Air water intercooler
cwl4m5
Post by cwl4m5 »
Pump is running but it does not look like fluid is flowing
Re: Air water intercooler
Did you bleed the reservoir? Are the heat exchangers installed with the fittings on the top side?
offroadkarter
Post by offroadkarter »
sounds like you're air locked, they have to be bled just like a normal cooling system.
cwl4m5
Post by cwl4m5 »
Yes bled and yes on top
