Used once, excellent condition. Includes a spare M12/14 threaded rod. Works on the E28, E24, E32, E34, and E31. There is an update kit available so that this tool works on the E38 and E39 as well. Allows for replacement of control arm bushings without removing the ball joint end of the arm from the steering knuckle.
Pictures
$225
FS: Sir Tools BMW 3021 for upper control arm bushings
Re: FS: Sir Tools BMW 3021 for upper control arm bushings
Wait, is this the same tool you were renting for the RR of the (big chunky) rear rubber mounting?
I still need to rent it from you please.
Different tool
Last bumped by Frybrid 524td on Oct 02, 2017 3:03 PM.
