Tapping oil pan advice....
Posted: May 02, 2018 10:28 AM
I'm thinking to use a step up drill bit to tap the oil pan for a 1/2 npt thread. How far behind the pan wall is the oil baffle?? How far can I go before I fuck things up?? Lol
Awesome information Sir....thank you much!!!tschultz wrote:This is mine... I'm not sure where I would put it if I redid it, however...
1/2" NPT x -10AN nipple
Clearance with the motor mount is a concern for bottom mounting:
If one takes off their oil pan they might as well tap it.Kyle in NO wrote:I have a pan already tapped for an oil drain if you’d like to swap.
