Posted: Feb 28, 2017 10:41 PM
by Logan1994
The manifold is custom doesn't look nice but I guess it works I don't know who made it.The tuner is local and is more of an Asian tuner evos and subarus. I tried finding some other tuners as well but the few I talked to didn't want to mess with megasquirt and he said he would do it. Yeah I figured from my research that 60lb injectors would be plenty for what I plan. Now I'm wondering if I'm having issues with the motor as well since it probably has 200k or more on it.
Posted: Mar 01, 2017 10:09 PM
by Nebraska_e28
Have you done a compression test?
Posted: Mar 02, 2017 12:45 PM
by Logan1994
Yeah last time I did one they were all right around 150
Posted: Mar 02, 2017 6:32 PM
by Shadow
15psi is twice the air, so it "should" make twice the power. Depending on your elevation.
Posted: Mar 02, 2017 6:38 PM
by T_C_D
Shadow wrote:15psi is twice the air, so it "should" make twice the power.
Efficiency is always better so they do at least 2.25x
Posted: Mar 02, 2017 10:44 PM
by BENAllison
Do you have any pictures of the set-up?
Posted: Mar 02, 2017 11:41 PM
by Logan1994
Posted: Mar 03, 2017 3:20 PM
by George
Can you post a datalog of a dyno run that indicates the injectors are maxed out?
If engine is healthy and the injector duty cycle is indeed maxed out I would start looking at fuel supply. Are you confident fuel pressure was maintained during tuning?
Posted: Mar 04, 2017 9:50 PM
by Logan1994
I don't know if fuel pressure was monitored. I should just install a fuel pressure gauge so I can monitor it. I will try get ahold of the tuner to see if he can datalog a full pull. Or I may try it myself with my tablet
