Starter upgrade
Starter upgrade
Is it worthwhile to upgrade the M5 starter to a B35(1.7KW) or M70(2.2KW) starter. I am about to replace the starter on my M5.
Re: Starter upgrade
The gear reduction B35 starter is smaller, lighter and sounds like it cranks with more energy IMO. I don't have it in my M6 (still original) but put one in my 535 and it's also a lot easier to install.
Re: Starter upgrade
Hey, did you end up installing a b35 starter in your M5?
How does it perform for you?
Also, where did you get yours?
Thanks
Etip
Thanks
Etip
Re: Starter upgrade
i put a B35 starter in my M5, when i had the engine out, a few years ago. i opted to install studs in the block, to make future replacement easier. worked great for me, on both accounts.
Re: Starter upgrade
Thanks Austin. Motor is out, so I'm planning on doing it now as well. I guess I'll do studs also...austin8753 wrote: Mar 23, 2022 1:21 AM i put a B35 starter in my M5, when i had the engine out, a few years ago. i opted to install studs in the block, to make future replacement easier. worked great for me, on both accounts.
Re: Starter upgrade
when you install studs, make sure the transmission is already bolted to the engine. if you don't do it this way, you run the risk of installing the stud too far in the block and the corresponding bell housing bolt won't have enough threads available to be tightened properly. use red loctite on the end of the stud so it doesn't come out later. good luck!Etip wrote: Mar 23, 2022 1:27 AMThanks Austin. Motor is out, so I'm planning on doing it now as well. I guess I'll do studs also...austin8753 wrote: Mar 23, 2022 1:21 AM i put a B35 starter in my M5, when i had the engine out, a few years ago. i opted to install studs in the block, to make future replacement easier. worked great for me, on both accounts.
Re: Starter upgrade
Thanks for that info. I'll heed it.austin8753 wrote: Mar 23, 2022 1:35 AMwhen you install studs, make sure the transmission is already bolted to the engine. if you don't do it this way, you run the risk of installing the stud too far in the block and the corresponding bell housing bolt won't have enough threads available to be tightened properly. use red loctite on the end of the stud so it doesn't come out later. good luck!Etip wrote: Mar 23, 2022 1:27 AMThanks Austin. Motor is out, so I'm planning on doing it now as well. I guess I'll do studs also...austin8753 wrote: Mar 23, 2022 1:21 AM i put a B35 starter in my M5, when i had the engine out, a few years ago. i opted to install studs in the block, to make future replacement easier. worked great for me, on both accounts.
Is there some other number or ? That the B35 goes by? I've been searching for a half hour and no one like FCP or the other parts suppliers show a "B35 stater"
Re: Starter upgrade
you would order parts for an M30B35 equipped car, so tell the catalogue you want a starter for a 1989-1993 535i.Etip wrote: Mar 23, 2022 1:58 AMThanks for that info. I'll heed it.austin8753 wrote: Mar 23, 2022 1:35 AMwhen you install studs, make sure the transmission is already bolted to the engine. if you don't do it this way, you run the risk of installing the stud too far in the block and the corresponding bell housing bolt won't have enough threads available to be tightened properly. use red loctite on the end of the stud so it doesn't come out later. good luck!Etip wrote: Mar 23, 2022 1:27 AMThanks Austin. Motor is out, so I'm planning on doing it now as well. I guess I'll do studs also...austin8753 wrote: Mar 23, 2022 1:21 AM i put a B35 starter in my M5, when i had the engine out, a few years ago. i opted to install studs in the block, to make future replacement easier. worked great for me, on both accounts.
Bosch part number: SR441x
Re: Starter upgrade
Yes I did the B35 upgrade. It was much easier to install than the old one. Cranks fast . It will be a whole easier with the motor out.
Its Bosch SR441X for the part number.
Re: Starter upgrade
Ricky535 wrote: Mar 23, 2022 9:00 PM Yes I did the B35 upgrade. It was much easier to install than the old one. Cranks fast . It will be a whole easier with the motor out.
Thanks guys. I just ordered. Paid a few bucks extra for Amazon but no core to return and will be here in a couple days.
I'll be sure to have it bemce tested before install.
Everything is really coming together for the car!!
